Nike SportWatch GPS Unit Replacement
Выберете то, что вам нужно
    1. Nike SportWatch GPS Unit Replacement, GPS Unit: шаг 1, изображение 1 из 1
      • Using a size #000 Phillips screwdriver, remove the six 5 mm screws on the back of the device.
      Спросите у FixBot
      Добавить комментарий
    2. Nike SportWatch GPS Unit Replacement: шаг 2, изображение 1 из 1
      • Then, gently pull the watch band and front screen apart.
      Спросите у FixBot
    3. Nike SportWatch GPS Unit Replacement: шаг 3, изображение 1 из 1
      • Using a size #000 Phillips screwdriver, remove the two 2.5 mm screws on the main board.
      Спросите у FixBot
    4. Nike SportWatch GPS Unit Replacement: шаг 4, изображение 1 из 1
      • Carefully, use the blue plastic opening tool to pry the main board out of the front panel.
      • Use extreme care when handling the ribbon cable. Avoid twisting or pulling it, as it is delicate and cannot be removed or replaced if damaged.
      Спросите у FixBot
    5. Nike SportWatch GPS Unit Replacement: шаг 5, изображение 1 из 1
      • Using the spudger, remove the orange tape that covers the wire for the GPS.
      Спросите у FixBot
    6. Nike SportWatch GPS Unit Replacement: шаг 6, изображение 1 из 1
      • Using the soldering iron, break the wire connecting the GPS to the main board at the connector.
      • When desoldering the GPS wire, set the soldering iron to a moderate heat level (around 350°C/662°F). To prevent damage, avoid prolonged contact with the board. For detailed instructions, refer to the iFixit soldering guide.
      Спросите у FixBot
    7. Nike SportWatch GPS Unit Replacement: шаг 7, изображение 1 из 1
      • To reassemble, follow the steps in reverse order. Ensure all connections are secure, screws are tightened evenly, and no ribbon cables are pinched. Once complete, test the watch by powering it on and verifying GPS functionality in an open area.
      Спросите у FixBot
    8. Nike SportWatch GPS Unit Replacement: шаг 8, изображение 1 из 1
      • After reassembly, power on the watch and perform a GPS test outdoors in a clear area. Wait for the watch to acquire a signal to confirm the successful replacement.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Ian Eichorn
Участник с: 10/22/15
696 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015 Участник UMass Dartmouth, Team 5-8, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G8
3 членов
Автор 30 руководств
3 Комментарии к руководству
which GPS unit is it?
charles - Ответить Поделиться
what gps unit is it?
I would also like to know what GPS unit that is and if it is possible to find a replacement or a compatible unit?
avs4820 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 33
За всё время: 2,347
