Google Pixel 4 Display Assembly Replacement
Выберете то, что вам нужно
  1. Google Pixel 4 Display Assembly Replacement, Remove the SIM card tray: шаг 1, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement, Remove the SIM card tray: шаг 1, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement, Remove the SIM card tray: шаг 1, изображение 3 из 3
    • Insert a SIM eject tool, bit, or a straightened paper clip into the small hole on the SIM card tray on the left edge of the phone.
    • Press firmly to eject the tray.
    • Remove the SIM card tray.
  2. Google Pixel 4 Display Assembly Replacement, Heat the back panel glass: шаг 2, изображение 1 из 1
    • Prepare an iOpener and apply it to the bottom edge of the back panel for one minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4 Display Assembly Replacement, Apply a suction cup: шаг 3, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement, Apply a suction cup: шаг 3, изображение 2 из 2
    • Apply a suction cup to the heated edge of the back panel by pressing down on it to create suction, as close to the edge as possible.
    • If your back glass is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken panel.
  4. Google Pixel 4 Display Assembly Replacement, Insert an opening pick: шаг 4, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement, Insert an opening pick: шаг 4, изображение 2 из 2
    • Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply more heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
  5. Google Pixel 4 Display Assembly Replacement, Begin to slice the adhesive: шаг 5, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement, Begin to slice the adhesive: шаг 5, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement, Begin to slice the adhesive: шаг 5, изображение 3 из 3
    • Slide the opening pick across the bottom towards the left corner to slice the adhesive.
    • With the pick still inserted, slide it from the bottom left corner over to the bottom right corner to completely slice the bottom side adhesive.
    • Leave the pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4 Display Assembly Replacement, Slice the lefthand-side adhesive: шаг 6, изображение 1 из 1
    • Prepare an iOpener and apply it on the left edge of the phone for one minute.
  7. Google Pixel 4 Display Assembly Replacement: шаг 7, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 7, изображение 2 из 2
    • Insert a second opening pick underneath the back panel directly over the charge port.
    • Slide the opening pick to the bottom left corner of the phone.
  8. Google Pixel 4 Display Assembly Replacement: шаг 8, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 8, изображение 2 из 2
    • Slide the opening pick around the bottom left corner and across the left side of the phone to slice the adhesive.
    • The adhesive can be very gummy. Push the pick in and out in a sawing motion to help with slicing.
    • Stop when you reach the top left corner, near the camera, and leave the pick inserted.
  9. Google Pixel 4 Display Assembly Replacement, Slice righthand-side adhesive: шаг 9, изображение 1 из 1
    • Prepare an iOpener and apply it on the right edge of the phone for one minute.
  10. Google Pixel 4 Display Assembly Replacement: шаг 10, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement: шаг 10, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement: шаг 10, изображение 3 из 3
    • With the first two opening picks still in place, insert a third pick on the lower part of the righthand side.
    • Slide the opening pick up towards the top of the phone, slicing the right side's adhesive.
    • Stop when you reach the top right corner, and leave the pick inserted.
  11. Google Pixel 4 Display Assembly Replacement, Slice the top-side adhesive: шаг 11, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement, Slice the top-side adhesive: шаг 11, изображение 2 из 2
    • Slide the third opening pick around the top right corner and across the top side of the phone, slicing the final strip of adhesive.
  12. Google Pixel 4 Display Assembly Replacement, Lift up the back panel: шаг 12, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement, Lift up the back panel: шаг 12, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement, Lift up the back panel: шаг 12, изображение 3 из 3
    • Once you have sliced around the perimeter of the phone, carefully lift the right edge of the back cover, opening it like a book.
    • Do not try to pull the panel all the way off yet, as it is still connected to the phone.
  13. Google Pixel 4 Display Assembly Replacement: шаг 13, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 13, изображение 2 из 2
    • Continue swinging open the back panel until you can rest it on the left edge the phone, being careful not to put any stress on the attached ribbon cable.
    • During reassembly, this is a good point to power on your phone and test all functions before re-sealing the back panel. Be sure to power your phone back down completely before you continue working.
  14. Google Pixel 4 Display Assembly Replacement, Disconnect the battery: шаг 14, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    Купить
    • Remove the five T3 Torx screws securing the battery connector shield:
    • Four 4.0 mm screws
    • One 2.1 mm screw
  15. Google Pixel 4 Display Assembly Replacement: шаг 15, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 15, изображение 2 из 2
    • Use a pair of tweezers to remove the battery connector shield.
  16. Google Pixel 4 Display Assembly Replacement: шаг 16, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 16, изображение 2 из 2
    • Whenever you use the spudger near the battery, be very careful not to puncture the battery.
    • Using the pointed end of a spudger, pry the battery connector straight up from the motherboard to disconnect the battery.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  17. Google Pixel 4 Display Assembly Replacement: шаг 17, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 17, изображение 2 из 2
    • Using the flat end of a spudger, gently fold the battery cable over so it doesn't accidentally make contact during the rest of your repairs.
  18. Google Pixel 4 Display Assembly Replacement, Disconnect the back panel connector: шаг 18, изображение 1 из 1
    • Use a T3 Torx driver to remove the two 4 mm screws securing the back panel connector cover.
  19. Google Pixel 4 Display Assembly Replacement: шаг 19, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 19, изображение 2 из 2
    • Use a pair of tweezers to remove the back panel connector cover.
  20. Google Pixel 4 Display Assembly Replacement: шаг 20, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 20, изображение 2 из 2
    • Using the pointed end of a spudger, pry up and disconnect the back panel connector.
  21. Google Pixel 4 Display Assembly Replacement, Remove the back panel: шаг 21, изображение 1 из 1
    • Remove the back panel.
    • During reassembly, follow this guide to install custom-cut adhesives for your device.
    • Follow this guide if you are using a pre-cut adhesive card.
  22. Google Pixel 4 Display Assembly Replacement, Front Camera and Sensor Assembly: шаг 22, изображение 1 из 1
    • Use a T3 Torx driver to remove the four 4 mm screws securing the camera connector cover.
  23. Google Pixel 4 Display Assembly Replacement: шаг 23, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement: шаг 23, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement: шаг 23, изображение 3 из 3
    • Using a pair of tweezers, tilt the camera cover up and slide it out of the retaining slot on the upper right corner of the phone to remove.
  24. Google Pixel 4 Display Assembly Replacement, Disconnect the camera and sensor connectors: шаг 24, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement, Disconnect the camera and sensor connectors: шаг 24, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement, Disconnect the camera and sensor connectors: шаг 24, изображение 3 из 3
    • Using the pointed end of a spudger, pry the camera and sensor connectors straight up from the motherboard.
  25. Google Pixel 4 Display Assembly Replacement: шаг 25, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 25, изображение 2 из 2
    • Disconnect the laser module connector.
  26. Google Pixel 4 Display Assembly Replacement, Remove the front camera and sensor assembly: шаг 26, изображение 1 из 1
    • Use a T3 Torx driver to remove the two 2.4 mm screws securing the front camera and sensor assembly.
  27. Google Pixel 4 Display Assembly Replacement: шаг 27, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement: шаг 27, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement: шаг 27, изображение 3 из 3
    • Use a pair of tweezers to remove the front camera and sensor assembly.
  28. Google Pixel 4 Display Assembly Replacement, Display Assembly: шаг 28, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement, Display Assembly: шаг 28, изображение 2 из 2
    • Use a spudger to disconnect the display connector from the motherboard.
  29. Google Pixel 4 Display Assembly Replacement, Slice the display adhesive: шаг 29, изображение 1 из 1
  30. Google Pixel 4 Display Assembly Replacement: шаг 30, изображение 1 из 3 Google Pixel 4 Display Assembly Replacement: шаг 30, изображение 2 из 3 Google Pixel 4 Display Assembly Replacement: шаг 30, изображение 3 из 3
    • This process will almost always destroy the OLED display panel. Only proceed if you are replacing an already-broken display assembly.
    • Apply a suction cup to the heated edge of the display assembly
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken display assembly.
    • Pull up on the suction cup with strong, steady force to create a gap between the display assembly and the frame.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Depending on the age of your phone, this may take significant force. If you are having trouble, apply more heat and try again.
  31. Google Pixel 4 Display Assembly Replacement: шаг 31, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 31, изображение 2 из 2
    • Slide the opening pick down the right bezel of the phone, between the display and the frame, to slice the adhesive.
    • Leave the pick inserted in the bottom right corner.
  32. Google Pixel 4 Display Assembly Replacement: шаг 32, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 32, изображение 2 из 2
    • Insert a second opening pick underneath the display assembly in the top left corner of the phone, near the front-facing camera cutout.
    • If this is difficult, you may need to reapply an iOpener to the upper edge of the display assembly.
    • Slide the opening pick around the corner and down the left side of the phone, stopping about halfway down, and leave the pick inserted.
  33. Google Pixel 4 Display Assembly Replacement: шаг 33, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement: шаг 33, изображение 2 из 2
    • Insert a third opening pick under the display assembly in the middle of the right edge of the phone and twist to separate the assembly.
  34. Google Pixel 4 Display Assembly Replacement, Tilt the display up: шаг 34, изображение 1 из 2 Google Pixel 4 Display Assembly Replacement, Tilt the display up: шаг 34, изображение 2 из 2
    • Tilt the display assembly up along the left edge of the phone.
    • Slide the display connector out of the hole near the motherboard to separate the display assembly from the rest of the phone.
    • The connector will slide out without any force.
  35. Google Pixel 4 Display Assembly Replacement, Remove the display assembly: шаг 35, изображение 1 из 1
    • Remove the display assembly.
    • You will have to thread the replacement assembly's display cable through the motherboard cutout.
    • If you're having trouble, you can unclip the white antenna cable running through the same cutout or you can loosen and partially remove the motherboard.
    • If you're using a custom-cut adhesive, follow this guide for instructions on how to apply adhesive to the replacement display assembly.
    • Be sure to test your repairs before you affix the display assembly with adhesives.
    • If you are using Tesa tape to reattach the display assembly, follow this guide.
    • During the boot-up process after reassembly, the display assembly will go through a calibration sequence. Do not touch the assembly during this process, as it could result in improper touch calibration and create touch issues.
Заключение
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
28 участников успешно повторили данное руководство.
Carsten Frauenheim
Участник с: 03/10/20
113 880 Репутация
Автор 338 руководств
Команда
iFixit Участник iFixit
Staff
135 членов
Автор 17 157 руководств
3 Комментариев
The guide was perfect. The hardest step was removing the front screen but with repeated use of the iOpener the screen finally came free.
David Springston - Ответить
I didnt check that the earpiece speaker grill was transferred from the original screen to the replacement which I had bought. “Cheaper” screens I’ve bought for various phones dont have the little extras. Mistake on my part but I was able to remove the new screen without damage! A little note in the steps to prep the screen could be handy.
I use a Razor blade technique for back plate removal. With minimal heating its possible to insert a safety razor blade into the adhesive gap by only a couple of millimetres and cut the glue . This leaves the original seal in place which then needs cleaning off to do a proper job. I glued the seal (without removing) to replace the back cover with good results. Nothing else has a finer leading edge and the strength gives good purchase. Safety being obvious - needs to be done with a decent pair of cut resistant gloves.
Fantastic guide and comprehensive. Mark up of the different screw lengths is a life saver. Cudos to google for minimising the variety of screws used!.
Matt K - Ответить
I replaced the screen while keeping the frame, but unfortunately had already gone too far in the "replace screen including frame" tutorial, so I did a bit more work than I'd have to. Reassembled, and now the phone is unresponsive, just black screen, no reaction at all, with or without a power cable attached. If it's one of the connections, is there a good way to narrow down the problem? From which point should I be able to turn the phone on or get some reaction without completely assembling it?
Cirkmann Zirkel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 64
За последние 30 дней: 234
За всё время: 33,774
