OnePlus 6T Front Camera Replacement
Выберете то, что вам нужно
  1. OnePlus 6T Front Camera Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Make sure the phone is powered off and placed with the back cover facing towards you on a stable surface.
    Спросите у FixBot
    Добавить комментарий
  2. OnePlus 6T Front Camera Replacement: шаг 2, изображение 1 из 1
    • Pop open the SIM card tray by inserting a SIM card removal tool into a small hole on the upper-left side of the phone.
    • Carefully remove the SIM card from its tray.
    Спросите у FixBot
  3. OnePlus 6T Front Camera Replacement: шаг 3, изображение 1 из 1
    • Loosen the binding glue within the phone using a hairdryer or an iOpener.
    • If you choose to use a hairdryer, hold the dryer at least eight inches from the phone and apply heat for two minutes in a circular motion around the edges of the phone.
    Спросите у FixBot
  4. OnePlus 6T Front Camera Replacement: шаг 4, изображение 1 из 3 OnePlus 6T Front Camera Replacement: шаг 4, изображение 2 из 3 OnePlus 6T Front Camera Replacement: шаг 4, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    • Insert a Jimmy under one of the heated corners of the phone to lift it slightly.
    • Insert a plastic card underneath the slightly lifted lip on the back cover and gently glide the card under the lifted phone casing.
    • There will be a small amount of tension, but this is normal as the card is removing the adhesive within the phone.
    • Remove the back cover from the phone.
    • Use high concentration (>90%) isopropyl alcohol and a lint-free cloth to remove all adhesive residue from the back cover and the frame.
    Спросите у FixBot
  5. OnePlus 6T Front Camera Replacement, Front Camera: шаг 5, изображение 1 из 2 OnePlus 6T Front Camera Replacement, Front Camera: шаг 5, изображение 2 из 2
    • Remove the single 3mm Phillips #00 screws holding the metal battery cover on the phone.
    • Use tweezers to remove the battery cover and place it to the side.
    Спросите у FixBot
  6. OnePlus 6T Front Camera Replacement: шаг 6, изображение 1 из 1
    • Remove eight 3mm Phillips #00 screws that connect the midframe to the phone.
    Спросите у FixBot
  7. OnePlus 6T Front Camera Replacement: шаг 7, изображение 1 из 1
    • Using a spudger, gently remove the midframe and place it to the side.
    Спросите у FixBot
  8. OnePlus 6T Front Camera Replacement: шаг 8, изображение 1 из 1
    • Using a spudger, lift the light brown tab in the middle of phone to disconnect the front camera.
    • Remove the front camera from the phone.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Kristen Gismondi
Участник с: 11/12/14
107 794 Репутация
Автор 270 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 28 233 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 8
За последние 30 дней: 53
За всё время: 1,785
