Microsoft Surface Pro Battery Replacement
Выберете то, что вам нужно
  1. Microsoft Surface Pro Battery Replacement, Heat edges of display: шаг 1, изображение 1 из 1
    • Use a heated iOpener or a heat gun to heat the edges of the display and soften its adhesive.
    • If you're using an iOpener it may take several cycles of reheating and applying it to soften the adhesive enough. Every time, let the iOpener sit on the display for at least a minute before reheating to allow the adhesive to soften.
    Спросите у FixBot
    Добавить комментарий
  2. Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: шаг 2, изображение 1 из 3 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: шаг 2, изображение 2 из 3 Microsoft Surface Pro Battery Replacement, Lift display and cut adhesive: шаг 2, изображение 3 из 3
    • Apply a suction cup as close as possible to the edge of the display.
    • Use the suction cup to lift the edge of the display enough to insert an opening pick under the edge.
    • Slide the opening pick all the way around the edges of the display to cut through the adhesive on the bezel.
    • Do not insert the opening pick past the bezel of the display—you may permanently damage the display.
    • The bezel is much thinner on the bottom of the display, which is the side with the Windows logo. To avoid damage, don't poke too deep with the opening pick on the bottom edge.
    • Ribbon cables and a circuit board are approx. 0.6 cm from the edge of the glass.
    • Be very careful and move slowly during this step. The display is fragile and will crack if too much force is applied against it. If your tools seem stuck, apply more heat to further soften the adhesive.
    Спросите у FixBot
  3. Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: шаг 3, изображение 1 из 3 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: шаг 3, изображение 2 из 3 Microsoft Surface Pro Battery Replacement, Disconnect/peel off ribbon cables: шаг 3, изображение 3 из 3
    • Starting from the top edge, lift the display slightly.
    • If you feel any resistance, use heat and an opening pick to slice through any remaining adhesive.
    • Before completely removing the display:
    • Disconnect the three display cables.
    • Gently peel from the frame 2 orange ribbon cables that are glued to it, as those should stay with the display. (e.g. use a thin plastic card to separate them)
    Спросите у FixBot
  4. Microsoft Surface Pro Battery Replacement, Removal: шаг 4, изображение 1 из 1
    • Remove the display.
    Спросите у FixBot
  5. Microsoft Surface Pro Battery Replacement, Battery: шаг 5, изображение 1 из 2 Microsoft Surface Pro Battery Replacement, Battery: шаг 5, изображение 2 из 2
    • Using a T3 Torx screwdriver, remove a total of 23 screws from the screen bezel of the Surface Pro.
    Спросите у FixBot
  6. Microsoft Surface Pro Battery Replacement: шаг 6, изображение 1 из 1
    • Lift the screen bezel from the Surface Pro.
    Спросите у FixBot
  7. Microsoft Surface Pro Battery Replacement: шаг 7, изображение 1 из 2 Microsoft Surface Pro Battery Replacement: шаг 7, изображение 2 из 2
    • Remove the 6 T5 screws from the panels on each side of the frame.
    • Remove 23 T2 screws from the panels.
    Спросите у FixBot
  8. Microsoft Surface Pro Battery Replacement: шаг 8, изображение 1 из 1
    • Lift both metal panels from the frame.
    Спросите у FixBot
  9. Microsoft Surface Pro Battery Replacement: шаг 9, изображение 1 из 2 Microsoft Surface Pro Battery Replacement: шаг 9, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Using tweezers, gently pull the eight orange ribbon cables from their sockets.
    Спросите у FixBot
  10. Microsoft Surface Pro Battery Replacement: шаг 10, изображение 1 из 2 Microsoft Surface Pro Battery Replacement: шаг 10, изображение 2 из 2
    • Unscrew the 17 T5 torx screws on the mother board with the T5 torx screw driver
    Спросите у FixBot
  11. Microsoft Surface Pro Battery Replacement: шаг 11, изображение 1 из 1
    • Once all screws are removed, gently lift up the logic board with your hands to pull it out.
    Спросите у FixBot
  12. Microsoft Surface Pro Battery Replacement: шаг 12, изображение 1 из 2 Microsoft Surface Pro Battery Replacement: шаг 12, изображение 2 из 2
    • Use your hands to pry off the entire battery pack with enough force to overcome the glue keeping the batteries in place.
    Спросите у FixBot
Заключение
40 человек успешно провели ремонт по этому руководству.
Jonathan Choi
Участник с: 10/09/13
1 090 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 8-20, Regan Fall 2013 Участник Cal Poly, Team 8-20, Regan Fall 2013
CPSU-REGAN-F13S8G20
4 членов
Автор 16 руководств
24 Комментарии к руководству
Thank you for that awesome guide!
Do you know where can i buy a battery for surface pro 2??
Thanks
John john - Ответить Поделиться
I am also trying to find out where to acquire the Surface Pro batteries...???
Tristan Irons - Ответить Поделиться
im also looking for a surface pro replacement battery.
Lekan Adesanya - Ответить Поделиться
I just bought one for $70 at a site called newpower99.com... should be here in 2 days. I have no idea if it will work, but it says it comes with a toolkit to replace it. I hope it works.
Matt - Ответить Поделиться
Did you have success installing the Newegg battery?
asmac - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 85
За последние 7 дней: 247
За последние 30 дней: 872
За всё время: 270,321
