Введение
How to replace your screen to your HTC Desire 826.
Выберете то, что вам нужно
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
Remove the metal bracket with the tweezers.
Remove the two 4.0 mm screws attaching the bottom plastic panel using a T5 screwdriver.
Remove the black plastic cover using a plastic spudger
Use tweezers to pry the wire up from the battery bed
Detach the ribbon cable by pulling with the tweezers where circled in blue
Flip the phone over so the screen side is facing up for the next step
Use the metal spudger to pry up the plastic cover pieces from the front of the phone
Pry up the edges of the screen using the metal spudger
Then use the suction cup to remove the screen from your device
Еще один человек закончил это руководство.
1 Комментарий к руководству
Après avoir fait le démontage de l'écran , le digital est devenu très dur et ne réagi pas automatiquement au toucher . Que dois-je faire ?
