OnePlus 5 Rear-Facing Camera Replacement
Выберете то, что вам нужно
    1. OnePlus 5 Rear-Facing Camera Replacement, SIM Card Tray: шаг 1, изображение 1 из 3 OnePlus 5 Rear-Facing Camera Replacement, SIM Card Tray: шаг 1, изображение 2 из 3 OnePlus 5 Rear-Facing Camera Replacement, SIM Card Tray: шаг 1, изображение 3 из 3
      • Insert a SIM card eject tool, bit, or a straightened paperclip into the small hole below the SIM card tray, located near the rear cameras on the edge of the phone.
      • Press firmly to eject the tray.
      • During reassembly, be sure to properly orient the SIM tray you you insert it.
      Спросите у FixBot
      Добавить комментарий
    1. OnePlus 5 Rear-Facing Camera Replacement, Back Cover: шаг 2, изображение 1 из 1
      • Remove the two 2.6 mm T2 screws straddling the USB-C port on the bottom edge of the phone.
      Спросите у FixBot
    2. OnePlus 5 Rear-Facing Camera Replacement: шаг 3, изображение 1 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 3, изображение 2 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 3, изображение 3 из 3
      • There is a high risk of damaging the display panel if this opening procedure is improperly followed.
      • The following four steps show how to pry the rear case from the plastic frame. Read through the steps first before attempting the procedure.
      • There are two different seams between the body and the screen of the phone:
      • Display panel seam: This seam is part of the display assembly. Do not pry at this seam, or you will separate and damage the display panel.
      • Frame seam: This is where the plastic frame meets the back cover. Only pry at this seam.
      • There are twelve clips that hold the frame against the rear case. Be aware of their location as you pry the back cover off in the following steps.
      Спросите у FixBot
    3. OnePlus 5 Rear-Facing Camera Replacement: шаг 4, изображение 1 из 2 OnePlus 5 Rear-Facing Camera Replacement: шаг 4, изображение 2 из 2
      • As you work, try not to accidentally power on the phone. If you do, turn the phone off before resuming disassembly.
      • Place a suction cup near the bottom edge of the display.
      • Pull on the suction cup with strong steady force.
      • Press the edge of an opening tool straight into the frame seam near the suction cup until the edge wedges between the plastic frame and the back cover's lip.
      • Due to tight tolerances, this will take substantial force. Using a new opening tool with an unmarred edge will help with this step.
      Спросите у FixBot
    4. OnePlus 5 Rear-Facing Camera Replacement: шаг 5, изображение 1 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 5, изображение 2 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 5, изображение 3 из 3
      • Once the opening tool's edge is wedged in position, carefully slide the tool along the bottom edge of the phone.
      • Carefully guide the opening tool around the left corner of the phone while keeping the tool's edge within the seam.
      Спросите у FixBot
    5. OnePlus 5 Rear-Facing Camera Replacement: шаг 6, изображение 1 из 2 OnePlus 5 Rear-Facing Camera Replacement: шаг 6, изображение 2 из 2
      • Lever the opening tool to release the first clip from the frame.
      Спросите у FixBot
    6. OnePlus 5 Rear-Facing Camera Replacement: шаг 7, изображение 1 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 7, изображение 2 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 7, изображение 3 из 3
      • Continue sliding the opening tool along the long edge, releasing the clips along the way.
      • The last clip in the top-left corner near the front-facing camera is recessed and can be difficult to release. Take your time and use the flat end of a spudger or an opening pick to help.
      Спросите у FixBot
    7. OnePlus 5 Rear-Facing Camera Replacement: шаг 8, изображение 1 из 1
      • With the bottom and left edge of the phone freed, gently wiggle the frame to release the top and right edge clips.
      • The frame is still connected to the back cover by a long flex cable. Do not remove the back cover.
      • During reassembly, pause here to test your phone's functionality before securing the back cover.
      • To reinstall the back cover:
      • Align the top edge of the frame to the back cover and ensure that the top clips slip into place.
      • Squeeze along the long edges of the phone to snap the remaining clips into place.
      Спросите у FixBot
    8. OnePlus 5 Rear-Facing Camera Replacement: шаг 9, изображение 1 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 9, изображение 2 из 3 OnePlus 5 Rear-Facing Camera Replacement: шаг 9, изображение 3 из 3
      • With all the clips released, flip the phone over so that the display is face-down.
      • Swing the back cover around and rest it on top of the exposed frame.
      • Be careful not to stress the flex cable connecting the back cover and the frame.
      Спросите у FixBot
    9. OnePlus 5 Rear-Facing Camera Replacement: шаг 10, изображение 1 из 2 OnePlus 5 Rear-Facing Camera Replacement: шаг 10, изображение 2 из 2
      • Remove the 2.6 mm Phillips screw holding the cable bracket above the battery in place.
      • Lift up and remove the cable bracket.
      • To reinstall the bracket, position one end into place, and bend the bracket slightly to spring the other end into place.
      Спросите у FixBot
    10. OnePlus 5 Rear-Facing Camera Replacement: шаг 11, изображение 1 из 2 OnePlus 5 Rear-Facing Camera Replacement: шаг 11, изображение 2 из 2
      • Use the point of a spudger to pry up and disconnect the back cover flex cable from its socket.
      • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
      Спросите у FixBot
    11. OnePlus 5 Rear-Facing Camera Replacement: шаг 12, изображение 1 из 1
      • Remove the back cover.
      Спросите у FixBot
    1. OnePlus 5 Rear-Facing Camera Replacement, OnePlus 5 Battery Disconnect: шаг 13, изображение 1 из 2 OnePlus 5 Rear-Facing Camera Replacement, OnePlus 5 Battery Disconnect: шаг 13, изображение 2 из 2
      • Use the point of a spudger to pry up and disconnect the battery connector from its socket.
      Спросите у FixBot
    1. OnePlus 5 Rear-Facing Camera Replacement, Rear-Facing Camera: шаг 14, изображение 1 из 3 OnePlus 5 Rear-Facing Camera Replacement, Rear-Facing Camera: шаг 14, изображение 2 из 3 OnePlus 5 Rear-Facing Camera Replacement, Rear-Facing Camera: шаг 14, изображение 3 из 3
      • Use the point of a spudger to pry up and disconnect the two rear-facing camera connectors from their sockets on the motherboard.
      Спросите у FixBot
    2. OnePlus 5 Rear-Facing Camera Replacement: шаг 15, изображение 1 из 2 OnePlus 5 Rear-Facing Camera Replacement: шаг 15, изображение 2 из 2
      • Insert the point of a spudger under the top left corner of the camera module and pry up to loosen it from its recess.
      Спросите у FixBot
    3. OnePlus 5 Rear-Facing Camera Replacement: шаг 16, изображение 1 из 1
      • Remove the rear-facing camera module.
      Спросите у FixBot
Заключение
Repair didn’t go as planned? Check out our OnePlus 5 Answers Community for troubleshooting help.
2 человек успешно провели ремонт по этому руководству.
Arthur Shi
Участник с: 01/03/18
344 940 Репутация
Автор 915 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 10
За последние 30 дней: 47
За всё время: 4,377
