Lexibook Junior Tablet Motherboard Replacement
Выберете то, что вам нужно
    1. Lexibook Junior Tablet Motherboard Replacement, Battery: шаг 1, изображение 1 из 1
      • Make sure your device is powered off before replacement to prevent electric shock.
      • With the device screen face down, use the metal spudger to remove the small rubber circles on all four corners of the device. The screws should now be revealed.
      • Using the metal spudger, pry open the small, long rubber rectangle on the back of the device to reveal more screws.
      Спросите у FixBot
      Добавить комментарий
    2. Lexibook Junior Tablet Motherboard Replacement: шаг 2, изображение 1 из 1
      • Using a Phillips #00 screwdriver, remove the four 6.8mm screws from the four corners of the device.
      • Using the same screwdriver, remove the three screws that were behind the rubber rectangle. These screws do not come out of the device.
      • Use the plastic opening tool to gently pry open the back panel of the tablet.
      Спросите у FixBot
    3. Lexibook Junior Tablet Motherboard Replacement: шаг 3, изображение 1 из 1
      • Use the nylon spudger to gently pry under the battery to remove it.
      • Make sure you do not damage the battery or metal plate in this process and only use a nylon spudger. Be patient and work slowly for the best results.
      Спросите у FixBot
    4. Lexibook Junior Tablet Motherboard Replacement: шаг 4, изображение 1 из 1
      • Use a soldering iron to remove the battery from the motherboard safely.
      • For advice on how to solder, check out iFixit's Soldering Guide.
      Спросите у FixBot
    1. Lexibook Junior Tablet Motherboard Replacement, Motherboard: шаг 5, изображение 1 из 2 Lexibook Junior Tablet Motherboard Replacement, Motherboard: шаг 5, изображение 2 из 2
      • Using the plastic opening tool, gently push the two small, black and white switches out in the direction of the ribbon wires.
      • Slowly pull the ribbon wire out of the switch to free it.
      Спросите у FixBot
    2. Lexibook Junior Tablet Motherboard Replacement: шаг 6, изображение 1 из 1
      • Push the larger black and white strip leading to a ribbon wire upward using the plastic opening tool.
      • Carefully pull the ribbon wire out of the switch
      Спросите у FixBot
    3. Lexibook Junior Tablet Motherboard Replacement: шаг 7, изображение 1 из 3 Lexibook Junior Tablet Motherboard Replacement: шаг 7, изображение 2 из 3 Lexibook Junior Tablet Motherboard Replacement: шаг 7, изображение 3 из 3
      • Unscrew the five 4 mm screws around the perimeter of the motherboard using the ph00 size phillips head screwdriver.
      Спросите у FixBot
    4. Lexibook Junior Tablet Motherboard Replacement: шаг 8, изображение 1 из 2 Lexibook Junior Tablet Motherboard Replacement: шаг 8, изображение 2 из 2
      • Remove the button board by unscrewing two more 4 mm screws and one 6.5 mm screw
      Спросите у FixBot
    5. Lexibook Junior Tablet Motherboard Replacement: шаг 9, изображение 1 из 1
      • Solder off connections from the wire connecting the motherboard to the speaker.
      • For how to solder, check out iFixit's Soldering Guide.
      Спросите у FixBot
Заключение
Rachel Klesius
Участник с: 09/19/16
645 Репутация
Автор 6 руководств
Команда
USF Tampa, Team 17-3, Blackwell Fall 2016 Участник USF Tampa, Team 17-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G3
4 членов
Автор 24 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 37
За всё время: 634
