How to Use Time Machine on macOS
    • Select System Preferences from the Apple menu.
    • Click the Time Machine icon in the bottom row.
    Спросите у FixBot
    Добавить комментарий
    • If you haven't already, plug in your external drive, or join to the network your NAS is connected to.
    • Click the Select Backup Disk button.
    • Select the disk you'd like to make backups to from the list.
    • External backup drives must be HFS (Mac OS X Journaled) formatted to work with Time Machine, not APFS, NTFS, etc.
    • Networked devices should appear automatically on this list. Consult your NAS' manual for assistance.
    • Check the Encrypt backups checkbox for additional data security, especially if your backup device is portable.
    Спросите у FixBot
    • If you chose not to encrypt your backups, you can skip this step.
    • Enter an encryption password for your Time Machine backups here, or let Apple generate one for you.
    • Store this password in a safe place! If you lose it, you will not be able to access any of your backup data or recover your machine.
    Спросите у FixBot
    • If you selected a network backup location, you may be asked to enter network login credentials at this point. Consult your NAS' documentation for more information.
    • Check the Back up automatically box if it isn't checked already, and Time Machine will be enabled!
    • To begin your first backup immediately, right click your backup drive and select Back Up to "Drive Name" Now.
    Спросите у FixBot
    • Time Machine supports multiple backup destinations for backup redundancy, if you have a second external drive or NAS.
    • Select Select Disk to select another drive.
    • Repeat steps 2 and 3 to select another backup disk from the list, and optionally enable encryption.
    Спросите у FixBot
    • When asked if you want to replace the current backup disk or use both, select the Use Both option. This will enable backups to both drives concurrently.
    • To add three or more backup destinations, select the Add or Remove Backup Disk option. You may need to scroll through the list of backup drives to find it.
    • With multiple drives, Time Machine will make hourly backups as normal, backing up to the drive with the oldest backup first, so all drives remain as up-to-date as possible.
    • If a second backup drive isn't connected, Time Machine will continue backing up to connected drives, and will automatically update the backup when the drive is reconnected, perfect for off-site or long-term backups!
    Спросите у FixBot
    • Now that you have Time Machine configured, macOS has a built-in backup browser to recover accidentally deleted or modified files.
    • In the folder that contained the files you want to recover, click the Time Machine icon in your menu bar, and select Enter Time Machine.
    Спросите у FixBot
    • On the right side of your screen, there will be a timeline of backup dates you can scroll through. Select the date you want to recover from.
    • Click the file you want to restore, and select Restore.
    Спросите у FixBot
    • Time Machine also has full system restore functionality, in case of hard drive failure. You can also use this method to setup a new machine from a previously created backup.
    • Boot to macOS recovery by holding Command+R.
    • Select Restore from Time Machine Backup from the list of available options.
    Спросите у FixBot
    • Continue to the Restore Your System page.
    • Select your Time Machine backup from the list, and Continue.
    • Select the most recent backup of your drive, or the backup you need to restore, and Continue.
    • Your Mac will now restore the system from the backup you selected, and will restart upon completion.
    Спросите у FixBot
    • Time Machine backups can also be used as a data source in the built-in Migration Assistant app.
    • Open the Migration Assistant app if you've already setup macOS.
    • Select the From a Mac, Time Machine backup, or startup disk option in the list of transfer choices, and click Continue.
    • Select the backup drive icon in the list of choices, and click Continue.
    • If you backed up to a NAS and don't see it in the list, ensure you're connected to the same network.
    • You may be asked to enter a decryption password. Enter the one you chose previously, when configuring your backup.
    Спросите у FixBot
    • Choose the backup you want to use, likely the latest backup, and click Continue.
    • Select the information you want to transfer.
    • If you have a lot of content backed up, it may take several hours to restore entirely.
    Спросите у FixBot
Заключение
That's it! Now you should know how to keep your data backed up using Time Machine, understand its more advanced features, and know how to restore a backup in the event of a failure.
4 человек успешно провели ремонт по этому руководству.
Jonah Aragon
Участник с: 08/05/18
5 728 Репутация
Автор 5 руководств
Команда
Experimax Coon Rapids Участник Experimax Coon Rapids
Business
3 членов
Автор 19 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 26
За последние 30 дней: 87
За всё время: 2,498
