Garmin Vivoactive Battery Replacement
Выберете то, что вам нужно
    1. Garmin Vivoactive Battery Replacement, Wristband: шаг 1, изображение 1 из 1
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      Спросите у FixBot
      Добавить комментарий
    2. Garmin Vivoactive Battery Replacement: шаг 2, изображение 1 из 2 Garmin Vivoactive Battery Replacement: шаг 2, изображение 2 из 2
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      Спросите у FixBot
    1. Garmin Vivoactive Battery Replacement, Display Unit: шаг 3, изображение 1 из 1
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      Спросите у FixBot
    2. Garmin Vivoactive Battery Replacement: шаг 4, изображение 1 из 2 Garmin Vivoactive Battery Replacement: шаг 4, изображение 2 из 2
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      Спросите у FixBot
    3. Garmin Vivoactive Battery Replacement: шаг 5, изображение 1 из 1
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      Спросите у FixBot
    4. Garmin Vivoactive Battery Replacement: шаг 6, изображение 1 из 1
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      Спросите у FixBot
    5. Garmin Vivoactive Battery Replacement: шаг 7, изображение 1 из 1
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      Спросите у FixBot
    6. Garmin Vivoactive Battery Replacement: шаг 8, изображение 1 из 1
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      Спросите у FixBot
    1. Garmin Vivoactive Battery Replacement, Battery: шаг 9, изображение 1 из 2 Garmin Vivoactive Battery Replacement, Battery: шаг 9, изображение 2 из 2
      • Follow previous guides until you've exposed the battery as shown.
      • Begin by removing the battery connector tab.
      • Be sure not to use a metal implement or your fingers to remove this tab. Doing so may cause personal harm or damage to the electrical components.
      Спросите у FixBot
    2. Garmin Vivoactive Battery Replacement: шаг 10, изображение 1 из 2 Garmin Vivoactive Battery Replacement: шаг 10, изображение 2 из 2
      • Use a plastic opening pick to gently pry out the battery as shown.
      • The battery is Lithium Polymer, follow safe handling procedures and DO NOT deform it upon removal.
      Спросите у FixBot
    3. Garmin Vivoactive Battery Replacement: шаг 11, изображение 1 из 3 Garmin Vivoactive Battery Replacement: шаг 11, изображение 2 из 3 Garmin Vivoactive Battery Replacement: шаг 11, изображение 3 из 3
      • With the battery loose from the case, rotate it to expose the attached tab
      • Gently pry up the attached tab with a fingernail.
      • Keep the vibrator, circled in red, as you may need to solder it to the new battery upon re-installation later.
      Спросите у FixBot
Заключение
17 человек успешно провели ремонт по этому руководству.
Michael Clark
Участник с: 10/01/15
679 Репутация
1 руководство автора
Команда
Cal Poly, Team 1-21, Maness Fall 2015 Участник Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 членов
Автор 17 руководств
29 Комментарии к руководству
But battery buy where?
sanborn - Ответить Поделиться
where to buy battery?
Whitney Oliver - Ответить Поделиться
I have the Same question... where can i buy the replacement?
Roli - Ответить Поделиться
I've tried everywhere to find a battery for my vivoactive, with no luck. Where should I look to find a battery? HELP!
David - Ответить Поделиться
Battery is a 3.7 V, 150 mAh Li-Polymer type.
Gary K - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 47
За последние 30 дней: 280
За всё время: 115,949
