How to install a GUI on Arch Linux
Выберете то, что вам нужно
    • Download the official Installation Image from the Arch Linux Download page.
    • The file you download may vary depending on how you want to boot into Arch. For this tutorial, we are going to want the ISO file.
    Спросите у FixBot
    Добавить комментарий
    • While it isn't a required step, it is recommended to verify the image before trying to use the ISO file.
    • Use GnuPG and import the Arch Linux Developer Key with the following command.
    • gpg --keyserver-options auto-key-retrieve --verify archlinux-version-x86_64.iso.sig
    • Once completed, navigate to the directory where your ISO file and the signature file are located. You can then verify the signature with the following command.
    Спросите у FixBot
    • Navigate to the BalenaEtcher website and download the appropriate version of BalenaEtcher for your operating system.
    • Insert your USB drive into your computer and launch BalenaEtcher. Select the Arch Linux ISO file you downloaded, then choose the USB drive as the target. Click 'Flash' to start the flashing process.
    • Ensure that you have selected the correct drive, as the process will erase all data on the drive.
    • Once the flashing process is complete, you can remove the USB drive.
    Спросите у FixBot
    • Power off the computer you want to install Arch Linux onto, and insert the USB drive.
    • Power on your machine and boot your machine into your BIOS or UEFI settings, and choose the USB drive as your boot option.
    Спросите у FixBot
    • Once the live system has loaded, you will be booted into Arch's terminal.
    • Arch Linux does not include a pre-installed graphical user interface (GUI) by default. Therefore, users are required to install and configure their preferred desktop environment or window manager manually after the base system is installed.
    • From the Terminal you can partition your disk, format the partitions, and mount the partitions according to your system's requirements.
    Спросите у FixBot
    • Use the Pacman package manager to install the base system and essential packages according to your preferences and needs.
    Спросите у FixBot
    • Configure the system by setting the hostname, configuring the network, and creating a user account with appropriate privileges. Set up the bootloader and other necessary configurations.
    Спросите у FixBot
    • After completing the installation and configuration process, type 'exit' to leave the chroot environment, unmount all the partitions and reboot the system.
    • Remove the USB drive when prompted and allow the system to boot into the newly installed Arch Linux environment.
    Спросите у FixBot
    • Regardless of which environment you are going to install, you will need to install the graphics drivers for your machine.
    • Use the following command to find which graphics card your machine is running.
    • Use the following command to find your graphics card. lspci | grep -e VGA
    Спросите у FixBot
    • Use the Official Arch Linux Driver Installation Guide to determine if your hardware is compatible with Arch Linux.
    • Once you've determined what graphics drivers you need, you will need to update your system with the following command. sudo pacman -Syyu
    • Once the system has finished updating you can install your drivers. If you are using VirtualBox then you will use the following command sudo pacman -S virtualbox-guest-utils virtualbox-guest-dkms
    Спросите у FixBot
    • The very next thing you will need is to install your Display Server. This is a crucial component for running graphical user interfaces on Linux systems, including Arch Linux. It serves as the display server, providing the framework for managing graphical output and user input.
    • For this tutorial, we will be using Xorg as our display server of choice for compatibility, configurability, and legacy support.
    • Use the following command to install Xorg and its related utilities. sudo pacman -S xorg xterm xorg-xinit
    • Once the installation is finished, run the following command startx, to test your Xorg installation.
    Спросите у FixBot
  1. Спросите у FixBot
  2. How to install a GUI on Arch Linux, Install MATE Desktop Environment: шаг 13, изображение 1 из 3 How to install a GUI on Arch Linux, Install MATE Desktop Environment: шаг 13, изображение 2 из 3 How to install a GUI on Arch Linux, Install MATE Desktop Environment: шаг 13, изображение 3 из 3
    • Pros: Resource Efficient, Traditional Desktop Layout similar to GNOME 2, and Highly Customizable
    • Cons: Aesthetic is not as visually polished, lacks some features found in heavier desktop environments like GNOME or KED, and application integration is not as extensive.
    • Requirements:
    • CPU: 1.0 GHz Processor or Higher
    • RAM: 2 GB
    • Storage: 10 GB of Free Space
    • Graphics: Card capable of 1024 x 768 Resolution
    • To install use the command sudo pacman -S mate mate-extra, then continue to the next step.
    Спросите у FixBot
  3. How to install a GUI on Arch Linux, Install Cinnamon Desktop Environment: шаг 14, изображение 1 из 3 How to install a GUI on Arch Linux, Install Cinnamon Desktop Environment: шаг 14, изображение 2 из 3 How to install a GUI on Arch Linux, Install Cinnamon Desktop Environment: шаг 14, изображение 3 из 3
    • Pros: User-Friendly Interface, Highly Customizable, Known for Stability and Reliability.
    • Cons: More Resource Intensive, Application Integration not as deep as other desktop experiences, highly dependent on specific pieces of hardware.
    • System Requirements:
    • CPU: 1.6 GHz Processor or Higher
    • RAM: 2 GB
    • Storage: 15 GB of free space
    • Graphics: Graphics card capable of 1024 x 768 resolution
    • To install use the command sudo pacman -S cinnamon nemo-fileroller, then continue to the next step.
    Спросите у FixBot
  4. How to install a GUI on Arch Linux, Install Gnome Desktop Environment: шаг 15, изображение 1 из 3 How to install a GUI on Arch Linux, Install Gnome Desktop Environment: шаг 15, изображение 2 из 3 How to install a GUI on Arch Linux, Install Gnome Desktop Environment: шаг 15, изображение 3 из 3
    • Pros: User-friendly, integrates seamlessly with GTK-based applications and features a highly efficient workflow.
    • Cons: More resource intensive, limited customization, lacks some advanced features that are available in other desktop environments.
    • CPU: 2 GHz dual-core processor or equivalent
    • RAM: 2 GB
    • Storage: 20 GB of free space
    • Graphics: Graphics card capable of OpenGL 3.3 or higher
    • To install use the command sudo pacman -S gnome gnome-extra, then continue to the next step.
    Спросите у FixBot
  5. How to install a GUI on Arch Linux, Install XFCE4 Desktop Environment: шаг 16, изображение 1 из 2 How to install a GUI on Arch Linux, Install XFCE4 Desktop Environment: шаг 16, изображение 2 из 2
    • Pros: Resource Efficient, Highly Customizable, Highly Stable.
    • Cons: Less modern Aesthetic, Lacks Core Features, Lack of Application Integration.
    • CPU: 1.6 GHz processor or equivalent
    • RAM: 1 GB
    • Storage: 15 GB of Free Space
    • Graphics: Graphics card capable of 1024x768 resolution
    • To install use the command sudo pacman -S xfce4 xfce4-goodies, then continue to the next step.
    Спросите у FixBot
  6. How to install a GUI on Arch Linux, Install KDE Plasma Desktop Environment: шаг 17, изображение 1 из 3 How to install a GUI on Arch Linux, Install KDE Plasma Desktop Environment: шаг 17, изображение 2 из 3 How to install a GUI on Arch Linux, Install KDE Plasma Desktop Environment: шаг 17, изображение 3 из 3
    • Pros: Highly Customizable, Ritch Feature Set (Including desktop widgets, advanced theming, and various configuration options), and Application integration.
    • Cons: More resource intensive, has a bit of a steep learning curve, and can become unwieldily .
    • CPU: 2 GHz Dual-Core Processor or better.
    • RAM: 4 GB
    • Storage: 25 GB of free space
    • Graphics: Graphics card capable of OpenGL3.1 or higher
    • To install use the command sudo pacman -S plasma kdeplasma-addons, then continue to the next step.
    Спросите у FixBot
  7. How to install a GUI on Arch Linux, Install LXDE Desktop Environment: шаг 18, изображение 1 из 2 How to install a GUI on Arch Linux, Install LXDE Desktop Environment: шаг 18, изображение 2 из 2
    • Pros: Lightweight design, Speed and Efficiency prioritized, and highly customizable.
    • Cons: Limited default features, less modern design, and lacks application integration.
    • CPU: Pentium III or equivalent
    • RAM: 512 MB
    • Storage: 10 GB of free space
    • Graphics: Graphics card capable of 800x600 resolution
    • To install use the command sudo pacman -S lxde, then continue to the next step.
    Спросите у FixBot
  8. Спросите у FixBot
  9. How to install a GUI on Arch Linux, Install Gnome Display Manager (GDM): шаг 20, изображение 1 из 1
    • Pros: Integrates seamlessly with GNOME Desktop Environment, user friends, and supports Wayland sessions.
    • Cons: Some features are dependent on GNOME components.
    • To install the Gnome Display Manager you will use the following commands.
    • sudo pacman -S gdm
    • sudo systemctl enable gdm
    • sudo systemctl start gdm
    • Once installed you can move on to the next step.
    Спросите у FixBot
  10. How to install a GUI on Arch Linux, Install Simple Desktop Display Manger (SDDM): шаг 21, изображение 1 из 1
    • Pros: Simple and lightweight, works well with KDE Plasma desktop environment, and highly customizable.
    • Cons Not as feature-rich as some other display managers.
    • To install the Simple desktop Display Manager you will use the following commands.
    • sudo pacman -S sddm
    • sudo systemctl enable sddm
    • sudo systemctl start sddm
    Спросите у FixBot
  11. How to install a GUI on Arch Linux, Install Lightweight X11 Display Manager (LXDM): шаг 22, изображение 1 из 1
    • Pros: Designed to work well with LXDE, light weight and easy to use, and is suitable for systems with lower resource availability.
    • Cons: Not as feature-rich as display managers with broader compatibility.
    • To install the Lightweight X11 Display Manager you will use the following commands.
    • sudo pacman -S lxdm
    • sudo systemctl enable lxdm
    • sudo systemctl start lxdm
    Спросите у FixBot
  12. How to install a GUI on Arch Linux, Install LightDM: шаг 23, изображение 1 из 1
    • Pros: Lightweight and fast, features support for multiple desktop environments, and highly customizable.
    • Cons: May not have as many advanced features as some other display managers.
    • To install the LightDM you will use the following commands.
    • sudo pacman -S lightdm
    • sudo systemctl enable lightdm
    • sudo systemctl start lightdm
    Спросите у FixBot
    • One of the last things needed is installing a few utilities for a smoother desktop experience.
    • Sound System: sudo pacman -S pulseaudio pulseaudio-alsa pavucontrol
    • Terminal and System Monitor: sudo pacman -S gnome-terminal gnome-system-monitor
    • Firefox and Media Players: sudo pacman -S firefox vlc audacious
    • LibreOffice: sudo pacman -S libreoffice
    Спросите у FixBot
    • Once you have everything installed, use the startx command to manually start the X Window System.
    Спросите у FixBot
Заключение
Congratulations, you just completed the installation of a GUI onto Arch Linux! The flexibility of Arch Linux allows users to tailor their graphical environment, striking a balance between resource efficiency and feature richness.
3 человек успешно провели ремонт по этому руководству.
Jacob Mehnert
Участник с: 10/18/21
49 148 Репутация
Автор 51 руководств
Команда
iFanatics Участник iFanatics
Community
69 членов
Автор 242 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 16
За последние 7 дней: 144
За последние 30 дней: 619
За всё время: 53,663
