Le Pan S Speaker Replacement
Выберете то, что вам нужно
    1. Le Pan S Speaker Replacement, Battery: шаг 1, изображение 1 из 1
      • Remove the two 3.5 mm Phillips #00 screws that are covered by the micro SD port.
      • This cover is adjacent to the volume button on the side of the Le Pan S.
      Спросите у FixBot
      Добавить комментарий
    2. Le Pan S Speaker Replacement: шаг 2, изображение 1 из 2 Le Pan S Speaker Replacement: шаг 2, изображение 2 из 2
      • Insert the spudger between the front and back panel in order to pry them apart.
      • Do this beside the volume button and the micro SD cover.
      • Pry open the rest of the Le Pan S by dragging the spudger across the side.
      Спросите у FixBot
    3. Le Pan S Speaker Replacement: шаг 3, изображение 1 из 1
      • Once the front and back faces are completely separated, remove the back cover to reveal the inside components.
      Спросите у FixBot
    4. Le Pan S Speaker Replacement: шаг 4, изображение 1 из 2 Le Pan S Speaker Replacement: шаг 4, изображение 2 из 2
      • Disconnect the battery from the circuitry and lay it out of the way.
      • The best method to complete this is to pull the bundled cable connector out with your hands. Pull towards the wires and away from the electrical board. Use the spudger to further coax the cable out.
      • If you are replacing your battery, make sure to dispose of it properly.
      Спросите у FixBot
    1. Le Pan S Speaker Replacement, Speaker: шаг 5, изображение 1 из 1
      • Remove the four 3.5 mm Phillips #00 screws holding the speakers in place.
      • Move the speakers out of the way.
      Спросите у FixBot
    2. Le Pan S Speaker Replacement: шаг 6, изображение 1 из 1
      • Place the wick on the solder connecting the speakers to the electrical board.
      • Place a heated soldering iron on the solder wick to melt the existing solder.
      • Pull the speakers off of the solder connection.
      • A solder vacuum can also be used in place of solder wick to remove old solder.
      • If you need more help with the soldering process, take a look at iFixit's guide for soldering and desoldering connections.
      Спросите у FixBot
Заключение
Maria Dole
Участник с: 09/17/15
395 Репутация
Автор 3 руководств
Команда
IUPUI, Team 2-1, Harley Fall 2015 Участник IUPUI, Team 2-1, Harley Fall 2015
IUPUI-HARLEY-F15S2G1
5 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 24
За всё время: 513
