JBL Clip 4 Battery Replacement
Выберете то, что вам нужно
    1. JBL Clip 4 Battery Replacement, Front Grill: шаг 1, изображение 1 из 1
      • Get a tool to pry the front grill off, ideally using one of the iFixit tools. This is required as the front grill is glued onto the device.
      Спросите у FixBot
      Добавить комментарий
    2. JBL Clip 4 Battery Replacement: шаг 2, изображение 1 из 1
      • Now you just need to pry it off using your chosen tool and it should come off easily leaving you with the front grill separated from the device. Your device should look like this after removing the front grill.
      Спросите у FixBot
    1. JBL Clip 4 Battery Replacement, Back Housing: шаг 3, изображение 1 из 1
      • First, you must unscrew the 5 Phillip head screws (6mm) around the edge of the device.
      Спросите у FixBot
    2. JBL Clip 4 Battery Replacement: шаг 4, изображение 1 из 1
      • Now with the unscrewed front and back housing, you should see some cables that connect between the two. Simply unplug these cables and the back housing will come apart from the front.
      Спросите у FixBot
    1. JBL Clip 4 Battery Replacement, Battery: шаг 5, изображение 1 из 1
      • The battery connects into the motherboard, and it is inside the black box shaped part that has a cable connecting into the motherboard. You must disconnect the cable connecting the battery to the motherboard.
      Спросите у FixBot
    2. JBL Clip 4 Battery Replacement: шаг 6, изображение 1 из 1
      • Now all you need to do is pull the battery out of the case its in and you have successfully disconnected the battery from the device.
      Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Trey Adao
Участник с: 03/06/26
598 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 3-4, Shaddix Spring 2026 Участник UMass Dartmouth, Team 3-4, Shaddix Spring 2026
UMASSD-SHADDIX-S26S3G4
4 членов
Автор 28 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 14
За последние 30 дней: 63
За всё время: 201
