Microsoft Surface Book 2 15" Front Camera Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Book 2 15" Front Camera Replacement, Motherboard: шаг 1, изображение 1 из 1
    • Open the laptop, then orient it so the touchpad is on your left.
    • Starting at the hinge, count six holes up on the tablet portion of the laptop.
    Спросите у FixBot
    Добавить комментарий
  2. Microsoft Surface Book 2 15" Front Camera Replacement: шаг 2, изображение 1 из 2 Microsoft Surface Book 2 15" Front Camera Replacement: шаг 2, изображение 2 из 2
    • Take a paper clip and unfold it.
    • Place the paper clip in the sixth hole and push until you hear a click.
    • Once you hear the click, lift up on the right side of the tablet from the base until it separates.
    • After the right side has been detached, lift up the left side as well.
    Спросите у FixBot
  3. Microsoft Surface Book 2 15" Front Camera Replacement: шаг 3, изображение 1 из 1
    • Place the tablet on a flat surface.
    • Using a heat gun or iOpener, heat up the edges of the screen to soften up the adhesive.
    Спросите у FixBot
  4. Microsoft Surface Book 2 15" Front Camera Replacement: шаг 4, изображение 1 из 1
    • Using a plastic pick, slice underneath the edge of the screen.
    • Use a suction cup to carefully lift the screen and create separation between the screen and frame.
    • Take care not to insert the tool too far to avoid cutting the ribbon cables.
    • Slowly make your way around the screen, and carefully cut the adhesive that secures the screen to the frame.
    • Don't use a metal tool, that could damage the screen or internal parts.
    Спросите у FixBot
  5. Microsoft Surface Book 2 15" Front Camera Replacement: шаг 5, изображение 1 из 2 Microsoft Surface Book 2 15" Front Camera Replacement: шаг 5, изображение 2 из 2
    • Lift up the screen.
    • Detach the ribbon cables connecting the underside of the screen to the motherboard.
    Спросите у FixBot
  6. Microsoft Surface Book 2 15" Front Camera Replacement: шаг 6, изображение 1 из 2 Microsoft Surface Book 2 15" Front Camera Replacement: шаг 6, изображение 2 из 2
    • Use a T3 Torx screwdriver to remove eleven 4 mm screws from the motherboard.
    • Use a T3 Torx screwdriver to remove the ten 2.5 mm screws from the top bar.
    Спросите у FixBot
  7. Microsoft Surface Book 2 15" Front Camera Replacement: шаг 7, изображение 1 из 1
    • Once the screws are removed from the top bar, gently lift up and remove it.
    • Be careful not to damage any ribbon cables or wires.
    • Gently lift up on the motherboard to remove it.
    Спросите у FixBot
  8. Microsoft Surface Book 2 15" Front Camera Replacement, Front Camera: шаг 8, изображение 1 из 1
    • After lifting the motherboard, locate the two cameras near the center of the motherboard.
    • Unplug front camera (right side) from the motherboard (lift carefully).
    Спросите у FixBot
Заключение
Colton Almeida
Участник с: 03/13/23
172 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 3-3, Petersen Spring 2023 Участник UMass Dartmouth, Team 3-3, Petersen Spring 2023
UMASSD-PETERSEN-S23S3G3
4 членов
Автор 23 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 34
За всё время: 830
