Nexus 9 Power and Volume Buttons Replacement
Выберете то, что вам нужно
    1. Nexus 9 Power and Volume Buttons Replacement, Rear Case: шаг 1, изображение 1 из 3 Nexus 9 Power and Volume Buttons Replacement, Rear Case: шаг 1, изображение 2 из 3 Nexus 9 Power and Volume Buttons Replacement, Rear Case: шаг 1, изображение 3 из 3
      • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
      • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
      Спросите у FixBot
      Добавить комментарий
    1. Nexus 9 Power and Volume Buttons Replacement, Battery: шаг 2, изображение 1 из 2 Nexus 9 Power and Volume Buttons Replacement, Battery: шаг 2, изображение 2 из 2
      • Carefully peel up the copper shielding with your fingers.
      • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
      Спросите у FixBot
    2. Nexus 9 Power and Volume Buttons Replacement: шаг 3, изображение 1 из 1
      • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
      • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
      • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
      Спросите у FixBot
    3. Nexus 9 Power and Volume Buttons Replacement: шаг 4, изображение 1 из 1
      • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
      • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
      Спросите у FixBot
    4. Nexus 9 Power and Volume Buttons Replacement: шаг 5, изображение 1 из 1
      • The battery should now lift free of the tablet.
      Спросите у FixBot
    1. Nexus 9 Power and Volume Buttons Replacement, Antenna Board: шаг 6, изображение 1 из 2 Nexus 9 Power and Volume Buttons Replacement, Antenna Board: шаг 6, изображение 2 из 2
      • This step is not necessary if you have already removed the battery.
      Спросите у FixBot
    2. Nexus 9 Power and Volume Buttons Replacement: шаг 7, изображение 1 из 1
      • Unscrew the three 3 mm Torx T5 screws on the antenna board.
      • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
      Спросите у FixBot
    3. Nexus 9 Power and Volume Buttons Replacement: шаг 8, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
      • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
      • The antenna board should now lift free of the motherboard.
      Спросите у FixBot
    1. Nexus 9 Power and Volume Buttons Replacement, Motherboard: шаг 9, изображение 1 из 2 Nexus 9 Power and Volume Buttons Replacement, Motherboard: шаг 9, изображение 2 из 2
      • Remove the three 3 mm T5 Torx screws.
      • Remove the five 2 mm Phillips #000 screws.
      Спросите у FixBot
    2. Nexus 9 Power and Volume Buttons Replacement: шаг 10, изображение 1 из 2 Nexus 9 Power and Volume Buttons Replacement: шаг 10, изображение 2 из 2
      • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
      • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
      • Pull up the ribbon connector with your fingers.
      Спросите у FixBot
    3. Nexus 9 Power and Volume Buttons Replacement: шаг 11, изображение 1 из 1
      • Gently lift the motherboard up from the device.
      Спросите у FixBot
    4. Nexus 9 Power and Volume Buttons Replacement: шаг 12, изображение 1 из 1
      Спросите у FixBot
    1. Nexus 9 Power and Volume Buttons Replacement, Power and Volume Buttons: шаг 13, изображение 1 из 1
      • Using your tweezers, gently grasp the clear rubber backing and pull outward. The buttons should come free.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Alden Simmer
Участник с: 02/05/15
370 Репутация
1 руководство автора
Команда
Cal Poly, Team 19-11, Maness Winter 2015 Участник Cal Poly, Team 19-11, Maness Winter 2015
CPSU-MANESS-W15S19G11
5 членов
Автор 9 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 7
За последние 30 дней: 38
За всё время: 2,358
