Logitech M185 Wireless Mouse Motherboard Replacement
Выберете то, что вам нужно
    1. Logitech M185 Wireless Mouse Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 3 Logitech M185 Wireless Mouse Motherboard Replacement, Motherboard: шаг 1, изображение 2 из 3 Logitech M185 Wireless Mouse Motherboard Replacement, Motherboard: шаг 1, изображение 3 из 3
      • Flip the mouse over so the bottom is facing up and you can see the power switch.
      • Before you begin, flip the power switch on the bottom to the "Off" position.
      • Press down on the battery cover.
      • Slide the battery cover off.
      Спросите у FixBot
      Добавить комментарий
    2. Logitech M185 Wireless Mouse Motherboard Replacement: шаг 2, изображение 1 из 2 Logitech M185 Wireless Mouse Motherboard Replacement: шаг 2, изображение 2 из 2
      • There is not a battery in our mouse. However, it is necessary to remove the battery to access the screw beneath.
      • Use a Phillips #00 screwdriver and remove the single screw from the battery compartment.
      Спросите у FixBot
    3. Logitech M185 Wireless Mouse Motherboard Replacement: шаг 3, изображение 1 из 1
      • Use a black nylon spudger to pry off the shell.
      • Work your way along the seam to release the tabs connecting the top and bottom of the mouse.
      • Do not use a metal spudger for prying, as it may damage internal components, such as the main circuit board, that are not visible.
      • Gently squeeze the sides of the mouse while using the spudger to pry the top case away from the bottom. The pressure will cause the mouse to open.
      Спросите у FixBot
    4. Logitech M185 Wireless Mouse Motherboard Replacement: шаг 4, изображение 1 из 1
      • Use a black nylon spudger to pry out the motherboard and remove it from the bottom case.
      • Don't use a metal spudger on the internals of your device as displayed in the photo, it can cause damage.
      • Be careful when handling the motherboard. If you don't have any gloves, do not touch the motherboard with your hands. Only hold it by the edges.
      Спросите у FixBot
    5. Logitech M185 Wireless Mouse Motherboard Replacement: шаг 5, изображение 1 из 2 Logitech M185 Wireless Mouse Motherboard Replacement: шаг 5, изображение 2 из 2
      • Remove the scroll wheel from the motherboard.
      • Before you insert your new motherboard, remember to attach the scroll wheel to it.
      Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
2 человек успешно провели ремонт по этому руководству.
Robert
Участник с: 09/09/24
201 Репутация
1 руководство автора
Команда
CSU Los Angeles, Team 2-5, Kershman Fall 2024 Участник CSU Los Angeles, Team 2-5, Kershman Fall 2024
CSULA-KERSHMAN-F24S2G5
4 членов
Автор 1 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 19
За последние 30 дней: 80
За всё время: 1,454
