Введение
This guide provides instructions for how to replace the display in your Garmin Nuvi 2599 GPS.
Выберете то, что вам нужно
Use a T4 Torx screwdriver to remove the four 5.8 mm screws from the back of the device.
Insert an opening pick into the seam between the top and bottom case and slide it around the edge of the device to release the clips holding them together.
Insert an opening tool into the seam between the top and bottom casing, and gently pry them apart.
Use an opening tool or a clean fingernail to flip up the locking flap on the display cable—this is the unlocked position.
Use tweezers or your fingers to gently pull the ribbon cable out of its socket.
Remove the display assembly.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
