Merch Source Projector Entertainment II Cooling Fan Replacement
Выберете то, что вам нужно
    1. Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: шаг 1, изображение 1 из 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Outer Casing: шаг 1, изображение 2 из 2
      • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
      Спросите у FixBot
      Добавить комментарий
    2. Merch Source Projector Entertainment II Cooling Fan Replacement: шаг 2, изображение 1 из 1
      • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
      • The bottom right panel screw does not come completely out the panel door.
      Спросите у FixBot
    3. Merch Source Projector Entertainment II Cooling Fan Replacement: шаг 3, изображение 1 из 2 Merch Source Projector Entertainment II Cooling Fan Replacement: шаг 3, изображение 2 из 2
      • Using your hands, gently pry the top and bottom of the projector casing apart.
      Спросите у FixBot
    1. Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: шаг 4, изображение 1 из 2 Merch Source Projector Entertainment II Cooling Fan Replacement, Cooling Fan: шаг 4, изображение 2 из 2
      • Locate the 80 mm fan and slide upward straight out of the housing.
      Спросите у FixBot
    2. Merch Source Projector Entertainment II Cooling Fan Replacement: шаг 5, изображение 1 из 2 Merch Source Projector Entertainment II Cooling Fan Replacement: шаг 5, изображение 2 из 2
      • Unsolder the red and black connections off of the motherboard.
      • If there are zip ties around the cables, they will need to be cut to remove the fan.
      • Need some help? Follow this guide to learn soldering basics.
      • While soldering the metal connections will get very hot. Never touch the iron with your hand.
      • Make sure that the projector is fully turned off and not plugged in. Allow up to 30 minutes for projector to cool down.
      • If there is hot glue within the connection in on the motherboard, you will need to peel it off simply using your fingers.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Stephanie
Участник с: 01/08/15
282 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 18-3, Maness Winter 2015 Участник Cal Poly, Team 18-3, Maness Winter 2015
CPSU-MANESS-W15S18G3
3 членов
Автор 8 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 11
За последние 30 дней: 27
За всё время: 2,815
