Gateway NE56R Series Disassembly
Выберете то, что вам нужно
    1. Gateway NE56R Series Disassembly, Remove hard drive cover: шаг 1, изображение 1 из 2 Gateway NE56R Series Disassembly, Remove hard drive cover: шаг 1, изображение 2 из 2
      • Remove the two Philips screws securing the hard drive cover to the base.
      • Pry the hard drive cover off with a spudger.
      Спросите у FixBot
      Добавить комментарий
    2. Gateway NE56R Series Disassembly, Remove hard drive caddy: шаг 2, изображение 1 из 1
      • With the laptop's battery side facing you, pull the hard drive caddy's tab to the right.
      Спросите у FixBot
    3. Gateway NE56R Series Disassembly, Remove hard drive: шаг 3, изображение 1 из 1
      • This step is unnecessary if you are only taking the hard drive out for testing purposes or are removing the motherboard.
      • Remove the four screws securing the hard drive to the caddy.
      Спросите у FixBot
      • Push the clips away from each other that are holding the RAM sticks. The RAM will then pop upwards. At this point, you can pull the stick out. Repeat for the second stick if applicable.
      Спросите у FixBot
    1. Gateway NE56R Series Disassembly, Remove keyboard: шаг 5, изображение 1 из 3 Gateway NE56R Series Disassembly, Remove keyboard: шаг 5, изображение 2 из 3 Gateway NE56R Series Disassembly, Remove keyboard: шаг 5, изображение 3 из 3
      • The keyboard has no screws to remove.
      • Use a fine spudger to push all six keyboard tabs. On the first, you'll have to use a bit of prying to get under the keyboard. After that, get your fingernail under the keyboard, and pull gently as you go along the keyboard using the spudger to pop the other clips.
      • There is one un-pushable clip on each side of the keyboard. Don't try to push them. Instead, once you get the top of the keyboard up, pull the keyboard out of the clips.
      • Gently push each side of the locking connector's lock towards the screen, and then pull the now-loose keyboard cable out. Set the keyboard aside.
      • Gently push each side of the power button locking connector towards the screen, and then pull the cable out.
      Спросите у FixBot
    2. Gateway NE56R Series Disassembly, Remove palmrest: шаг 6, изображение 1 из 2 Gateway NE56R Series Disassembly, Remove palmrest: шаг 6, изображение 2 из 2
      • Flip the laptop over again.
      • Remove the seventeen Philips M2.5x8 screws securing the palmrest.
      • Remove the two silver Philips M2.5x6 screws securing the palmrest.
      • Break out the Philips #0 bit, and remove the three silver Philips M2 screws securing the palmrest.
      • Use a spudger to separate the palmrest from the base.
      • Slide the optical drive out.
      • Remove the wireless antenna connectors, and then the wireless card.
      Спросите у FixBot
    3. Gateway NE56R Series Disassembly, Remove motherboard: шаг 7, изображение 1 из 1
      • Back with the Philips #1 bit, remove the two silver M2.5x6 Philips screws.
      • Remove all cables from the motherboard, including pulling out the wireless antenna from its hole.
      • Flip the motherboard up. The DC jack is still connected to the board, so don't tug the board away just yet.
      Спросите у FixBot
    4. Gateway NE56R Series Disassembly, Unplug the DC jack: шаг 8, изображение 1 из 1
      • Pull back on the DC jack plug to remove it. Now you may remove the motherboard and put the rest of the laptop aside.
      Спросите у FixBot
    5. Gateway NE56R Series Disassembly, Remove heatsink: шаг 9, изображение 1 из 1
      • Remove the four screws securing the heatsink to the motherboard.
      • Remove the black tape securing the heatsink to the fan, and now the heatsink will be free.
      Спросите у FixBot
    6. Gateway NE56R Series Disassembly, Remove fan: шаг 10, изображение 1 из 1
      • Remove the three screws securing the fan to the motherboard.
      • Remove the fan connector from the motherboard, and then remove the fan.
      Спросите у FixBot
    7. Gateway NE56R Series Disassembly, Remove CPU: шаг 11, изображение 1 из 1
      • Turn the CPU socket screw counterclockwise to release the CPU, and lift the CPU out of the socket.
      Спросите у FixBot
    8. Gateway NE56R Series Disassembly, Remove speakers: шаг 12, изображение 1 из 1
      • Remove each of the screws securing the left and right speakers, and remove the speakers.
      Спросите у FixBot
    9. Gateway NE56R Series Disassembly, Remove LCD assembly: шаг 13, изображение 1 из 1
      • Remove each of the screws securing the hinges to the base, and then lift the assembly upwards to remove it.
      Спросите у FixBot
    10. Gateway NE56R Series Disassembly, Remove DC jack & USB port board: шаг 14, изображение 1 из 1
      • At this point, you may simply pull upwards on the DC jack to remove it.
      • The USB port board is secured by a single M2x3 Philips screw. You may remove this screw and pull the board by its cable upwards.
      • The cable is attached to the base with adhesive.
      Спросите у FixBot
Заключение
9 человек успешно провели ремонт по этому руководству.
Joseph Sctbunio
Участник с: 09/23/17
7 884 Репутация
Автор 42 руководств
3 Комментарии к руководству
What about the GPU, is it built in, bc i have this and need to upgrade ir for windows 11.
Eclipsesion - Ответить Поделиться
In this model, the GPU is integrated inside the CPU (it's an
Intel integrated HD3000 iGPU).
These kinds of GPUs are not suitable for gaming and are designed for office/work purposes.
These are low-profile GPUs optimized for battery life.
This kind of integrated GPU might already works on Windows 11 if you try the latest official 64 bit driver.
It works on windows 10 but as stated on the Intel's website it's been a while support for this GPU is abandonned and the driver is officialy built for Windows 8.1 :
https://www.intel.fr/content/www/fr/fr/s...
Brendan - Ответить Поделиться
How do I go about removing the CMOS battery on a Gateway NE56R41u laptop manufactured in 2013. I need to clear out the BIOS password as I am not the original owner. It currently has Windows 8.1 installed on it. I would like to be able to install various Linux Distros on it suitable for older hardware. This will require me being able to access the BIOS in order to change the boot order. I have read that removing the CMOS battery for an extended period of time should remove the password. I have watched several videos, but am still unclear where the CMOS battery is located in the disassembly process. Thank You in advance, any assistance you are able to provide would be greatly appreciated.
George - Oct 22, 2025
George Hudson - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 69
За всё время: 8,012
