Logitech Craft Battery Replacement
Выберете то, что вам нужно
  1. Logitech Craft Battery Replacement, Turn off the keyboard: шаг 1, изображение 1 из 1
    • Before you begin, flip the keyboard's power switch into the OFF position.
    • Unplug all cables from your keyboard.
  2. Logitech Craft Battery Replacement, Remove the plastic foot: шаг 2, изображение 1 из 2 Logitech Craft Battery Replacement, Remove the plastic foot: шаг 2, изображение 2 из 2
    • Lay your keyboard down with the feet facing up on a clean work surface.
    • The dial will prevent the keyboard from laying perfectly flat. If you need to, lay the keyboard on a soft towel to prevent wobble.
    • Heat an iOpener and lay it on the left rear plastic foot for about two minutes.
    • Alternatively, you can also use a hair dryer to heat the sticker. Make sure it's on the Low setting to avoid warping the plastic.
  3. Logitech Craft Battery Replacement, Remove the foot pad: шаг 3, изображение 1 из 3 Logitech Craft Battery Replacement, Remove the foot pad: шаг 3, изображение 2 из 3 Logitech Craft Battery Replacement, Remove the foot pad: шаг 3, изображение 3 из 3
    • Only one foot (the one next to the power switch) has a hidden screw underneath—you don't need to remove both feet.
    • Insert the point of a spudger under an end of the foot.
    • Push the spudger underneath the foot and lift until you can grip it with your fingers.
    • The foot should come away from the keyboard without much force. If it feels stuck, apply more heat and try again.
    • Peel the foot up and remove it.
  4. Logitech Craft Battery Replacement, Remove the screw securing the bottom cover: шаг 4, изображение 1 из 2 Logitech Craft Battery Replacement, Remove the screw securing the bottom cover: шаг 4, изображение 2 из 2
    • If there's plastic film covering the screw, use the point of a spudger to poke through it.
    • Use a Phillips screwdriver to remove the 4.7 mm‑long screw securing the bottom cover.
  5. Logitech Craft Battery Replacement, Unlock the bottom cover: шаг 5, изображение 1 из 2 Logitech Craft Battery Replacement, Unlock the bottom cover: шаг 5, изображение 2 из 2
    • The bottom cover is held in place by slotted plastic clips along the entire length of the keyboard.
    • Don't attempt to force the cover off until all clips have disengaged. The bottom cover should come away with little to no force.
    • Hold the keyboard upside down above your work surface.
    • Grip the bottom cover and slide it towards the ON/OFF switch to unlock it from the rest of the device.
  6. Logitech Craft Battery Replacement, Slide and remove the bottom cover: шаг 6, изображение 1 из 3 Logitech Craft Battery Replacement, Slide and remove the bottom cover: шаг 6, изображение 2 из 3 Logitech Craft Battery Replacement, Slide and remove the bottom cover: шаг 6, изображение 3 из 3
    • Lay the keyboard back down onto your work surface.
    • Lightly push down on the bottom cover and slide it further towards the ON/OFF switch.
    • Remove the bottom cover.
    • During reassembly, make sure the bottom cover sits flush along the entire length of the keyboard—all clips need to lock back in place.
  7. Logitech Craft Battery Replacement, Remove the foam pieces: шаг 7, изображение 1 из 3 Logitech Craft Battery Replacement, Remove the foam pieces: шаг 7, изображение 2 из 3 Logitech Craft Battery Replacement, Remove the foam pieces: шаг 7, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    • Various pieces of foam protect the battery wires and the interconnect ribbon cable. They'll need to be removed in order to access the battery.
    • Use a pair of tweezers to peel up and remove the first piece of foam covering the interconnect cable.
    • The foam pads are all secured with light adhesive.
    • Try your best to not rip these foam pads as you remove them—ideally they're reused during reassembly.
  8. Logitech Craft Battery Replacement: шаг 8, изображение 1 из 2 Logitech Craft Battery Replacement: шаг 8, изображение 2 из 2
    • Remove the two remaining topmost pieces of foam from the keyboard.
    • Be very careful not to puncture the battery, as it can leak dangerous chemicals or catch fire.
  9. Logitech Craft Battery Replacement, Remove the interconnect cable: шаг 9, изображение 1 из 3 Logitech Craft Battery Replacement, Remove the interconnect cable: шаг 9, изображение 2 из 3 Logitech Craft Battery Replacement, Remove the interconnect cable: шаг 9, изображение 3 из 3
    • Use the point of a spudger to gently lift the hinged locking flap on the interconnect cable's ZIF connector up and away from the cable.
    • Use a pair of tweezers to slide the interconnect cable out of its connector.
    • Try to grip the cable by the blue plastic, not by the cable itself.
  10. Logitech Craft Battery Replacement: шаг 10, изображение 1 из 3 Logitech Craft Battery Replacement: шаг 10, изображение 2 из 3 Logitech Craft Battery Replacement: шаг 10, изображение 3 из 3
    • Use the point of a spudger to lift the hinged locking flap on the opposite end of the interconnect cable.
    • Remove the interconnect cable.
  11. Logitech Craft Battery Replacement, Remove the rest of the foam: шаг 11, изображение 1 из 2 Logitech Craft Battery Replacement, Remove the rest of the foam: шаг 11, изображение 2 из 2
    • Use a pair of tweezers to remove the two remaining pieces of foam securing the battery wires.
  12. Logitech Craft Battery Replacement, De-route the battery wires: шаг 12, изображение 1 из 3 Logitech Craft Battery Replacement, De-route the battery wires: шаг 12, изображение 2 из 3 Logitech Craft Battery Replacement, De-route the battery wires: шаг 12, изображение 3 из 3
    • Use a pair of tweezers to slide the battery wires out from underneath their plastic routing clips on either side of the battery.
  13. Logitech Craft Battery Replacement, Disconnect both battery connectors: шаг 13, изображение 1 из 2 Logitech Craft Battery Replacement, Disconnect both battery connectors: шаг 13, изображение 2 из 2
    • Use a pair of tweezers to firmly grip the left battery connector.
    • Hold the tweezers with your fingers as close to the connector as possible to get a firm hold.
    • Gently rock the connector side‑to‑side and slide it straight out of the socket.
    • Always pull cables by their connectors and not the wires themselves.
  14. Logitech Craft Battery Replacement: шаг 14, изображение 1 из 2 Logitech Craft Battery Replacement: шаг 14, изображение 2 из 2
    • Repeat the previous step to disconnect the right battery connector.
    • During reassembly, note that the battery connector that goes into the right board has three battery wires, and the left has two.
  15. Logitech Craft Battery Replacement, Remove the battery: шаг 15, изображение 1 из 3 Logitech Craft Battery Replacement, Remove the battery: шаг 15, изображение 2 из 3 Logitech Craft Battery Replacement, Remove the battery: шаг 15, изображение 3 из 3
    • Insert the flat edge of a spudger underneath one of the short edges of the battery.
    • Push the spudger underneath the battery and lift, separating it from the adhesive holding it to the keyboard.
    • Make sure you push underneath the battery and not into it. Don't bend or deform the battery.
    • If the battery isn't separating, apply a few drops of isopropyl alcohol (>90%) to its edge and slightly tilt the keyboard. Wait one minute for the alcohol to soften the adhesive and try again.
    • Remove the battery.
    • To install a replacement battery:
    • Remove any leftover adhesive from the battery well.
    • Use double‑sided tape or pre-cut adhesive to secure the battery, making sure the battery is correctly oriented— thebattery connector that goes into the right board has three battery wires, and the left has two.
Заключение
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Reuse or Recycle—Never put discarded electronic parts in household waste. Visit Logitech Recycling to find your nearest recycling points, including the option to mail back old devices to Logitech for free if there’s no convenient solution in your area. You can also take your e-waste to any R2 or e-Stewards certified recycler. And don’t let good working parts or repaired devices die a slow death in your sock drawer—pass them along to someone who can use them.
Share your experience—Leave a comment here or send your feedback directly to Logitech at repair@logitech.com to help shape future repair guides and product design.
9 человек успешно провели ремонт по этому руководству.
Carsten Frauenheim
Участник с: 03/10/20
156 485 Репутация
Автор 439 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 23 828 руководств
1 Комментарий к руководству
fantastic instructions, where can I get a replacement battery?
Angel L Velazquez - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 8
За последние 7 дней: 49
За последние 30 дней: 264
За всё время: 11,742
