Введение
This guide will help to you access your viewfinder in your Nikon D40 and replace the viewfinder.
Выберете то, что вам нужно
Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
Use a spudger to keep the upper body separate from the printed circuit board.
Wiggle the plastic eyepiece out of the frame. This may require some force.
2 человек успешно провели ремонт по этому руководству.
