Введение
When the HMDX Chill is not functioning and all other attempts at fixing the issue have been made, the issue will most likely located in the motherboard. This guide will show how to locate and replace the motherboard of the HMDX Chill.
Выберете то, что вам нужно
Insert a metal spudger under the rubber base.
Pry the rubber base off.
Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
Use a soldering iron to desolder the wires connecting the motherboard to the case.
Insert the spudger between the case and the wire and move the spudger upwards.
The wire behind the motherboard will now be visible. Pull this out from behind.
Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
