Google Pixel 4a Screen Replacement
Выберете то, что вам нужно
  1. Google Pixel 4a Screen Replacement, Precautionary notes: шаг 1, изображение 1 из 3 Google Pixel 4a Screen Replacement, Precautionary notes: шаг 1, изображение 2 из 3 Google Pixel 4a Screen Replacement, Precautionary notes: шаг 1, изображение 3 из 3
    • You will need to pry the screen up to remove it from the phone. Read the following notes carefully before proceeding.
    • Take note of the two seams on the edge of the phone:
    • Screen seam: This seam separates the screen from the rest of the phone. This is where you should pry.
    • Frame seam: This is where the plastic frame meets the back cover. It is held in place by screws. Do not pry at this seam.
    • Before you begin, note the following areas on the screen:
    • Screen flex cable: Do not insert the opening pick deeper than instructed or you risk damaging this cable.
    • Note the orange ribbon cable under the lower-right corner of the screen, which is susceptible to damage if your opening pick is pressed into it. Only insert your opening pick as little as is necessary to separate the screen adhesive.
    • Adhesive perimeter: Prying beyond this narrow perimeter without angling the pick will damage the OLED panel.
  2. Google Pixel 4a Screen Replacement, Heat the right edge of the screen: шаг 2, изображение 1 из 1
    • Apply a heated iOpener to the right edge of the display for one minute to soften the adhesive.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  3. Google Pixel 4a Screen Replacement, Insert an opening pick: шаг 3, изображение 1 из 3 Google Pixel 4a Screen Replacement, Insert an opening pick: шаг 3, изображение 2 из 3 Google Pixel 4a Screen Replacement, Insert an opening pick: шаг 3, изображение 3 из 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Place a suction cup as close to the right edge of the screen as possible.
    • Lift the suction cup with a strong steady force.
    • Insert the tip of an opening pick into the screen seam no more than 1 mm.
  4. Google Pixel 4a Screen Replacement, Guide the opening pick under the OLED panel: шаг 4, изображение 1 из 3 Google Pixel 4a Screen Replacement, Guide the opening pick under the OLED panel: шаг 4, изображение 2 из 3 Google Pixel 4a Screen Replacement, Guide the opening pick under the OLED panel: шаг 4, изображение 3 из 3
    • This step shows how to insert the pick without damaging the OLED panel. Do this before beginning to slice the adhesive.
    • With the pick 1 mm into the gap, pivot the pick upwards to a steep angle.
    • At a steep angle, carefully push the pick into the gap about 1/4 inch (6 mm). The pick should slide in below the OLED panel.
    • Stop if you feel the point of the pick hitting a ridge. The pick may be pressing against the edge of the OLED panel. Angle the pick and try again.
  5. Google Pixel 4a Screen Replacement, Cut the adhesive: шаг 5, изображение 1 из 3 Google Pixel 4a Screen Replacement, Cut the adhesive: шаг 5, изображение 2 из 3 Google Pixel 4a Screen Replacement, Cut the adhesive: шаг 5, изображение 3 из 3
    • Slide the pick along the right edge of the screen to cut the adhesive.
    • Do not insert the pick more than 1/4 inch (6 mm) or you may damage the screen's flex cable.
    • Leave the pick in the top right corner to prevent the adhesive from re-sealing.
  6. Google Pixel 4a Screen Replacement: шаг 6, изображение 1 из 3 Google Pixel 4a Screen Replacement: шаг 6, изображение 2 из 3 Google Pixel 4a Screen Replacement: шаг 6, изображение 3 из 3
    • The screen adhesive is very weak and you should not need to re-apply heat. If the screen does feel hard to slice, apply heat to the difficult area for one minute and try again.
    • Insert another opening pick into the right edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the opening pick around the bottom of the phone to cut the adhesive.
    • There is a delicate cable under the bottom-right corner of the screen. If you feel your opening pick snag on anything, pull it out and try again. Make sure your pick is angled downward and only inserted as little as is necessary to separate the adhesive (no more than 2 mm deep).
    • Leave the pick inserted along the bottom edge to prevent the adhesive from resealing.
  7. Google Pixel 4a Screen Replacement: шаг 7, изображение 1 из 3 Google Pixel 4a Screen Replacement: шаг 7, изображение 2 из 3 Google Pixel 4a Screen Replacement: шаг 7, изображение 3 из 3
    • Insert another opening pick into the bottom edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Use the pick to slice through the left edge of the phone.
    • If the screen feels hard to slice, heat the left edge for one minute and try again.
    • Leave the pick inserted along the left edge of the phone to prevent the adhesive from re-sealing.
  8. Google Pixel 4a Screen Replacement: шаг 8, изображение 1 из 3 Google Pixel 4a Screen Replacement: шаг 8, изображение 2 из 3 Google Pixel 4a Screen Replacement: шаг 8, изображение 3 из 3
    • There's a mesh covering the earpiece speaker on the top edge of the screen. If you don’t have a replacement mesh, take care not to damage or lose this component.
    • Insert another opening pick into the left edge of the phone at an angle where a gap has already formed to prevent damage to the OLED panel.
    • Slide the pick around the top edge of the phone to cut the adhesive.
    • If the screen feels hard to slice, heat the top edge for one minute and try again.
  9. Google Pixel 4a Screen Replacement: шаг 9, изображение 1 из 2 Google Pixel 4a Screen Replacement: шаг 9, изображение 2 из 2
    • Once you have cut around the perimeter of the phone, carefully lift the right edge of the screen, opening the phone like a book.
    • Do not remove the screen yet.
    • Use an opening pick to carefully cut through any remaining adhesive.
  10. Google Pixel 4a Screen Replacement, Flip the screen over: шаг 10, изображение 1 из 3 Google Pixel 4a Screen Replacement, Flip the screen over: шаг 10, изображение 2 из 3 Google Pixel 4a Screen Replacement, Flip the screen over: шаг 10, изображение 3 из 3
    • Lift from the top edge and swing the screen over the bottom edge until you can rest it glass-side down.
    • Be careful not to put any stress on the attached ribbon cable.
  11. Google Pixel 4a Screen Replacement, Disconnect the display: шаг 11, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Use a pair of tweezers to carefully peel up the black tape covering the screen connector bracket.
    • If it is in good condition, you can re-use this tape during reassembly. Otherwise, replace it with a piece of electrical tape.
  12. Google Pixel 4a Screen Replacement: шаг 12, изображение 1 из 1
    Magnetic Project Mat
    $19.95
    • Use a T3 Torx driver to remove the two 2.1 mm screws securing the screen connector bracket.
  13. Google Pixel 4a Screen Replacement: шаг 13, изображение 1 из 1
    • Use a pair of tweezers to remove the screen connector bracket.
    • Make sure to keep this component to reinstall it during reassembly.
  14. Google Pixel 4a Screen Replacement: шаг 14, изображение 1 из 2 Google Pixel 4a Screen Replacement: шаг 14, изображение 2 из 2
    • Use the tip of a spudger to pry up and disconnect the screen flex cable.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. Google Pixel 4a Screen Replacement, Remove the screen: шаг 15, изображение 1 из 3 Google Pixel 4a Screen Replacement, Remove the screen: шаг 15, изображение 2 из 3 Google Pixel 4a Screen Replacement, Remove the screen: шаг 15, изображение 3 из 3
    • Remove the screen.
    • To install a new screen:
    • Check if your replacement screen has speaker mesh and top edge adhesive pre-installed.
    • If it does, you won't need the top edge adhesive.
    • If it doesn't, remove the larger clear liner from the top edge adhesive and apply it to the screen (not the frame). Make sure the larger cutout lines up with the speaker mesh.
    • Follow this guide to apply the custom-cut adhesive.
    • Use the third photo as a reference to position your adhesives.
    • During the boot-up process after reassembly, the screen will go through a calibration sequence. Don't touch the screen during this process, as it could result in improper touch calibration and create touch issues.
Заключение
94 человек успешно провели ремонт по этому руководству.
Sam Omiotek
Участник с: 02/25/19
93 358 Репутация
Автор 290 руководств
39 Комментарии к руководству
Really nice repair guide. But no place to buy the screen.
jeffreyjantos - Ответить
Yep, still waiting for it to be available.
Paul -
Same, still waiting. I have a broken pixel 4a and I have a right to repair it.
Erik Fry -
Where do you recommend that I purchase the Pixel4a screen replacement from? I found these two with Witrigs being cheaper, but not sure if either are reliable high quality screens.
https://www.witrigs.com/oem-screen-repla...
https://phoneremedies.com/collections/go...
Alejandro Gaytan - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 93
За последние 7 дней: 560
За последние 30 дней: 2,051
За всё время: 211,305
