Nintendo Switch Micro SD Card Reader Replacement
Выберете то, что вам нужно
  1. Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: шаг 1, изображение 1 из 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: шаг 1, изображение 2 из 3 Nintendo Switch Micro SD Card Reader Replacement, Release the Joy Con controller locking tabs: шаг 1, изображение 3 из 3
    • Before you begin this repair, make sure the device is completely powered off.
    • Press and hold down the small round button on the back of the Joy Con controller.
    • While you hold down the button, slide the controller upward.
  2. Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: шаг 2, изображение 1 из 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: шаг 2, изображение 2 из 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the Joy Con controllers: шаг 2, изображение 3 из 3
    • Continue sliding the Joy Con upward until it's completely removed from the console.
    • Repeat this same process for the other Joy Con.
  3. Nintendo Switch Micro SD Card Reader Replacement, Remove the back-side screws: шаг 3, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $16.96
    • Use a Y00 screwdriver to remove the four 6.3 mm-long screws securing the rear panel.
    • If you do happen to strip one of the four 6.3 mm-long Y00 screws, If you are lucky and careful, you may be able to use a Y0 bit to remove the screw(s). Please note that if you do attempt this, a bit of extra pressure will need to be applied to the screwdriver so that the screwdriver bit catches the screw.
    • If you do end up removing the stripped screw with this method, PLEASE do not reuse the screw again and instead replace the screw.
  4. Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: шаг 4, изображение 1 из 2 Nintendo Switch Micro SD Card Reader Replacement, Remove the top and bottom screws: шаг 4, изображение 2 из 2
    • Use a JIS 00 driver to remove the following screws securing the rear panel:
    • One 2.5 mm-long screw on the top edge of the device
    • Two 2.5 mm-long screws on the bottom edge of the device
    • To prevent these tight screws from stripping, apply firm downward force, work slowly, and try another JIS 00 driver if the screws won't come out. Make sure the driver is fully inserted.
    • You can use a Phillips #000 screwdriver in a pinch, but you risk damaging or stripping the screws. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they are the same size.
  5. Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: шаг 5, изображение 1 из 2 Nintendo Switch Micro SD Card Reader Replacement, Remove the center side screws: шаг 5, изображение 2 из 2
    • Use a JIS 00 driver to remove the two 3.8 mm center screws on the sides of the device (one on each side).
  6. Nintendo Switch Micro SD Card Reader Replacement: шаг 6, изображение 1 из 2 Nintendo Switch Micro SD Card Reader Replacement: шаг 6, изображение 2 из 2
    • Use your finger to flip up the kickstand on the back of the device.
    • If there's a microSD card in the microSD card slot, remove it now before you continue to the next step.
  7. Nintendo Switch Micro SD Card Reader Replacement, Remove the kickstand well screw: шаг 7, изображение 1 из 1
    • Use a JIS 00 driver to remove the 1.6 mm screw in the kickstand well.
    • Close the kickstand.
  8. Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: шаг 8, изображение 1 из 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: шаг 8, изображение 2 из 3 Nintendo Switch Micro SD Card Reader Replacement, Remove the rear panel: шаг 8, изображение 3 из 3
    • Open the game card cartridge flap.
    • The game card cartridge flap attaches to the other half of the plastic shell, preventing you from completely lifting up the rear panel if it's closed.
    • Lift the rear panel up from the bottom of the device and remove it.
  9. Nintendo Switch Micro SD Card Reader Replacement, Remove the microSD card reader: шаг 9, изображение 1 из 1
    • Use a JIS 00 driver to remove the 3.1 mm screw securing the microSD card reader to the device.
  10. Nintendo Switch Micro SD Card Reader Replacement: шаг 10, изображение 1 из 2 Nintendo Switch Micro SD Card Reader Replacement: шаг 10, изображение 2 из 2
    • Use your fingers or a pair of tweezers to lift the microSD card reader straight up from the device to disconnect and remove it.
    • During reassembly, make sure the press connector underneath the foam pad is firmly connected to the motherboard. It may help to remove the foam pad before reinstalling the card reader.
Заключение
Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Nintendo Switch Answers community for help.
168 человек успешно провели ремонт по этому руководству.
Craig Lloyd
Участник с: 02/10/16
41 056 Репутация
Автор 82 руководств
64 Комментарии к руководству
My SD reader never worked.
Used this guide to find that it was never seated correctly. Reseated and now works perfectly. THANK YOU!
Finx O'Mally - Ответить
My console won’t boot if I have an SD card inserted after reseating it. What should I do?
Ewan MacInnis - Ответить
Easy guide, fixed my problem. Changed the SD card reader cause I was abusing of it by putting SD in and out constantly.
Nicola Bonardi - Ответить
Great guide! My 11-year-old son was able to fix his Switch himself with no difficulty.
Matt - Ответить
Some one can help me, when I tried to put the connector again I damage the fpc connector of the motherboard so I try to find out again can any one know the kind of model of this connector I really appreciate the help
Best regards
Philip Milian - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 88
За последние 7 дней: 709
За последние 30 дней: 3,025
За всё время: 260,318
