HP 15-ay052nr Screen Replacement
Выберете то, что вам нужно
    1. HP 15-ay052nr Screen Replacement, Battery: шаг 1, изображение 1 из 1
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
      Спросите у FixBot
      Добавить комментарий
    2. HP 15-ay052nr Screen Replacement: шаг 2, изображение 1 из 1
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
      Спросите у FixBot
    3. HP 15-ay052nr Screen Replacement: шаг 3, изображение 1 из 1
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
      Спросите у FixBot
    1. HP 15-ay052nr Screen Replacement, Bottom Cover: шаг 4, изображение 1 из 1
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
      Спросите у FixBot
    2. HP 15-ay052nr Screen Replacement: шаг 5, изображение 1 из 1
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
      Спросите у FixBot
    3. HP 15-ay052nr Screen Replacement: шаг 6, изображение 1 из 1
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
      Спросите у FixBot
    4. HP 15-ay052nr Screen Replacement: шаг 7, изображение 1 из 1
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
      Спросите у FixBot
    1. HP 15-ay052nr Screen Replacement, Fan: шаг 8, изображение 1 из 1
      • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
      • The base is the side by the heatsink, which is made of copper.
      Спросите у FixBot
    2. HP 15-ay052nr Screen Replacement: шаг 9, изображение 1 из 1
      • Unplug the fan cable from the motherboard.
      • The fan can now be removed.
      Спросите у FixBot
    1. HP 15-ay052nr Screen Replacement, Screen: шаг 10, изображение 1 из 1
      • Disconnect the display cable.
      Спросите у FixBot
    2. HP 15-ay052nr Screen Replacement: шаг 11, изображение 1 из 1
      • Unplug the wire attached to the wireless adapter.
      Спросите у FixBot
    3. HP 15-ay052nr Screen Replacement: шаг 12, изображение 1 из 1
      • Remove the two 6.5-mm screws from the fan side of the computer.
      Спросите у FixBot
    4. HP 15-ay052nr Screen Replacement: шаг 13, изображение 1 из 1
      • Remove the two 3mm JIS #0 screws.
      • Remove the one broad head 2mm JIS #0 screw.
      Спросите у FixBot
    5. HP 15-ay052nr Screen Replacement: шаг 14, изображение 1 из 1
      • Lay the display with its back on a flat surface.
      Спросите у FixBot
    6. HP 15-ay052nr Screen Replacement: шаг 15, изображение 1 из 1
      • Pry open the screen cover using an iFixit opening tool around the entire screen.
      Спросите у FixBot
    7. HP 15-ay052nr Screen Replacement: шаг 16, изображение 1 из 1
      • Remove the four 3-mm JIS #0 screws.
      Спросите у FixBot
    8. HP 15-ay052nr Screen Replacement: шаг 17, изображение 1 из 1
      • Unplug the cable connected to the screen located on the bottom.
      • The screen should come off and can be replaced.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Alicia Cardell
Участник с: 01/10/19
243 Репутация
1 руководство автора
Команда
Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019 Участник Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019
OIT-LANCASTER-W19S1G5
4 членов
Автор 71 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 23
За всё время: 754
