Введение
Before disassembling anything be sure that the device is powered off. This installation is much easier for those familiar with the use of soldering irons. Those who have never used one before should look at this guide.
Выберете то, что вам нужно
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
Gently pull the battery cable connector from its socket on the motherboard.
The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Remove the two #00 Phillips screws securing the battery to the rear case assembly.
Use a plastic opening tool to peel back the battery bracket.
Cautiously grasp the battery and lift it out of the device.
2 Комментарии к руководству
Where can I purchase a new Garmin StreetPilot c320 Battery Replacement battery?
john Lyons
11 Cavanaugh Cres
Terrace Bay Ontario
P0T2W0 Canada
Thanks' - I just found two of my old Garmin StreetPilot c320 units in storage.
This will be the project of the evening watching movies.
New 18650 Battery with charging protection is ready.
Thankfully these are ten times easier than the TomTom just completed with new battery install.
Cheers
