Nintendo 3DS Power Button Replacement
Выберете то, что вам нужно
    1. Nintendo 3DS Power Button Replacement, Loosen the rear screws: шаг 1, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      Phillips #00 Screwdriver
      $5.49
      • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
      • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
      • The screws are held in place by locking washers, and will not come out of the back cover.
      Спросите у FixBot
      Добавить комментарий
    2. Nintendo 3DS Power Button Replacement, Remove the rear cover: шаг 2, изображение 1 из 2 Nintendo 3DS Power Button Replacement, Remove the rear cover: шаг 2, изображение 2 из 2
      • Hold the device in one hand and turn it over.
      • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
      • Flip the 3DS over again so that the back cover is facing up.
      • Pull the back cover up and away from the rest of the device to remove it.
      Спросите у FixBot
    1. Nintendo 3DS Power Button Replacement, Battery: шаг 3, изображение 1 из 3 Nintendo 3DS Power Button Replacement, Battery: шаг 3, изображение 2 из 3 Nintendo 3DS Power Button Replacement, Battery: шаг 3, изображение 3 из 3
      • Insert a plastic opening tool into the notch in the lower case above the battery.
      • Pry the battery up with the plastic opening tool.
      • Grab the top edge of the battery and lift it out of the lower case.
      Спросите у FixBot
    1. Nintendo 3DS Power Button Replacement, Lower Case: шаг 4, изображение 1 из 1
      • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
      • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
      • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
      • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
      Спросите у FixBot
    2. Nintendo 3DS Power Button Replacement: шаг 5, изображение 1 из 3 Nintendo 3DS Power Button Replacement: шаг 5, изображение 2 из 3 Nintendo 3DS Power Button Replacement: шаг 5, изображение 3 из 3
      • Lift the bottom edge of the lower case off the rest of the 3DS.
      • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
      • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
      • Remove the lower case from the device.
      Спросите у FixBot
    1. Nintendo 3DS Power Button Replacement, Circle Pad Joystick: шаг 6, изображение 1 из 1
      • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
      Спросите у FixBot
    2. Nintendo 3DS Power Button Replacement: шаг 7, изображение 1 из 3 Nintendo 3DS Power Button Replacement: шаг 7, изображение 2 из 3 Nintendo 3DS Power Button Replacement: шаг 7, изображение 3 из 3
      • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
      • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
      Спросите у FixBot
    3. Nintendo 3DS Power Button Replacement: шаг 8, изображение 1 из 3 Nintendo 3DS Power Button Replacement: шаг 8, изображение 2 из 3 Nintendo 3DS Power Button Replacement: шаг 8, изображение 3 из 3
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Lift the Circle Pad joystick off the motherboard.
      Спросите у FixBot
    4. Nintendo 3DS Power Button Replacement: шаг 9, изображение 1 из 2 Nintendo 3DS Power Button Replacement: шаг 9, изображение 2 из 2
      • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
      • Use a spudger or screwdriver to lift the pads up and remove them from the device.
      Спросите у FixBot
    1. Nintendo 3DS Power Button Replacement, SD Board: шаг 10, изображение 1 из 1
      • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
      Спросите у FixBot
    2. Nintendo 3DS Power Button Replacement: шаг 11, изображение 1 из 2 Nintendo 3DS Power Button Replacement: шаг 11, изображение 2 из 2
      • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
      Спросите у FixBot
    3. Nintendo 3DS Power Button Replacement: шаг 12, изображение 1 из 3 Nintendo 3DS Power Button Replacement: шаг 12, изображение 2 из 3 Nintendo 3DS Power Button Replacement: шаг 12, изображение 3 из 3
      • Insert the flat end of a spudger between the SD board and the motherboard.
      • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
      • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
      • Once completely freed, lift the SD board straight off the motherboard.
      Спросите у FixBot
    1. Nintendo 3DS Power Button Replacement, Pry the Wi-Fi card up: шаг 13, изображение 1 из 2 Nintendo 3DS Power Button Replacement, Pry the Wi-Fi card up: шаг 13, изображение 2 из 2
      • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
      • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
      Спросите у FixBot
    2. Nintendo 3DS Power Button Replacement, Disconnect the Wi-Fi board: шаг 14, изображение 1 из 3 Nintendo 3DS Power Button Replacement, Disconnect the Wi-Fi board: шаг 14, изображение 2 из 3 Nintendo 3DS Power Button Replacement, Disconnect the Wi-Fi board: шаг 14, изображение 3 из 3
      • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
      • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
      • Remove the Wi-Fi board from the device.
      Спросите у FixBot
    1. Nintendo 3DS Power Button Replacement, Motherboard Assembly: шаг 15, изображение 1 из 2 Nintendo 3DS Power Button Replacement, Motherboard Assembly: шаг 15, изображение 2 из 2
      • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
      • Pull the microphone straight up out of the upper case.
      Спросите у FixBot
    2. Nintendo 3DS Power Button Replacement: шаг 16, изображение 1 из 3 Nintendo 3DS Power Button Replacement: шаг 16, изображение 2 из 3 Nintendo 3DS Power Button Replacement: шаг 16, изображение 3 из 3
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
      • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
      Спросите у FixBot
    3. Nintendo 3DS Power Button Replacement: шаг 17, изображение 1 из 2 Nintendo 3DS Power Button Replacement: шаг 17, изображение 2 из 2
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
      • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
      Спросите у FixBot
    4. Nintendo 3DS Power Button Replacement: шаг 18, изображение 1 из 3 Nintendo 3DS Power Button Replacement: шаг 18, изображение 2 из 3 Nintendo 3DS Power Button Replacement: шаг 18, изображение 3 из 3
      • Remove seven Phillips screws securing the motherboard to the upper case:
      • Four 2.5 mm gold screws
      • Two 3.5 mm black screws
      • One 2.5 mm silver screw
      • When you remove this screw the volume slider can fall out.
      • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
      Спросите у FixBot
    5. Nintendo 3DS Power Button Replacement: шаг 19, изображение 1 из 3 Nintendo 3DS Power Button Replacement: шаг 19, изображение 2 из 3 Nintendo 3DS Power Button Replacement: шаг 19, изображение 3 из 3
      • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
      • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
      Спросите у FixBot
    6. Nintendo 3DS Power Button Replacement: шаг 20, изображение 1 из 1
      • Remove the motherboard assembly from the rest of the device.
      Спросите у FixBot
    1. Nintendo 3DS Power Button Replacement, Power Button: шаг 21, изображение 1 из 1
      • Peel the silicone cover from the back of the power button.
      Спросите у FixBot
    2. Nintendo 3DS Power Button Replacement: шаг 22, изображение 1 из 2 Nintendo 3DS Power Button Replacement: шаг 22, изображение 2 из 2
      • Open the 3DS, but keep the backside of the buttons facing upward.
      • Use your finger to push the power button up through the upper case and remove it.
      • The power button only fits in one orientation, so be sure to reinstall it correctly.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
David Hodson
Участник с: 04/13/10
156 614 Репутация
Автор 127 руководств
1 Комментарий к руководству
Hi David, how are you doing? I have the Super Mario Black Edition 3ds. I accidently pulled out the power button ,now it's really difficult putting all the pieces back in the space where it belongs.Can you show me how to do the properly..... Please!
Thanks in Advance David
James - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 9
За последние 7 дней: 50
За последние 30 дней: 193
За всё время: 24,189
