Hair Dryer Heating Element Replacement
Выберете то, что вам нужно
    1. Hair Dryer Heating Element Replacement, Nozzle: шаг 1, изображение 1 из 2 Hair Dryer Heating Element Replacement, Nozzle: шаг 1, изображение 2 из 2
      • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
      • If nozzle is not attached, skip to next step.
      Спросите у FixBot
      Добавить комментарий
    1. Hair Dryer Heating Element Replacement, Grating: шаг 2, изображение 1 из 1
      • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
      • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
      Спросите у FixBot
    2. Hair Dryer Heating Element Replacement: шаг 3, изображение 1 из 1
      • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
      Спросите у FixBot
    3. Hair Dryer Heating Element Replacement: шаг 4, изображение 1 из 1
      • Separate the hair dryer grating into the three pieces seen in the image.
      Спросите у FixBot
    1. Hair Dryer Heating Element Replacement, Heating Element: шаг 5, изображение 1 из 1
      • Using the Phillips #1 screwdriver remove the two screws holding the handle of the dryer together.
      Спросите у FixBot
    2. Hair Dryer Heating Element Replacement: шаг 6, изображение 1 из 2 Hair Dryer Heating Element Replacement: шаг 6, изображение 2 из 2
      • Carefully separate the plastic casing using a spudger. Your hairdryer should now be disassembled into two large halves.
      • This can also be done with your hands if you twist the sides of the hair dryer slightly in opposite directions.
      Спросите у FixBot
    3. Hair Dryer Heating Element Replacement: шаг 7, изображение 1 из 1
      • Remove the heat-element housing by sliding it off of the dryer in the direction away from the handle.
      • Make sure the heating element is facing up so that removal is easier. If there is a casing, slightly twist as needed.
      Спросите у FixBot
    4. Hair Dryer Heating Element Replacement: шаг 8, изображение 1 из 1
      • Isolate the heating element.
      • Use a desoldering wick and soldering iron to desolder the wires.
      • Refer to this soldering page for more information on soldering.
      • You will need to be careful with these wires. Do not cut or yank the wires; this may cause further issues with your hair dryer.
      Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Make sure wiring is enclosed in the body of the hair dryer, and the heating element casing is attached properly before screwing it closed.
9 человек успешно провели ремонт по этому руководству.
Mitch
Участник с: 10/04/12
37 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 24-29, Regan Fall 2012 Участник Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 членов
Автор 11 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 32
За последние 30 дней: 158
За всё время: 47,482
