Введение
This guide will take you through the process involved with installing an antenna. De-soldering and soldering will be required.
Выберете то, что вам нужно
Lift up all four rubber pads on the bottom of the router with the plastic opening tool.
Remove the clear plastic casing by lifting it straight up from the router.
Separate the motherboard from the top shell by lifting it straight up from the router.
Peel off the yellow tape holding the wires.
Set the tape aside on a clean surface so that it can be reused.
3 человек успешно провели ремонт по этому руководству.
