JBL Tune 510BT LED and Refractor Replacement
Выберете то, что вам нужно
    1. JBL Tune 510BT LED and Refractor Replacement, Faceplate: шаг 1, изображение 1 из 2 JBL Tune 510BT LED and Refractor Replacement, Faceplate: шаг 1, изображение 2 из 2
      • Firmly grasp the earmuff and pull away from the center until the lip of the earmuff is disengaged.
      • Pull the earmuff towards the center of the headphones until it is free.
      Спросите у FixBot
      Добавить комментарий
    2. JBL Tune 510BT LED and Refractor Replacement: шаг 2, изображение 1 из 2 JBL Tune 510BT LED and Refractor Replacement: шаг 2, изображение 2 из 2
      • Remove the three 3 mm screws using a JIS #00 screwdriver.
      Спросите у FixBot
    3. JBL Tune 510BT LED and Refractor Replacement: шаг 3, изображение 1 из 1
      • Carefully remove the faceplate by lifting it firmly.
      • Avoid rough movements, as there is a single thin wire connecting the faceplate to the internals.
      • If the repair is for the right-side driver, be mindful of the charging port, as the faceplate has a slot there for it. Lift the opposite end and back the port out.
      • To completely detach the faceplate, desolder the wires from the connections on the motherboard.
      Спросите у FixBot
    1. JBL Tune 510BT LED and Refractor Replacement, LED and Refractor: шаг 4, изображение 1 из 3 JBL Tune 510BT LED and Refractor Replacement, LED and Refractor: шаг 4, изображение 2 из 3 JBL Tune 510BT LED and Refractor Replacement, LED and Refractor: шаг 4, изображение 3 из 3
      • This is where you would find the rubber housing normally.
      • If the rubber housing is dislodged, which is fairly common, simply replace it in its correct orientation to its seating, being sure to place the indicated piece through the hole to the exterior of the headphones.
      Спросите у FixBot
    2. JBL Tune 510BT LED and Refractor Replacement: шаг 5, изображение 1 из 2 JBL Tune 510BT LED and Refractor Replacement: шаг 5, изображение 2 из 2
      • Heat the small spots of solder where the two LED strips are on the circuit board with a soldering iron.
      • The yellow strip is the white LED, and the white strip is the red and blue LED. Make note of their orientation and positions.
      • Solder the new LEDs into position, making sure the contacts are solid.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Ryan
Участник с: 01/30/24
648 Репутация
Автор 4 руководств
Команда
Utah Tech University, Team 1-2, McMurrin Spring 2024 Участник Utah Tech University, Team 1-2, McMurrin Spring 2024
UTAHTECH-MCMURRIN-S24S1G2
2 членов
Автор 23 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 14
За последние 30 дней: 66
За всё время: 1,673
