Nikon D3100 Motherboard Replacement
Выберете то, что вам нужно
    1. Nikon D3100 Motherboard Replacement, LCD Screen: шаг 1, изображение 1 из 1
      • Use a Phillips #00 screwdriver for all of the screws.
      • Remove two of the 4mm screws indicated by the circles on the bottom side of the camera.
      Спросите у FixBot
      Добавить комментарий
    2. Nikon D3100 Motherboard Replacement: шаг 2, изображение 1 из 2 Nikon D3100 Motherboard Replacement: шаг 2, изображение 2 из 2
      • Remove four of the 3mm screws around the eye piece located on the top of the back panel, including the screw hidden behind the auto focus label.
      • Remove the 3mm screw behind the rubber grip on the top right of the back panel.
      Спросите у FixBot
    3. Nikon D3100 Motherboard Replacement: шаг 3, изображение 1 из 1
      • Peel back the rubber grip on the right side of the camera using a spudger.
      • You may need a heating pad to melt the glue holding the rubber grip to the camera. If using the heating pad, use caution and handle carefully.
      • Remove two of the 5mm screws under the rubber grip.
      Спросите у FixBot
    4. Nikon D3100 Motherboard Replacement: шаг 4, изображение 1 из 1
      • Remove two of the 4mm screws on the left side of the camera.
      Спросите у FixBot
    5. Nikon D3100 Motherboard Replacement: шаг 5, изображение 1 из 2 Nikon D3100 Motherboard Replacement: шаг 5, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Starting from the top, gently lift the back panel of the camera off. Slowly separate the back panel from the main body of the camera.
      • Be careful not to pull the panel out too fast or the ribbon may be damaged.
      • Carefully remove the ribbon using a spudger to lift up the connector and then use tweezers to pull out the ribbon.
      • Separate the back panel from the main body of the camera.
      Спросите у FixBot
    6. Nikon D3100 Motherboard Replacement: шаг 6, изображение 1 из 1
      • Be careful when separating the metal plate from the back panel because the speaker wire is connected to the metal plate. It can easily be torn if caution is not taken.
      • Remove nine of the 3mm screws connecting the metal plate to the plastic panel.
      Спросите у FixBot
    7. Nikon D3100 Motherboard Replacement: шаг 7, изображение 1 из 1
      • Remove the tape covering the ribbons. Be careful not to break the tape.
      Спросите у FixBot
    8. Nikon D3100 Motherboard Replacement: шаг 8, изображение 1 из 1
      • Remove the two ribbons connecting the LCD screen to the metal plate using the same method from Step 5.
      Спросите у FixBot
    9. Nikon D3100 Motherboard Replacement: шаг 9, изображение 1 из 1
      • Remove the old LCD screen from metal plate.
      Спросите у FixBot
    1. Nikon D3100 Motherboard Replacement, Motherboard: шаг 10, изображение 1 из 2 Nikon D3100 Motherboard Replacement, Motherboard: шаг 10, изображение 2 из 2
      • Use tweezers to gently lift the yellow tape from the back of the camera.
      Спросите у FixBot
    2. Nikon D3100 Motherboard Replacement: шаг 11, изображение 1 из 1
      • Use a plastic spudger to remove the 6 ribbons.
      • Be careful not to tear the ribbons.
      Спросите у FixBot
    3. Nikon D3100 Motherboard Replacement: шаг 12, изображение 1 из 2 Nikon D3100 Motherboard Replacement: шаг 12, изображение 2 из 2
      • Remove the plug located on the top-right side of the camera.
      • Remove the plug located on the top-left side of the camera.
      Спросите у FixBot
    4. Nikon D3100 Motherboard Replacement: шаг 13, изображение 1 из 1
      • Use a Philips #00 Screwdriver to remove the five 3 mm screws marked in the image.
      Спросите у FixBot
    5. Nikon D3100 Motherboard Replacement: шаг 14, изображение 1 из 2 Nikon D3100 Motherboard Replacement: шаг 14, изображение 2 из 2
      • Gently pull out the side wall of the camera so that the motherboard comes out easier.
      • Do not pull too hard or you will risk breaking the plastic.
      Спросите у FixBot
    6. Nikon D3100 Motherboard Replacement: шаг 15, изображение 1 из 1
      • Be careful while lifting the motherboard because there is one more ribbon attached.
      • Gently lift the motherboard to separate it from the back of the camera.
      • Use a plastic spudger to detach the ribbon.
      Спросите у FixBot
    7. Nikon D3100 Motherboard Replacement: шаг 16, изображение 1 из 1
      • Replace the motherboard.
      Спросите у FixBot
Заключение
6 человек успешно провели ремонт по этому руководству.
Jet Mejia
Участник с: 09/26/16
686 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 14-1, Eyestone Fall 2016 Участник USF Tampa, Team 14-1, Eyestone Fall 2016
USFT-EYESTONE-F16S14G1
3 членов
Автор 21 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 23
За последние 30 дней: 103
За всё время: 6,758
