Huawei P smart Pro Display Replacement
Выберете то, что вам нужно
      • To start, remove the back glass by following these steps:
      • Begin by heating up your iOpener. For instructions on how to heat up your iOpener, see this guide.
      • Place the iOpener on the right side of your device (with the back glass facing you).
      • Attach the suction cup to the back glass and pull up.
      • Insert an opening pick and slide it to the bottom right corner.
      • Insert another opening pick and slide it to the top right corner.
      • At the top of the device, insert an opening pick and slide it to the top left corner. If needed, reheat your iOpener and place it on the edge before prying. Repeat this step for the bottom left corner.
      • You can now fully pry open the back glass.
      Спросите у FixBot
      Добавить комментарий
      • Undo all 12 screws to remove the metal shield.
      • Make sure to not lose the screws.
      Спросите у FixBot
      • Disconnect the ribbon cable that leads to the display with the Spudger (included with your iOpener Kit).
      • To avoid damage to the cameras, please disconnect them from the motherboard and temporarily place them in another location, such as a small bag.
      • Do not shake the bag to avoid damage to the cameras inside.
      Спросите у FixBot
      • Connect the new display and power on the phone, then test if the touchscreen works properly. If the display works as intended, power off the phone and proceed to the next step.
      • If the display does not work, you are advised to temporarily stop here and purchase a new one.
      Спросите у FixBot
      • Disconnect the ribbon cable to the battery using the Spudger (included with your iOpener Kit), then gently pry it out of the casing using the Plastic Cards (also included with your iOpener Kit).
      • Be very careful when prying the battery out of the casing, as you might accidentally puncture it.
      Спросите у FixBot
      • Use the iOpener to heat up the edges of the old display, then gently pry it up using the Suction Cup and the Opening Picks (both included with your iOpener Kit) and remove it.
      • If the glue on your display is already loose, you can skip this step.
      Спросите у FixBot
      • Use the Tweezers (included with your iOpener Kit) to remove the adhesive residues created by the display adhesive. To help loosen the residue, you can use a bit of isopropyl alcohol on a cotton swab.
      • At this point, you can also clean the adhesive residues created by the back glass adhesive.
      Спросите у FixBot
      • Apply the T-7000 adhesive to the edges.
      • Insert the new display and connect the ribbon cable to the motherboard.
      • Make sure that you are feeding the ribbon cable of the display through the small hole.
      • Use the clamps to secure the screen in place.
      • You will have to wait around 12 hours to let the adhesive properly secure the display.
      Спросите у FixBot
      • After the T-7000 adhesive fully hardens and secures the display in place, reinsert the battery.
      • If replacing the battery, you are advised to dispose of the old battery at a dedicated tech recycling center.
      • At this point, you can now reconnect the cameras to the motherboard.
      Спросите у FixBot
      • Place the metal shield in its designated place and fasten the screws.
      Спросите у FixBot
      • Reinsert the back glass.
      • If replacing the back glass, you are advised to properly dispose of it.
      • Use the clamps to secure the back glass in place.
      • You will have to wait another 12 hours to let the adhesive properly secure the back glass.
      Спросите у FixBot
Заключение
You’ve successfully replaced the display on your Huawei P smart Pro! Taking the time to carefully follow each step ensures your device is restored to full functionality and looks as good as new. Remember to test all features before final assembly to catch any issues early.
Regular maintenance and cautious handling will help prolong your phone’s lifespan. If you encounter any difficulties or have questions, don’t hesitate to reach out to the repair community for support.
Great job on completing this repair—your phone is ready to tackle whatever comes next!
Tiberiu S.
Участник с: 06/15/25
208 Репутация
1 руководство автора
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 12
За последние 30 дней: 48
За всё время: 246
