LG VX6100 Main Display Replacement
Выберете то, что вам нужно
  1. LG VX6100 Main Display Replacement, Battery: шаг 1, изображение 1 из 1
    • Open the battery casing by pressing the gray "PUSH" button. Slide the back of the casing downward.
    Спросите у FixBot
    Добавить комментарий
    • Carefully remove the faulty battery from the back of the phone.
    • Inspect the battery port to ensure the battery is the issue. Ensure the four gold connecting prongs are intact and are pointing straight into the port.
    Спросите у FixBot
  2. LG VX6100 Main Display Replacement: шаг 3, изображение 1 из 1
    • Align the gold prongs with the gold plates on the bottom of the battery. Make sure "This Side Up" is visible
    • Push the battery flat against the back of the phone until it clicks into place.
    Спросите у FixBot
    • Replace the back cover of the phone by sliding the casing down into place. Gently press the top until it clicks.
    • Charge the device and turn it on to confirm the issue is resolved.
    Спросите у FixBot
  3. LG VX6100 Main Display Replacement, Front Case: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Remove the four grey plugs using either tweezers or a push pin.
    Спросите у FixBot
  4. LG VX6100 Main Display Replacement: шаг 6, изображение 1 из 1
    • Remove the four screws that are now exposed using a Phillips #00 screwdriver.
    • Be sure to put the screws in a safe place as they are very small and easy to lose.
    Спросите у FixBot
  5. LG VX6100 Main Display Replacement: шаг 7, изображение 1 из 1
    • Once all the screws have been removed, use a plastic opener tool to pry the case from the rest of the phone.
    • Insert the opener tool into the seem between the case and the phone. Apply pressure to separate the two pieces.
    • Do this across the entire length of the seem until the case is no longer attached to the phone.
    Спросите у FixBot
  6. LG VX6100 Main Display Replacement: шаг 8, изображение 1 из 1
    • The case can now be removed and the interior of the front is accessible.
    Спросите у FixBot
  7. LG VX6100 Main Display Replacement, Main Display: шаг 9, изображение 1 из 2 LG VX6100 Main Display Replacement, Main Display: шаг 9, изображение 2 из 2
    • Locate the solder on the side of the metal plate on the top half of the phone.
    • Place a piece of solder wick on top of the solder.
    • To desolder the connection, very carefully place the tip of the soldering iron on top of the solder wick. Hold it steady until the solder is soaked up into the solder wick.
    • The soldering iron will damage circuitry if held down for too long.
    • Cut off the used solder wick with pliers and repeat this step if any solder remains.
    Спросите у FixBot
  8. LG VX6100 Main Display Replacement: шаг 10, изображение 1 из 1
    • After the solder has been removed, pry off the camera assembly connection shield with the plastic opening tool.
    Спросите у FixBot
  9. LG VX6100 Main Display Replacement: шаг 11, изображение 1 из 2 LG VX6100 Main Display Replacement: шаг 11, изображение 2 из 2
    • Remove the main display by lifting up the extruded white edge with your fingernail.
    Спросите у FixBot
Заключение
Ryan Bishop
Участник с: 04/17/12
1 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 12-39, Regan Spring 2012 Участник Cal Poly, Team 12-39, Regan Spring 2012
CPSU-REGAN-S12S12G39
3 членов
Автор 32 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 38
За всё время: 1,526
