Google Pixel Fold Flip Battery Replacement
Выберете то, что вам нужно
  1. Google Pixel Fold Flip Battery Replacement, Safety Precautions: шаг 1, изображение 1 из 1
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel Fold Flip Battery Replacement, Remove the SIM card tray: шаг 2, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Remove the SIM card tray: шаг 2, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Remove the SIM card tray: шаг 2, изображение 3 из 3
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole.
    • Press firmly to eject the SIM card tray.
  3. Google Pixel Fold Flip Battery Replacement, Heat the bottom edge: шаг 3, изображение 1 из 1
    • Heat an iOpener and apply it to the bottom edge of the screen for two minutes.
  4. Google Pixel Fold Flip Battery Replacement, Adhesive information: шаг 4, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Adhesive information: шаг 4, изображение 2 из 2
    • While you're waiting for the adhesive to soften, note the following:
    • The adhesive is under the dark black border surrounding the screen.
    • During the screen removal procedure, you only need to insert your opening pick as deep as the border.
    • Don't insert your pick any deeper, as you risk damaging the screen and internal components.
  5. Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 5, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 5, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 5, изображение 3 из 3
    • Apply a suction cup to the screen, as close to the center of the bottom edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the screen and the frame.
    • Insert an opening pick into the gap.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the edge and try again.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the screen.
  6. Google Pixel Fold Flip Battery Replacement, Separate the bottom adhesive: шаг 6, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Separate the bottom adhesive: шаг 6, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Separate the bottom adhesive: шаг 6, изображение 3 из 3
    • Slide the opening pick along the bottom edge to separate the adhesive.
    • Leave the opening pick in the bottom right corner before continuing.
  7. Google Pixel Fold Flip Battery Replacement, Heat the right edge: шаг 7, изображение 1 из 1
    • Apply a heated iOpener to the right edge of the screen for two minutes.
  8. Google Pixel Fold Flip Battery Replacement, Separate the bottom right adhesive: шаг 8, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Separate the bottom right adhesive: шаг 8, изображение 2 из 2
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  9. Google Pixel Fold Flip Battery Replacement, Separate the right adhesive: шаг 9, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Separate the right adhesive: шаг 9, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Separate the right adhesive: шаг 9, изображение 3 из 3
    • Insert a new opening pick in the bottom right corner.
    • Slide the opening pick toward the top right corner to separate the adhesive.
    • Leave the opening pick in the top right corner before continuing.
  10. Google Pixel Fold Flip Battery Replacement, Heat the top edge: шаг 10, изображение 1 из 1
    • Apply a heated iOpener to the top edge of the screen for two minutes.
  11. Google Pixel Fold Flip Battery Replacement, Separate the top right adhesive: шаг 11, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Separate the top right adhesive: шаг 11, изображение 2 из 2
    • Rotate the opening pick around the top right corner to separate its adhesive.
  12. Google Pixel Fold Flip Battery Replacement, Separate the top adhesive: шаг 12, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Separate the top adhesive: шаг 12, изображение 2 из 2
    • Insert a new opening pick in the top right corner.
    • Slide the opening pick toward the top left corner to separate its adhesive.
  13. Google Pixel Fold Flip Battery Replacement, Heat the left edge: шаг 13, изображение 1 из 1
    • Apply a heated iOpener to the left edge of the screen for two minutes.
  14. Google Pixel Fold Flip Battery Replacement, Separate the top left adhesive: шаг 14, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Separate the top left adhesive: шаг 14, изображение 2 из 2
    • The sharp corner is very fragile. Use plenty of heat and be very gentle around the corner during this step.
    • Angle your pick so it's as flat as possible to the screen.
    • Rotate the opening pick around the top left corner to separate the adhesive.
  15. Google Pixel Fold Flip Battery Replacement, Separate the left adhesive: шаг 15, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Separate the left adhesive: шаг 15, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Separate the left adhesive: шаг 15, изображение 3 из 3
    • Insert a new opening pick in the top left corner.
    • Slide the opening pick toward the bottom left corner to separate the adhesive.
  16. Google Pixel Fold Flip Battery Replacement, Separate the bottom left adhesive: шаг 16, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Separate the bottom left adhesive: шаг 16, изображение 2 из 2
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  17. Google Pixel Fold Flip Battery Replacement, Adhesive information: шаг 17, изображение 1 из 1
    • There's a small adhesive strip that secures the screen near the top right corner of the phone.
    • The next three steps will show you how to separate this adhesive.
  18. Google Pixel Fold Flip Battery Replacement, Heat the top right corner: шаг 18, изображение 1 из 1
    • Heat an iOpener and apply it to the top right corner of the screen for two minutes.
  19. Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 19, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 19, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 19, изображение 3 из 3
    • Insert an opening pick under the right edge of the screen, near the top right corner.
    • Push the opening pick under the screen as far you can go without losing your grip.
  20. Google Pixel Fold Flip Battery Replacement, Separate the adhesive: шаг 20, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Separate the adhesive: шаг 20, изображение 2 из 2
    • Be very careful during this step, as you risk breaking the screen. Work slowly and apply more heat if necessary.
    • Twist the opening pick back and forth to separate the adhesive.
    • If you don't feel the adhesive separating, apply more heat or insert the pick at a different angle.
  21. Google Pixel Fold Flip Battery Replacement, Reposition the screen: шаг 21, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Reposition the screen: шаг 21, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Reposition the screen: шаг 21, изображение 3 из 3
    • At this point, the screen should be separated from the frame. If there's still resistance around the edges, use an opening pick to separate any remaining adhesive.
    • Don't remove the screen yet, as it's still connected to the phone by a cable.
    • Swing the left edge of the screen up and over the right edge of the phone.
    • Let the screen rest next to the phone before continuing.
  22. Google Pixel Fold Flip Battery Replacement, Unfasten the bottom bracket: шаг 22, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    FixMat
    $36.95
    Купить
    • While the Pixel Fold uses Torx Plus screws, standard Torx bits also work. Use the same size or one size larger (T3 Torx or T4 bits with 3IP Torx Plus screws) and apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the five 2.5 mm‑long screws securing the bottom bracket.
  23. Google Pixel Fold Flip Battery Replacement, Remove the bottom bracket: шаг 23, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Remove the bottom bracket: шаг 23, изображение 2 из 2
    Купить
    • Use tweezers, or your fingers, to remove the bottom bracket.
    • During reassembly, make sure the bottom bracket is sitting in its two alignment pegs before refastening it.
  24. Google Pixel Fold Flip Battery Replacement, Disconnect the flip battery: шаг 24, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Disconnect the flip battery: шаг 24, изображение 2 из 2
    • Don't pry against the battery during this step. Angle your spudger under the left or right edges of the press connector.
    • Use the flat end of a spudger to pry up and disconnect the flip battery press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  25. Google Pixel Fold Flip Battery Replacement, Disconnect the screen: шаг 25, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Disconnect the screen: шаг 25, изображение 2 из 2
    • Insert the point of a spudger under the short edge of the screen press connector facing the bottom of the phone.
    • Don't insert your spudger anywhere else, as you risk damaging surface-mounted components on the logic board.
    • Pry up to disconnect the screen press connector.
  26. Google Pixel Fold Flip Battery Replacement, Remove the screen: шаг 26, изображение 1 из 1
    • Remove the screen.
  27. Google Pixel Fold Flip Battery Replacement, Reassembly information: шаг 27, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: шаг 27, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: шаг 27, изображение 3 из 3
    Tesa 61395 Tape
    $5.99
    Купить
    • During reassembly, perform the following:
    • If you're reusing your screen, use tweezers to remove big chunks of adhesive from the perimeter of the screen.
    • Repeat for any adhesive on the frame, including the small adhesive at the top right of the phone.
    • If your top right adhesive is still intact and sticky, you can reuse it.
    • Use isopropyl alcohol (>90%) and a lint-free cloth to remove any remaining adhesive residue.
    • Follow this guide to replace your screen adhesive.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the screen to the frame.
  28. Google Pixel Fold Flip Battery Replacement, Disconnect the bottom interconnect cable: шаг 28, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Disconnect the bottom interconnect cable: шаг 28, изображение 2 из 2
    • Use a spudger to pry up and disconnect the bottom interconnect cable press connector.
  29. Google Pixel Fold Flip Battery Replacement, Unfasten the lower board: шаг 29, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Unfasten the lower board: шаг 29, изображение 2 из 2
    Купить
    • Use a Torx Plus 3IP screwdriver to remove the 2.2 mm‑long screw securing the lower board.
    • There's a magnet at the bottom right corner of phone. As you remove the nearby screw, it might stick to the magnet.
    • If you're having trouble inserting the screw, use tweezers to hold it in place while you screw in the first few threads.
  30. Google Pixel Fold Flip Battery Replacement, Secure the cable: шаг 30, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Secure the cable: шаг 30, изображение 2 из 2
    • During the next step, keep the bottom interconnect cable out of the way using your hands or tape with light adhesive.
  31. Google Pixel Fold Flip Battery Replacement, Remove the lower board: шаг 31, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Remove the lower board: шаг 31, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Remove the lower board: шаг 31, изображение 3 из 3
    • Use a spudger to pry up the lower board from its recess in the frame.
    • Remove the lower board.
  32. Google Pixel Fold Flip Battery Replacement, Reassembly information: шаг 32, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: шаг 32, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Reassembly information: шаг 32, изображение 3 из 3
  33. Google Pixel Fold Flip Battery Replacement, Heat the battery cable: шаг 33, изображение 1 из 1
    • The battery cable is lightly adhered to the frame.
    • Heat an iOpener and apply it to the battery cable for two minutes.
  34. Google Pixel Fold Flip Battery Replacement, Separate the adhesive: шаг 34, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Separate the adhesive: шаг 34, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Separate the adhesive: шаг 34, изображение 3 из 3
    Купить
    • Slide an opening pick under the battery cable to separate the adhesive.
    • Use tweezers, or your fingers, to move the battery cable upward to expose the stretch-release adhesive tab under it.
  35. Google Pixel Fold Flip Battery Replacement, Adhesive information: шаг 35, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Adhesive information: шаг 35, изображение 2 из 2
    • Six stretch release adhesive strips secure the battery to the frame:
    • The three along the left edge are very difficult to remove. Work slowly and avoid pulling the strips at steep angles.
    • The three along the bottom are moderately difficult to remove.
  36. Google Pixel Fold Flip Battery Replacement, Peel up the tabs: шаг 36, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Peel up the tabs: шаг 36, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Peel up the tabs: шаг 36, изображение 3 из 3
    • Take care not to puncture or bend the battery with sharp tools—it can leak dangerous chemicals and/or catch fire.
    • Use tweezers to peel the black pull tabs from off the frame so you can grip them with your fingers.
    • Some of the black tabs aren't adhered and don't require peeling.
  37. Google Pixel Fold Flip Battery Replacement, Remove the stretch release adhesive: шаг 37, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Remove the stretch release adhesive: шаг 37, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Remove the stretch release adhesive: шаг 37, изображение 3 из 3
    • Pull each strip out slowly and steadily at a low angle. Give them plenty of time to stretch and un-stick from under the battery.
    • You can also wrap an adhesive strip around a spudger and "roll" it for a more consistent pull.
    • If any adhesive strips break off, try to retrieve them using your fingers or tweezers, and continue pulling—but don’t pry under the battery.
    • If you can't retrieve a strip, don't worry! Remove as much adhesive as possible and move to the next step for an alternate method.
    • Repeat for all six stretch release adhesive strips.
  38. Google Pixel Fold Flip Battery Replacement, Apply isopropyl alcohol: шаг 38, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Apply isopropyl alcohol: шаг 38, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Apply isopropyl alcohol: шаг 38, изображение 3 из 3
    • If all six of the stretch release adhesive strips separated cleanly, skip the next five steps. Otherwise, follow these steps for an alternate method.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • Apply a few drops of high concentration (>90%) isopropyl alcohol in the gap between the frame and the left edge of the battery.
  39. Google Pixel Fold Flip Battery Replacement, Tilt the phone: шаг 39, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Tilt the phone: шаг 39, изображение 2 из 2
    • Tilt the left side of the phone up to let the isopropyl alcohol flow under the battery.
    • Wait one minute for the alcohol to soften the adhesive.
  40. Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 40, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 40, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Insert an opening pick: шаг 40, изображение 3 из 3
    • Take care not to puncture or bend the battery—it can leak dangerous chemicals and/or catch fire.
    • Apply a suction cup to the battery, as close to the center of the right edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap between the battery and the frame.
  41. Google Pixel Fold Flip Battery Replacement, Rotate the pick: шаг 41, изображение 1 из 2 Google Pixel Fold Flip Battery Replacement, Rotate the pick: шаг 41, изображение 2 из 2
    • Rotate the opening pick so its long edge sits in the gap.
  42. Google Pixel Fold Flip Battery Replacement, Pry up the battery: шаг 42, изображение 1 из 3 Google Pixel Fold Flip Battery Replacement, Pry up the battery: шаг 42, изображение 2 из 3 Google Pixel Fold Flip Battery Replacement, Pry up the battery: шаг 42, изображение 3 из 3
    • Pull up on the suction cup with strong, steady force while also prying up with the opening pick to separate the battery from the frame.
    • If you're feeling a lot of resistance, apply a few more drops of isopropyl alcohol and try again.
    • Depending on the condition of your adhesive, you might need to repeat the alcohol and prying cycle a few times before the battery adhesive yields.
  43. Google Pixel Fold Flip Battery Replacement, Remove the battery: шаг 43, изображение 1 из 1
    Tesa 61395 Tape
    $5.99
    Купить
    • If your bottom interconnect cable is still taped down, remove the tape now.
    • Lift the battery out its recess and remove it.
    • During reassembly, if your adhesive is still intact and sticky, you can reuse it. Otherwise, follow this guide to replace the adhesive with custom cut strips.
    • If you don't have custom cut adhesive strips, use double-sided tape, like Tesa Tape, to secure the battery to the frame.
Заключение
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel Fold Answers Community for help.
Alex Diaz-Kokaisl
Участник с: 01/16/22
125 885 Репутация
Автор 592 руководств
Команда
iFixit Участник iFixit
Staff
137 членов
Автор 17 537 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 13
За последние 30 дней: 48
За всё время: 489
