How to Clean Corroded Battery Terminals
Выберете то, что вам нужно
  1. How to Clean Corroded Battery Terminals, Safety precautions: шаг 1, изображение 1 из 1
    • Wear gloves to protect your hands from the corrosion—it's a skin irritant.
    • If your device still works, power it down completely before starting.
    Спросите у FixBot
    Добавить комментарий
  2. How to Clean Corroded Battery Terminals, Remove the batteries: шаг 2, изображение 1 из 3 How to Clean Corroded Battery Terminals, Remove the batteries: шаг 2, изображение 2 из 3 How to Clean Corroded Battery Terminals, Remove the batteries: шаг 2, изображение 3 из 3
    • Remove the batteries from your device.
    • If there's a lot of corrosion, the batteries may be stuck in their recess. Don't try to force them out...unless you're a small, green, force-sensitive creature.
    • If any batteries are stuck, follow the next step as normal to clean around them.
    Спросите у FixBot
  3. How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: шаг 3, изображение 1 из 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: шаг 3, изображение 2 из 3 How to Clean Corroded Battery Terminals, Remove big chunks of corrosion: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Anti-Static Brush
    $2.99
    • Use a toothbrush or anti‑static brush to gently remove any bigger chunks of corrosion from the battery terminals and battery recess.
    • Use the point of a spudger to pick out any bits that are stuck.
    • Pick around the batteries, and not at the batteries themselves.
    • Flip your device over and gently shake out the loose corrosion and debris.
    • Dispose of the corrosion and debris in the trash.
    Спросите у FixBot
  4. How to Clean Corroded Battery Terminals, Remove any stuck batteries: шаг 4, изображение 1 из 2 How to Clean Corroded Battery Terminals, Remove any stuck batteries: шаг 4, изображение 2 из 2
    • You should now be able to remove any batteries that were previously stuck.
    • Clean out the battery recess with a toothbrush.
    Спросите у FixBot
  5. How to Clean Corroded Battery Terminals, Clean the terminals: шаг 5, изображение 1 из 3 How to Clean Corroded Battery Terminals, Clean the terminals: шаг 5, изображение 2 из 3 How to Clean Corroded Battery Terminals, Clean the terminals: шаг 5, изображение 3 из 3
    • Alkaline batteries contain a base, which is what corrosion is made of. An acid like white vinegar or lemon juice will neutralize this base.
    • Lightly dip a cotton swab in white vinegar or lemon juice.
    • Don't soak the cotton swab. Only use a small amount of liquid at a time.
    • Gently rub the battery terminals with the cotton swab to dissolve and remove the corrosion.
    • The corrosion may fizz and bubble. Don't worry, this is normal.
    • Continue this process until there's no corrosion on the terminals.
    Спросите у FixBot
  6. How to Clean Corroded Battery Terminals: шаг 6, изображение 1 из 3 How to Clean Corroded Battery Terminals: шаг 6, изображение 2 из 3 How to Clean Corroded Battery Terminals: шаг 6, изображение 3 из 3
    Microfiber Cleaning Cloths
    $3.99
    • Isopropyl alcohol will remove any residue left from the previous step.
    • Lightly dip a cotton swab in highly-concentrated isopropyl alcohol (over 90%).
    • Gently rub the battery terminals with the cotton swap to remove any remaining residue from the previous step.
    • Wipe the residue away with a microfiber or lint-free cloth.
    • Repeat this process until the terminals are completely clean.
    • Wait two minutes to allow any residual alcohol to evaporate.
    Спросите у FixBot
  7. How to Clean Corroded Battery Terminals, Install new batteries: шаг 7, изображение 1 из 3 How to Clean Corroded Battery Terminals, Install new batteries: шаг 7, изображение 2 из 3 How to Clean Corroded Battery Terminals, Install new batteries: шаг 7, изображение 3 из 3
    Спросите у FixBot
Заключение
Cleaning didn’t go as planned? Ask our Answers community for help.
For other electronics skills, click here.
21 человек успешно провели ремонт по этому руководству.
Spencer Day
Участник с: 09/14/22
197 157 Репутация
Автор 1 243 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 32 279 руководств
2 Комментарии к руководству
Good article, thanks.
MarkDownUnder - Ответить Поделиться
Nice Article . Thanks Bro
TSM Tool - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 53
За последние 7 дней: 495
За последние 30 дней: 2,114
За всё время: 70,997
