Google Pixel 4a 5G Back Cover Replacement
Выберете то, что вам нужно
  1. Google Pixel 4a 5G Back Cover Replacement, Eject the SIM card tray: шаг 1, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Eject the SIM card tray: шаг 1, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Eject the SIM card tray: шаг 1, изображение 3 из 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM tray hole.
    • Press directly into the hole to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Google Pixel 4a 5G Back Cover Replacement, Precautionary Notes: шаг 2, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Precautionary Notes: шаг 2, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Precautionary Notes: шаг 2, изображение 3 из 3
    • You will need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of your phone:
    • Screen seam: This seam separates the screen from the rest of the phone. This is where you have to pry.
    • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
    • Before you begin, note the following areas on the screen:
    • Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
    • Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
  3. Google Pixel 4a 5G Back Cover Replacement, Heat the right edge of the screen: шаг 3, изображение 1 из 1
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  4. Google Pixel 4a 5G Back Cover Replacement, Insert an opening pick: шаг 4, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Insert an opening pick: шаг 4, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Insert an opening pick: шаг 4, изображение 3 из 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force.
    • Insert the tip of an opening pick into the screen seam no more than 1 mm.
  5. Google Pixel 4a 5G Back Cover Replacement, Guide the opening pick under the OLED panel: шаг 5, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Guide the opening pick under the OLED panel: шаг 5, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Guide the opening pick under the OLED panel: шаг 5, изображение 3 из 3
    • This step shows how to insert your pick without damaging the OLED panel. Do this before slicing the adhesive.
    • With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
    • At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
    • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
  6. Google Pixel 4a 5G Back Cover Replacement, Slice through the display adhesive: шаг 6, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Slice through the display adhesive: шаг 6, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Slice through the display adhesive: шаг 6, изображение 3 из 3
    • Slide the pick along the right edge of the screen to cut the adhesive.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable.
    • Leave the pick in the bottom-right corner to prevent the adhesive from re-sealing.
  7. Google Pixel 4a 5G Back Cover Replacement: шаг 7, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 7, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 7, изображение 3 из 3
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • The screen adhesive is weak, so you should not need to re-apply heat. If the screen is hard to slice, apply heat to the difficult area for one minute and try again.
    • Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the opening pick around the top of the phone to cut the adhesive.
    • Leave the pick inserted along the top edge to prevent the adhesive from resealing.
  8. Google Pixel 4a 5G Back Cover Replacement: шаг 8, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 8, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 8, изображение 3 из 3
    • Insert another opening pick into the top edge of your phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Use the pick to slice around the top-left corner where the camera window is.
    • If the screen is hard to slice, apply heat to the difficult area for one minute and try again.
    • Leave the pick inserted along the left edge of your phone to prevent the adhesive from re-sealing.
  9. Google Pixel 4a 5G Back Cover Replacement: шаг 9, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 9, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 9, изображение 3 из 3
    • Slide the opening pick to cut the adhesive along the left edge of your phone.
    • Keep in mind that you are now slicing near the screen flex cable and digitizer.
  10. Google Pixel 4a 5G Back Cover Replacement: шаг 10, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 10, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 10, изображение 3 из 3
    • Slide the opening pick around the bottom-left corner and across the bottom of the display to cut the rest of the adhesive.
  11. Google Pixel 4a 5G Back Cover Replacement: шаг 11, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement: шаг 11, изображение 2 из 2
    • Once you have cut around the perimeter of the phone, carefully lift the right edge of the screen, partially opening the phone like a book.
    • Do not remove the screen yet.
    • Use an opening pick to carefully cut through any remaining adhesive.
  12. Google Pixel 4a 5G Back Cover Replacement, Flip the screen over: шаг 12, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Flip the screen over: шаг 12, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Flip the screen over: шаг 12, изображение 3 из 3
    • Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
    • Be careful not to put any stress on the attached ribbon cable.
  13. Google Pixel 4a 5G Back Cover Replacement, Disconnect the display: шаг 13, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Disconnect the display: шаг 13, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Disconnect the display: шаг 13, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Купить
    • Use your fingernail or a pair of tweezers to carefully peel off the tape covering the screen connector.
    • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of Kapton tape.
  14. Google Pixel 4a 5G Back Cover Replacement: шаг 14, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 14, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 14, изображение 3 из 3
    • Insert the tip of a spudger into the opening of the plastic cover securing the screen flex cable.
    • Pry the plastic cover straight up until it pops out of place.
    • The plastic cover may spring into the air.
    • Remove the plastic cover.
  15. Google Pixel 4a 5G Back Cover Replacement: шаг 15, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement: шаг 15, изображение 2 из 2
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  16. Google Pixel 4a 5G Back Cover Replacement, Remove the screen: шаг 16, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Remove the screen: шаг 16, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Remove the screen: шаг 16, изображение 3 из 3
    • Remove the screen.
    • To install a new screen:
    • Check if your replacement screen has speaker mesh and top edge adhesive pre-installed.
    • If it does, you won't need the top edge adhesive.
    • If it doesn't, remove the larger clear liner from the top edge adhesive and apply it to the screen (not the frame). Make sure the larger cutout lines up with the speaker mesh.
    • Follow this guide to apply the custom-cut adhesive.
    • Use the third photo as a reference to position your adhesives.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Don't touch the screen during this process, as it could result in improper touch calibration and create touch issues.
  17. Google Pixel 4a 5G Back Cover Replacement, Remove the midframe screws: шаг 17, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement, Remove the midframe screws: шаг 17, изображение 2 из 2
    Magnetic Project Mat
    $19.95
    Купить
    • Use a T3 Torx driver to remove the nine 4.4 mm-long screws securing the back cover to the midframe.
  18. Google Pixel 4a 5G Back Cover Replacement, Separate the back cover from the midframe: шаг 18, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement, Separate the back cover from the midframe: шаг 18, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement, Separate the back cover from the midframe: шаг 18, изображение 3 из 3
    • Insert an opening pick into the seam between the midframe and the back cover, right above the SIM card slot.
    • Slide the opening pick along the right edge of your phone to release the plastic clips securing the back cover to the midframe.
  19. Google Pixel 4a 5G Back Cover Replacement: шаг 19, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 19, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 19, изображение 3 из 3
    • Continue sliding the opening pick along the top, left, and bottom edges of your phone until all of the plastic tabs securing the back cover to the midframe are released.
  20. Google Pixel 4a 5G Back Cover Replacement: шаг 20, изображение 1 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 20, изображение 2 из 3 Google Pixel 4a 5G Back Cover Replacement: шаг 20, изображение 3 из 3
    • Flip your phone over so the back cover is facing up.
    • Carefully swing the back cover up to an upright position.
    • Do not remove the back cover. It is still attached by two ribbon cables.
    • Rest the back cover against an object such as a cardboard box or soda can.
  21. Google Pixel 4a 5G Back Cover Replacement, Remove the motherboard bracket: шаг 21, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement, Remove the motherboard bracket: шаг 21, изображение 2 из 2
    • Use a T3 Torx screwdriver to remove the seven screws securing the motherboard bracket:
    • Four 4.0 mm-long screws
    • Three 2.1 mm-long screws
  22. Google Pixel 4a 5G Back Cover Replacement: шаг 22, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement: шаг 22, изображение 2 из 2
    • Remove the motherboard bracket.
  23. Google Pixel 4a 5G Back Cover Replacement, Disconnect the battery: шаг 23, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement, Disconnect the battery: шаг 23, изображение 2 из 2
    • Use the tip of a spudger to disconnect the battery cable from the motherboard.
  24. Google Pixel 4a 5G Back Cover Replacement, Remove the back cover: шаг 24, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement, Remove the back cover: шаг 24, изображение 2 из 2
    • Use the tip of a spudger to pry up and disconnect the fingerprint sensor cable.
  25. Google Pixel 4a 5G Back Cover Replacement: шаг 25, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement: шаг 25, изображение 2 из 2
    • Use the tip of a spudger to pry up and disconnect the front sensor array cable.
  26. Google Pixel 4a 5G Back Cover Replacement: шаг 26, изображение 1 из 2 Google Pixel 4a 5G Back Cover Replacement: шаг 26, изображение 2 из 2
    • Remove the back cover.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components from the new part before installing.
4 участников успешно повторили данное руководство.
Sam Omiotek
Участник с: 02/25/19
73 693 Репутация
Автор 288 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 39
За последние 30 дней: 144
За всё время: 7,445
