MNT Reform CPU Module Replacement
Выберете то, что вам нужно
  1. MNT Reform CPU Module Replacement, Remove Bottom Plate Screws: шаг 1, изображение 1 из 1
    • Remove the following screws securing the transparent acrylic bottom plate to the main box:
    • Ten M2×6mm silver Phillips screws
    Спросите у FixBot
    Добавить комментарий
  2. MNT Reform CPU Module Replacement, Remove Bottom Plate: шаг 2, изображение 1 из 1
    • Lift the bottom plate and set it aside.
    • Before servicing anything on the inside, make sure to remove all battery cells.
    Спросите у FixBot
  3. MNT Reform CPU Module Replacement, Remove Battery Cells: шаг 3, изображение 1 из 2 MNT Reform CPU Module Replacement, Remove Battery Cells: шаг 3, изображение 2 из 2
    • Pull out the eight battery cells one by one, and set them aside safely.
    • Do not use a metal tool to remove the batteries. You may accidentally short-circuit the metal pins of the battery holders.
    • When replacing the batteries, pay attention to the polarity! Inserting a cell the wrong way in will damage your device.
    • The circuit board indicates the + and - orientation for each cell.
    Спросите у FixBot
  4. MNT Reform CPU Module Replacement, Remove Heatsink Screws: шаг 4, изображение 1 из 1
    • Remove the following screws securing the heatsink:
    • Four M2×12 Philips screws
    Спросите у FixBot
  5. MNT Reform CPU Module Replacement, Remove the Heatsink: шаг 5, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    • Gently pull the heatsink up.
    • Take care not to lose the four cylindrical plastic spacers supporting the heatsink.
    • When replacing the heatsink, remember to place the spacers over the screw holes before screwing down the heatsink. It may be helpful to use tweezers to align the spacers if placing the heatsink on top shifted them.
    • When replacing the heatsink into the laptop, you will need to apply new thermal paste. We have a thermal paste guide that makes replacing the thermal compound easy.
    • If you need to remove the heatsink frequently, it is possible to replace the thermal paste with a 0.5mm thermal pad instead.
    Спросите у FixBot
  6. MNT Reform CPU Module Replacement, Disconnect CPU Module Ribbon Cable: шаг 6, изображение 1 из 2 MNT Reform CPU Module Replacement, Disconnect CPU Module Ribbon Cable: шаг 6, изображение 2 из 2
    • Gently lift the black tab on the ribbon cable connector, then slide the ribbon cable out.
    Спросите у FixBot
  7. MNT Reform CPU Module Replacement, Release CPU Module: шаг 7, изображение 1 из 1
    • Release the tabs on each side of the CPU module by pulling them at the same time.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up, similarly to a RAM stick on other laptop computers.
    Спросите у FixBot
  8. MNT Reform CPU Module Replacement, Remove CPU Module: шаг 8, изображение 1 из 1
    • Pull the CPU module out of its socket on the motherboard.
    • To avoid damaging its socket on the motherboard, do not excessively lift the free end of the CPU module.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order. Don't forget to re-apply new thermal paste.
Ensure that no cables are squeezed when replacing the bottom plate. Don’t overtighten screws.
Еще один человек закончил это руководство.
Neelfyn
Участник с: 05/13/14
981 Репутация
Автор 9 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 3
За последние 30 дней: 23
За всё время: 935
