OnePlus 6 Rear Camera Replacement
Выберете то, что вам нужно
    1. OnePlus 6 Rear Camera Replacement, Back Panel: шаг 1, изображение 1 из 1
      • Turn on the heat gun to a low heat and and gently heat the curved edges on the back of the phone.
      • Be careful not to overheat or melt the plastic; heat guns can get out of hand quickly!
      • Wedge the opening picks between the front and back panel and slide them around the perimeter to break the adhesive securing the back cover.
      • Repeat until the back panel is fully released.
      Спросите у FixBot
      Добавить комментарий
    2. OnePlus 6 Rear Camera Replacement: шаг 2, изображение 1 из 2 OnePlus 6 Rear Camera Replacement: шаг 2, изображение 2 из 2
      • Gently lift up the back panel, with care not to damage the fingerprint sensor ribbon cable.
      Спросите у FixBot
    3. OnePlus 6 Rear Camera Replacement: шаг 3, изображение 1 из 2 OnePlus 6 Rear Camera Replacement: шаг 3, изображение 2 из 2
      Инструмент, используемый на этом этапе:
      • Use a pair of tweezers to gently pull up on the red tab and disconnect the cable from the device.
      • Completely remove the back panel from the device.
      Спросите у FixBot
    1. OnePlus 6 Rear Camera Replacement, Battery: шаг 4, изображение 1 из 2 OnePlus 6 Rear Camera Replacement, Battery: шаг 4, изображение 2 из 2
      • Grip the green tab connected to the battery and pull the battery directly up and out.
      Спросите у FixBot
    1. OnePlus 6 Rear Camera Replacement, Fingerprint sensor: шаг 5, изображение 1 из 2 OnePlus 6 Rear Camera Replacement, Fingerprint sensor: шаг 5, изображение 2 из 2
      • The midframe is made of plastic and located above the battery space.
      • Using the Phillips #00 screwdriver, remove the ten 3 mm screws from the midframe.
      • ATTENTION - Be aware that the 10th screw is actually underneath the round white sticker marked with the green circle at the bottom left. Do not remove the screw next to it marked with the orange circle or you will damage your midframe board.
      • Lift the bottom of the mid frame directly up and remove it from the device.
      Спросите у FixBot
    1. OnePlus 6 Rear Camera Replacement, Motherboard: шаг 6, изображение 1 из 1
      • Remove the ten screws holding the motherboard using a Phillips #00 screwdriver.
      Спросите у FixBot
    2. OnePlus 6 Rear Camera Replacement: шаг 7, изображение 1 из 2 OnePlus 6 Rear Camera Replacement: шаг 7, изображение 2 из 2
      • Disconnect the small metal tabs near the battery compartment that are holding the motherboard down.
      • Using a fingernail, carefully work under the edge and pry the motherboard up from the phone.
      • The cameras should lift up with the motherboard.
      Спросите у FixBot
    1. OnePlus 6 Rear Camera Replacement, Rear Camera: шаг 8, изображение 1 из 2 OnePlus 6 Rear Camera Replacement, Rear Camera: шаг 8, изображение 2 из 2
      • Lift up on the small tabs connecting the cameras to the motherboard to disconnect them.
      • Push on the lens side of the cameras and remove them from the motherboard.
      Спросите у FixBot
Заключение
Hunter Brown
Участник с: 09/28/21
118 Репутация
1 руководство автора
Команда
Clemson, Team 4-3, Hunter Fall 2021 Участник Clemson, Team 4-3, Hunter Fall 2021
CLEM-HUNTER-F21S4G3
5 членов
Автор 72 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 50
За всё время: 1,755
