MacBook Air 11" Early 2015 Logic Board Replacement
Выберете то, что вам нужно
  1. MacBook Air 11" Early 2015 Logic Board Replacement, Lower Case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    Купить
    • Shut down and close your computer. Lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
    When you say:
    Do the 8mm & 2.5mm dimensions refer to the LENGTH of those screws, or the size of the pentalobe? That is, are there other sizes of pentalobe drivers like there are for hex, phillips and torx? When only one dimension is provided, it is usually the socket/driver size, not the screw length, maybe since the length cannot be seen when the screw is installed.
    Can I suggest that you clarify your instructions so folks are confident they are only in need of _one_ pentalobe driver?
    Nerdily yours,
    Larry (whose iPhone 4S can now get through a day without 6 recharges thanks to ifixit.com ;-)
    larryleveen - Ответить
    The 8mm and 2.5mm are the length of the screws. One pentalobe P5 screwdriver suffices for all the screws (P5 is implicitly the size of the pentalobe screw heads).
    Michael Welham -
    I sourced all the parts from ifixit, plus a magnetic project mat which I found to be very useful for organising the teardown and reassembly.
    Allen - Ответить
    The magnetic mat is
    GERARD SZAREK -
    Keep the 2.5mm tiny screws away from the MagSafe connector as they will be attracted and sucked in to the magnet.
    Frank O'Carroll - Ответить
    A tip an old bench tech taught me that has saved me many times: I put clear “Scotch” tape over the case screws as they became “free”. The tape kept them in place while I lifted the lid off, cleaned it etc.
    Michael Mee - Ответить
    Thank you for a really smart tip! I will be using that countless more times!
    Lilljedahl -
    I’m confused about internet recovery and installing MacOS. Is all of this done before placing in the new ssd card or after. I don’t have any files that I would like to safe/transfer, is all of this necessary, if I don’t do it before placing new ssd, will I still be able to instal/upgrade macOS afterwards.
    It’s an old Mac and now it won’t start or charge, I know I will have to replace battery and put new battery first and turn on Mac before doing the ssd stuff. Since it won’t effing start.
    I’m really clueless about backing up old ssd, since I don’t need any files, besides MacOS(software) ,and is that related to the ssd?
    AMG - Ответить
    The answer to your question: You need to insert your SSD into the computer before internet recovery. If you start the recovery before inserting SSD, it won’t affect the setup, you won’t damage anything. But your SSD will not be detected (as there isn’t one inserted.)
    Also, a little tip: If you bought a used SSD, go into Disk Utility and format the drive with the highest security level to permanently remove all of the previous files.
    Also a FYI: Internet Recovery will load up Mac OS X 10.9.5 Mavericks, so I would recommend making a recovery drive from a Big Sur (or desired version) through another Mac, and a USB. You can visit this support doc: https://support.apple.com/en-us/HT201372
    Hope this helps! -Dan
    danielwen -
    I got a macbook air with a damaged and swollen battery. I could remove all screws, except one 2,5 mm screw. I’m afraid it got damaged while attempting to remove it, I have no grip with the P5 pentalobe screwdriver. How can I proceed?
    Robert Hermans - Ответить
    Hi Robert!
    Try some techniques found in this stripped screw removal guide. Good luck!
    Arthur Shi -
    Hello I have a macbook air they are say they do not have parts for my laptop macbook air 11 inches 2013 mid need to replace battery which one to buy
    vensilver - Ответить
    Hello! This is the part you want—maybe we’re not able to ship it to you if you’re out of the United States. The battery in your MacBook Air should be the same for all 11” between mid-2011 to early-2015.
    Arthur Shi -
    The smaller screws went in more easily when I put back all the screws along the hinge edge first.
    Rachel Slatkin - Ответить
  2. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 2, изображение 1 из 1
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Early 2015 Logic Board Replacement, Battery Connector: шаг 3, изображение 1 из 2 MacBook Air 11" Early 2015 Logic Board Replacement, Battery Connector: шаг 3, изображение 2 из 2
    • In this step you will disconnect the battery to help avoid shorting out any components during service.
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally bend back and make contact with its socket.
    When reassembling the connector wire needs to be bent to fit.
    GERARD SZAREK - Ответить
  4. MacBook Air 11" Early 2015 Logic Board Replacement, I/O Board Cable: шаг 4, изображение 1 из 2 MacBook Air 11" Early 2015 Logic Board Replacement, I/O Board Cable: шаг 4, изображение 2 из 2
    • Use the flat end of a spudger to pry the left and right I/O board cable connectors up off their respective sockets on the I/O board.
  5. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 5, изображение 1 из 1
    • Lift and remove the I/O board cable.
  6. MacBook Air 11" Early 2015 Logic Board Replacement, Fan: шаг 6, изображение 1 из 2 MacBook Air 11" Early 2015 Logic Board Replacement, Fan: шаг 6, изображение 2 из 2
    • Use the tip of a spudger to carefully push on each side of the iSight camera cable connector to loosen it out of its socket on the logic board.
    • We recommend you gently "walk" the connector out of its socket.
  7. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 7, изображение 1 из 2 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 7, изображение 2 из 2
    • Peel the iSight camera cable up off the adhesive securing it to the fan.
    Additionally it seems as though the display assembly I have is from an earlier model with a different built in camera. I don’t care if the camera works, could I chop the cord, power it up, and just no have a working camera?
    Aidan - Ответить
  8. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 8, изображение 1 из 2 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 8, изображение 2 из 2
    • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    Be sure you understand how the connector works, if you have to go and look up “apple ZIF connector” and watch a video. The one above flips up from where the tool is pointing at. Again do not damage the connector. Click the second picture to see this!
    joe - Ответить
  9. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 9, изображение 1 из 1
    • Remove the following three screws securing the fan to the upper case:
    • Two 5.5 mm T5 Torx screws
    • One 4.6 mm T5 Torx screw
    • In some models this is a 3.6 mm T5 Torx screw.
  10. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 10, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 10, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 10, изображение 3 из 3
    • Lift, but do not remove the fan out of its recess in the upper case.
    • Carefully pull the fan ribbon cable out of its socket as you remove the fan from the Air.
  11. MacBook Air 11" Early 2015 Logic Board Replacement, Logic Board Assembly: шаг 11, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement, Logic Board Assembly: шаг 11, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement, Logic Board Assembly: шаг 11, изображение 3 из 3
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth card, and move them out of the way.
    Be very careful. When I did this - just as in the photo - I prised the top of the antenna connector off from the bottom of it, leaving me with only one functioning antenna.
    Andrew Wainwright - Ответить
    You can usually pull the airport card out of the socket and let it dangle by the attached wires. They can be frustrating to re-attach.
    maccentric - Ответить
    This seems like great advice! Any more details would be greatly appreciated
    Colleen V -
    Just walk it out slowly. The cables don’t have a lot of slack, so if you pull too hard on the card it may yank the cables out of their sockets, or worse, when it comes free.
    maccentric -
    When I did this, one antenna connection broke off and the other will not reattach for love nor money. I have not idea how to fix it. I’d try a blob of solder if my fingers were the size of matchsticks! Haha
    Andrew Aldis - Ответить
  12. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 12, изображение 1 из 1
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  13. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 13, изображение 1 из 1
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
  14. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 14, изображение 1 из 2 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 14, изображение 2 из 2
    • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
    • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
    Did it wrong to begin with by taking the complete socket away and not just the insert. Now I can’t get the socket back on the logic board contacts. Any ideas?
    John Lillywhite - Ответить
    I have the same issue! Did you find a solution?
    Alexis Townsend -
    It's safer and easier to use the tip of a spudger to depress the catch located on the top of the socket. Push down and towards the connector and it will ease itself out without damage.
    jgreenb2 - Ответить
  15. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 15, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 15, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 15, изображение 3 из 3
    • Use the tip of a spudger to de-route the antenna cables from their notches in the logic board.
    I ordered a used display and the antennae wires are way too short to make it in to their respective ports (either of them). Am I missing something? Anything I should know to do a splice?
    -Aidan
    Aidan - Ответить
    I did not disconnect the tiny gold terminals, they are too fragile. I just slide out the card but leave it connected to the antenna, if replacing the logic board is the aim.
    Jurgen - Ответить
    They're not clicking back in when I reassemble it
    Carson Banker - Ответить
  16. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 16, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 16, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 16, изображение 3 из 3
    • Gently push the tip of a spudger under the black plastic flap stuck to the display data cable lock to make the lock pop upward and away from the socket.
    • While holding the lock away from the socket, gently pull the display data cable out of its socket.
    • Do not pull upward on the display data cable as you disconnect it, as its socket may break off the logic board.
  17. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 17, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 17, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 17, изображение 3 из 3
    • Use the tip of a spudger to pry under the speaker cable connector, lifting it straight up from its socket.
    • De-route the cable from its notch in the logic board.
  18. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 18, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 18, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 18, изображение 3 из 3
    • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
  19. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 19, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 19, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 19, изображение 3 из 3
    • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
    • Pull the keyboard backlight ribbon cable out of its socket.
  20. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 20, изображение 1 из 1
    • Remove the single 2.9 mm T5 Torx screw securing the AirPort/Bluetooth card to the logic board.
  21. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 21, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 21, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 21, изображение 3 из 3
    • Slightly lift the free end of the AirPort/Bluetooth board and pull it out of its socket on the logic board.
    • To avoid damaging its socket on the logic board, do not excessively lift the free end of the AirPort/Bluetooth card.
  22. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 22, изображение 1 из 1
    • Remove the three 3.6 mm T5 Torx screws securing the logic board to the upper case.
    • In some models these are 3.1 mm T5 Torx screws.
  23. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 23, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 23, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 23, изображение 3 из 3
    • Gently lift the logic board assembly from the heat sink end and pull it away from the port side of the case to remove it from the Air.
    • When replacing the logic board, insert the board's rubber edge under the port-side rubber gasket, then lower the board into place.
    There's a screw that's connecting the logic board to the casing that has to be removed before sliding the logic board out. I found that out the hard way.
    Andrea Carter - Ответить
    Only 3 were in mine, where did you find another screw?
    maccentric -
    When replacing the logic board, make sure you haven’t trapped an antenna cable underneath. Easy to sort it out now, much more annoying if you only discover it after screwing everything down first!
  24. MacBook Air 11" Early 2015 Logic Board Replacement, Logic Board: шаг 24, изображение 1 из 1
    • Remove the four 2.5 mm T5 Torx screws securing the heat sink to the logic board.
  25. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 25, изображение 1 из 1
    • If the heat sink seems to be stuck to the logic board after removing all four screws, use a spudger to carefully separate the heat sink from the faces of the CPU.
    • Remove the heat sink from the logic board.
    • When reinstalling the heat sink, be sure to apply a new layer of thermal paste. If you have never applied thermal paste before, we have a guide that makes it easy.
  26. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 26, изображение 1 из 1
    • Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
  27. MacBook Air 11" Early 2015 Logic Board Replacement: шаг 27, изображение 1 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 27, изображение 2 из 3 MacBook Air 11" Early 2015 Logic Board Replacement: шаг 27, изображение 3 из 3
    • Lift the free end of the SSD just enough to get a good hold of it.
    • Do not excessively lift the end of the SSD.
    • Pull the drive straight out of its socket and remove it from the logic board.
    • When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
    Help pls, my 2014 MacBook Air suddenly won’t charge or turn on. After I shut it down despite trying the smc reset, disconnecting and connecting the battery and tried the smc reset but it wouldn’t budge. Tested the charger and it’s working fine but will not show any light indication when connected to my laptop and would not turn on as well.
    Olivia Ngrim - Ответить
    I finally got laptop diagnosed and it was the ic chip. Got it fixed and the laptop was working, the technician also suggested I get a new battery which I did as my old one was tossed. but camera and sound stopped working completely and the new battery stopped charging too. I checked the battery health tried all troubleshooting like nvram and smc reset but nothing worked. so I took it back and he told me to manage it that way. But I decided to get a new logic board on AliExpress for 70usd used instructions above to install myself. Finally the camera was working but laptop became slow with fan running in high speed non stop. Meanwhile the sound ain’t working still so I contacted the motherboard surplier and he suggested I a new I/o audio jack board which I did. And boom sound is back but fan still works on high speed, system is still slow and battery not charging despite diagnostics showing n battery health is normal.
    Olivia Ngrim -
    So continuation of my comment above. Apparently what was causing my fan to be running on high speed was my battery. My battery was a fake one. I was duped by the seller. If I check the battery health it keeps saying normal and not charging. I decided to try a different battery and boom the fan was quite, laptop speed was back and the Mac was operating as good as new. So I decided to get a new battery and it solved all my problem.
    Olivia Ngrim -
    Hola lo necesito para la serie C02Q4HJTGFWM de una MAC BOOK AIR 11 PULGADAS 2015, es la indicada??
    Patricia Arguello Garcia - Ответить
    I have provided the full story to my MacBook shutdown and won’t turn on here MacBook shut down and won’t turn on or charge repair suggestions plus tips on fan on high speed, no sound and slow Mac experience and how I got it fixed
Заключение
15 участников успешно повторили данное руководство.
Sam Goldheart
Участник с: 10/18/12
465 970 Репутация
Автор 538 руководств
Команда
iFixit Участник iFixit
Staff
136 членов
Автор 17 299 руководств
3 Комментариев
Thank you so much! This actually wasn't difficult at all, especially following your guide! I was able to fix my dad's computer with a replacement logic board. He's going to be super happy about this!
Robin H - Ответить
I don’t see a difference between this and the guide for the Early 2014 11” MacBook Air. Is there a difference or can I replace my dead 2014 Air’s Logic Board with a 2015? That Thunderbolt 2 port would be really helpful!
vnangia - Ответить
Where can one order a Logic board?
Buntu Mfaku - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 23
За последние 30 дней: 93
За всё время: 17,184
