How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus
Выберете то, что вам нужно
  1. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Heat the back cover: шаг 1, изображение 1 из 1
    • Prepare an iOpener and apply it to the back cover for at least three minutes to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
  2. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: шаг 2, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: шаг 2, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Insert an opening pick: шаг 2, изображение 3 из 3
    • Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
    • If the back cover is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap you created.
    • Slide the opening pick to the bottom left corner to slice the adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  3. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 3, изображение 1 из 2 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 3, изображение 2 из 2
    • Insert a second opening pick at the bottom edge of your phone.
    • Slide the opening pick to the bottom right corner to slice the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 4, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 4, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 4, изображение 3 из 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener for two to three minutes to reheat it.
    • Insert a third opening pick at the bottom right corner of your phone.
    • Slide the opening pick along the right edge of your phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  5. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 5, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 5, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 5, изображение 3 из 3
    • When you slice near the camera assembly, insert only the tip of the opening pick (~4-5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick underneath the top right corner of your phone.
    • Slide the opening pick along the top edge to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 6, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 6, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 6, изображение 3 из 3
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide the opening pick along the left edge of the back cover to slice the remaining adhesive.
    • When you slice near the power button, insert only the tip of the opening pick (~3-4 mm) to avoid damaging the power and volume button flex cable.
  7. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the back cover: шаг 7, изображение 1 из 2 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the back cover: шаг 7, изображение 2 из 2
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Use some high concentration (over 90%) isopropyl alcohol to wipe away any adhesive residue.
    • If you're using Samsung custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  8. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 8, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 8, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Slice the adhesive: шаг 8, изображение 3 из 3
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a thermal event.
    • Insert an opening pick underneath the left bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom left edge of the assembly to separate it from the battery.
  9. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 9, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 9, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus: шаг 9, изображение 3 из 3
    • Insert an opening pick underneath the bottom end of the NFC antenna and charging coil assembly.
    • Carefully slide the opening pick along the bottom of the assembly to separate it from the loudspeaker.
  10. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the charging coil: шаг 10, изображение 1 из 2 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the charging coil: шаг 10, изображение 2 из 2
    • Use a spudger to disconnect the charging coil by prying the connector straight up from its socket.
  11. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the NFC antenna: шаг 11, изображение 1 из 2 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the NFC antenna: шаг 11, изображение 2 из 2
    • Use a spudger to disconnect the NFC antenna by prying the connector straight up from its socket.
  12. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Unfasten the NFC antenna & charging coil assembly screws: шаг 12, изображение 1 из 1
    • Use a Phillips screwdriver to remove the five 3.9 mm-long screws securing the NFC antenna and charging coil assembly.
  13. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the NFC antenna & charging coil assembly: шаг 13, изображение 3 из 3
    • Use a pair of tweezers or your fingers to carefully remove the NFC antenna and charging coil assembly.
  14. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the battery cable: шаг 14, изображение 1 из 2 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the battery cable: шаг 14, изображение 2 из 2
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
  15. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Unfasten the loudspeaker assembly screws: шаг 15, изображение 1 из 1
    • Use a Phillips screwdriver to remove the six 3.9 mm-long screws securing the loudspeaker assembly.
  16. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Pry up the loudspeaker assembly: шаг 16, изображение 1 из 2 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Pry up the loudspeaker assembly: шаг 16, изображение 2 из 2
    • Insert an opening pick into the gap between the top edge of the loudspeaker assembly and the midframe.
    • Use your opening pick to pry up the loudspeaker assembly by tilting it downwards.
  17. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the loudspeaker assembly: шаг 17, изображение 1 из 2 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the loudspeaker assembly: шаг 17, изображение 2 из 2
    • Remove the loudspeaker assembly.
    • During reassembly apply new adhesive where it's necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
  18. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: шаг 18, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: шаг 18, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Disconnect the main & interconnect flex cables: шаг 18, изображение 3 из 3
    • Use a spudger to disconnect the main and interconnect flex cables from the motherboard by prying their upper connectors straight up from their sockets.
  19. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the main flex cable: шаг 19, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the main flex cable: шаг 19, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the main flex cable: шаг 19, изображение 3 из 3
    • Use a spudger to disconnect the main flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the main flex cable.
  20. How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the interconnect flex cable: шаг 20, изображение 1 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the interconnect flex cable: шаг 20, изображение 2 из 3 How to Remove the Interconnect Cables in the Samsung Galaxy S21 Plus, Remove the interconnect flex cable: шаг 20, изображение 3 из 3
    • Use a spudger to disconnect the interconnect flex cable from the daughterboard by prying its bottom connector straight up from its socket.
    • Use your fingers or a pair of tweezers to carefully remove the interconnect flex cable.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
After you've completed the repair, follow this guide to test your repair.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Dominik Schnabelrauch
Участник с: 11/23/16
172 614 Репутация
Автор 676 руководств
Команда
iFixit Участник iFixit
Community
141 членов
Автор 17 707 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 4
За последние 30 дней: 16
За всё время: 282
