OnePlus 12 Back Glass Replacement
Выберете то, что вам нужно
    1. OnePlus 12 Back Glass Replacement, Back Glass: шаг 1, изображение 1 из 1
      • Ensure the phone is powered off and placed with the back glass facing towards you on a stable surface.
      Спросите у FixBot
      Добавить комментарий
    2. OnePlus 12 Back Glass Replacement: шаг 2, изображение 1 из 2 OnePlus 12 Back Glass Replacement: шаг 2, изображение 2 из 2
      • Pop open the SIM card tray by inserting a SIM card removal tool into the SIM card tray on the bottom of the phone.
      • Remove the SIM card tray from the phone and set it aside for when we are done.
      Спросите у FixBot
      • Loosen the glue holding the back glass in place by using a hairdryer or an iOpener.
      • If you use a hairdryer, hold it at least a few inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone - not the center.
      Спросите у FixBot
    3. OnePlus 12 Back Glass Replacement: шаг 4, изображение 1 из 2 OnePlus 12 Back Glass Replacement: шаг 4, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      Jimmy
      $7.95
      • Insert a Jimmy into the seam of the back glass to lift it slightly. Try to reduce pressure on any single spot of the glass to avoid cracking it.
      • Insert a plastic card underneath the small gap created on the back glass and gently glide the card under the lifted glass.
      • Remove the back glass from the phone by working your way around the glass slowly. You may need to re-heat after a while to keep the glue soft. Otherwise, you may shatter the glass.
      • Use isopropyl alcohol and a lint-free cloth to remove any leftover adhesive and adhesive residue from the frame of the phone (and the back glass if you are re-using it). Do not skip this or else the back glass may not stick on properly.
      Спросите у FixBot
Заключение
ThatStella7922
Участник с: 03/16/20
526 Репутация
Автор 3 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 10
За последние 7 дней: 55
За последние 30 дней: 110
За всё время: 110
