OnHub Outer Casing Replacement
Выберете то, что вам нужно
    1. OnHub Outer Casing Replacement, Speaker Grille: шаг 1, изображение 1 из 2 OnHub Outer Casing Replacement, Speaker Grille: шаг 1, изображение 2 из 2
      • Make sure the device is unplugged before proceeding with the disassembly.
      • While holding the base firmly using the palm of one hand, remove the cowl (cover) by turning the cowl counterclockwise until a snap is heard. Once disengaged, pull upwards.
      Спросите у FixBot
      Добавить комментарий
    2. OnHub Outer Casing Replacement: шаг 2, изображение 1 из 1
      • Place the plastic opening tool under the speaker grille, and just above the light ring.
      • Move the plastic opening tool around the groove while applying upward force to pry loose the 4 clips holding the grille in place.
      Спросите у FixBot
    3. OnHub Outer Casing Replacement: шаг 3, изображение 1 из 2 OnHub Outer Casing Replacement: шаг 3, изображение 2 из 2
      • Using a metal spudger, carefully remove the congestion-sensor antenna by undoing the two clips.
      • There is a delicate wire connection to the antenna that is easily broken if not careful.
      Спросите у FixBot
    1. OnHub Outer Casing Replacement, Congestion-sensing Antenna: шаг 4, изображение 1 из 2 OnHub Outer Casing Replacement, Congestion-sensing Antenna: шаг 4, изображение 2 из 2
      • Remove the wire connection to the antenna by soldering it off.
      • For help with soldering and de-soldering check out the iFixit Soldering Guide
      Спросите у FixBot
    1. OnHub Outer Casing Replacement, Outer Casing: шаг 5, изображение 1 из 2 OnHub Outer Casing Replacement, Outer Casing: шаг 5, изображение 2 из 2
      • You must remove the plastic cover found just above the speaker.
      • Wedge the plastic opening tool under the cover and apply pressure in an upward direction.
      • There are four clips that you are removing. When disengaged, these clips will make a snapping noise.
      • Though the snapping noise is normal, take care not to break these clips.
      Спросите у FixBot
    2. OnHub Outer Casing Replacement: шаг 6, изображение 1 из 1
      • Upon removing the cover, four screws and the speaker housing will be exposed.
      • Unscrew the four 12mm screws using a #1 Phillips head screwdriver.
      • This unlocks the speaker housing and antenna array from the casing.
      Спросите у FixBot
    3. OnHub Outer Casing Replacement: шаг 7, изображение 1 из 2 OnHub Outer Casing Replacement: шаг 7, изображение 2 из 2
      • On the bottom of the OnHub is two screws holding the casing to the base.
      • To access these screws, you must remove the rubber pad that is glued to the base.
      • To remove the pad, slide a metal spudger under the edge of the pad. Pry the pad away from the base, removing the glue.
      • Once the pad is pulled up enough to grab, peel it the rest of the way exposing the screws.
      • The rubber pad is thin and fragile; be careful not to tear when removing.
      Спросите у FixBot
    4. OnHub Outer Casing Replacement: шаг 8, изображение 1 из 1
      • Remove the two 12mm screws under the base of the OnHub by using a #1 Phillips head screwdriver.
      Спросите у FixBot
    5. OnHub Outer Casing Replacement: шаг 9, изображение 1 из 2 OnHub Outer Casing Replacement: шаг 9, изображение 2 из 2
      • Once the two screws are removed from the base, it is time to split the casing apart.
      • It is okay if a couple clips break. It will still hold together with a few remaining.
      • Wedge a spudger between the two casing halves, and pry the clips apart starting from the top
      • There are three hooking style clips in total.
      Спросите у FixBot
    6. OnHub Outer Casing Replacement: шаг 10, изображение 1 из 1
      • Once unclipped, you can slide the two casing halves apart, and remove the casing.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Joseph Ainsworth
Участник с: 02/10/16
544 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 3-3, Sullivan Spring 2016 Участник USF Tampa, Team 3-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G3
3 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 10
За последние 30 дней: 31
За всё время: 700
