Введение
A faulty USB can cause a host of different problems. This guide is designed to show the reader how to safely replace the USB outlet to restore proper function to your Numark N4 without needing to replace the entire motherboard it is attached to.
Please note that this guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Выберете то, что вам нужно
Turn the Numark N4 over so that the bottom panel is facing upwards.
Loosen and remove the 17 12mm screws from the bottom panel using a Phillips #2 screwdriver.
Using your fingers, gently pull apart the two panels of the device until you feel resistance from the cables.
Open the two panels completely, gently placing each side on your working area to avoid damage to the buttons on the outside face.
Loosen and remove the five 12mm screws from the circuit board using a Phillips #2 screwdriver.
Locate the USB on the circuit board.
Using a soldering station, carefully desolder the connection points to the USB outlet.
4 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
i we like to get the new board of dis numark n4
