Nintendo DS Lite Lower Screen Replacement
Выберете то, что вам нужно
  1. Nintendo DS Lite Lower Screen Replacement, Nintendo DS Lite Battery Disconnect: шаг 1, изображение 1 из 1
    • Place your device upside down and locate the battery compartment.
    • Find the Phillips head screw securing the battery cover in the bottom right hand corner of the device.
    • Loosen the screw enough to remove the battery cover but leave the screw in the cover for reassembly.
    • Use only a Phillips screwdriver to remove screw.
    Спросите у FixBot
    Добавить комментарий
  2. Nintendo DS Lite Lower Screen Replacement: шаг 2, изображение 1 из 1
    • Slowly remove the battery cover with the iFixit opening tool.
    • Make sure to remove the cover carefully to keep from losing Phillips screw in the cover. It will be needed for reassembly.
    Спросите у FixBot
  3. Nintendo DS Lite Lower Screen Replacement: шаг 3, изображение 1 из 2 Nintendo DS Lite Lower Screen Replacement: шаг 3, изображение 2 из 2
    • Use the iFixit opening tool to carefully pry the battery out of the case.
    • After the old battery is removed replace it with a new battery facing the same direction as when the cover was opened.
    • For some devices, you may be able to remove the battery by flipping the DS over and letting the battery fall into your hand.
    Спросите у FixBot
  4. Nintendo DS Lite Lower Screen Replacement, Disassembling Nintendo DS Lite Bottom Case: шаг 4, изображение 1 из 1
    • Remove the following seven screws that secure the lower case to the DS Lite:
    • Three silver tri-point screws (5mm long)
    • One black tri-point screw (4mm)
    • Two gold Phillips screws (4mm)
    • One silver Phillips screw (3mm)
    • Do not remove the silver PH screw (3mm) in the battery compartment yet. It holds the main PCB in place.
    Спросите у FixBot
  5. Nintendo DS Lite Lower Screen Replacement: шаг 5, изображение 1 из 1
    • On the front edge of the Nintendo DS between the headphone jack plug and volume controls remove the plastic insert (or cartridge) from the lower slot (Slot 2).
    Спросите у FixBot
  6. Nintendo DS Lite Lower Screen Replacement: шаг 6, изображение 1 из 2 Nintendo DS Lite Lower Screen Replacement: шаг 6, изображение 2 из 2
    • Flip the unit over so that it is facing right-side up.
    • Use a spudger to pry open the gap between the bottom case and the front panel. Work all the way around the case until the panel is free.
    • Avoid touching the L and R shoulder buttons, because they easily detach and are difficult to reassemble. Keep the bottom case flat against your workbench to help hold the shoulder buttons in place.
    Спросите у FixBot
  7. Nintendo DS Lite Lower Screen Replacement: шаг 7, изображение 1 из 3 Nintendo DS Lite Lower Screen Replacement: шаг 7, изображение 2 из 3 Nintendo DS Lite Lower Screen Replacement: шаг 7, изображение 3 из 3
    • Carefully separate the two pieces by hand.
    • The two shoulder buttons are made up of three pieces -- the plastic button, a pin, and a spring. If they accidentally pop out while you are working, study the picture and make sure you put the spring in the correct position.
    • When reassembling the cover, make sure that the power and volume switch covers on the bottom case are aligned with the switches on the board to avoid breakage.
    Спросите у FixBot
  8. Nintendo DS Lite Lower Screen Replacement, Lower Screen: шаг 8, изображение 1 из 1
    • Remove the two screws holding the motherboard to the rest of the device using a Phillips #00 screwdriver.
    Спросите у FixBot
  9. Nintendo DS Lite Lower Screen Replacement: шаг 9, изображение 1 из 2 Nintendo DS Lite Lower Screen Replacement: шаг 9, изображение 2 из 2
    • Locate the small ribbon cable that connects the touch screen to the motherboard. Do not pull on this cable.
    • Gently lift the hinged black cover on the connector.
    • The hinges are near where the ribbon is inserted.
    • After lifting the black cover, the ribbon cable will disconnect easily.
    Спросите у FixBot
  10. Nintendo DS Lite Lower Screen Replacement: шаг 10, изображение 1 из 1
    • With a plastic opening tool, gently begin to separate the motherboard from the rest of the device.
    • The ribbon cable and two wires are still connected to the motherboard and the buttons tend to fall out.
    Спросите у FixBot
  11. Nintendo DS Lite Lower Screen Replacement: шаг 11, изображение 1 из 2 Nintendo DS Lite Lower Screen Replacement: шаг 11, изображение 2 из 2
    • Flip the motherboard over so the touch screen is facing up.
    Спросите у FixBot
  12. Nintendo DS Lite Lower Screen Replacement: шаг 12, изображение 1 из 1
    • Do not pull on the main ribbon cable.
    • Carefully lift the tiny hinged cover on the connector.
    • The ribbon cable will easily disconnect.
    • Remove the third ribbon cable the same way.
    Спросите у FixBot
  13. Nintendo DS Lite Lower Screen Replacement: шаг 13, изображение 1 из 1
    • There is nothing else connecting the touch screen. Just pick up and set aside.
    Спросите у FixBot
Финишная прямая
13 человек успешно провели ремонт по этому руководству.
justin chadwick
Участник с: 01/21/10
512 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 16-30, Maness Winter 2010 Участник Cal Poly, Team 16-30, Maness Winter 2010
CPSU-MANESS-W10S16G30
4 членов
Автор 29 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 24
За последние 7 дней: 170
За последние 30 дней: 896
За всё время: 30,797
