PowerBook G3 Wallstreet Hard Drive Replacement
Выберете то, что вам нужно
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Keyboard: шаг 1, изображение 1 из 1
      • Remove both expansion bay modules using the levers on the front of the computer.
      • Insert your index fingers inside the expansion bays and search for the two ribbed tabs on the underside of the upper case. The tabs are located near the bottom corners of the keyboard.
      • Pull the tabs toward yourself and the keyboard will pop up.
      Спросите у FixBot
      Добавить комментарий
    2. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 2, изображение 1 из 1
      • Pull the keyboard forward to disengage the tabs holding it in back and rotate it toward you.
      • Rest the keyboard on the trackpad.
      Спросите у FixBot
      • This is a diagram of the ribbon clamp connectors you will disconnect in the next step.
      • 1) With your fingernails, grasp the locking bar on either side and pull up a small amount (about 1/16" or 2 mm).
      • 2) After disengaging the locking bar, slide the cable out of the connector.
      Спросите у FixBot
    3. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 4, изображение 1 из 1
      • Disconnect the two keyboard connectors by disengaging the clamps and pulling the ribbons directly upward.
      Спросите у FixBot
    4. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 5, изображение 1 из 1
      • Slide a spudger downward between each plastic strain relief cable and the wall of the case in order to bow out the cable beyond the small tab holding it in place.
      • Once the strain relief cables are free, lift the keyboard off.
      Спросите у FixBot
    5. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 6, изображение 1 из 1
      • Your laptop should look approximately like this.
      Спросите у FixBot
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Heat Shield: шаг 7, изображение 1 из 1
      • Remove the two Phillips screws from the heat shield.
      • One screw is shorter than the other. When putting the Wallstreet back together, this screw goes in the middle of the heat shield.
      Спросите у FixBot
    2. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 8, изображение 1 из 1
      • Grasp the metal handle on the heat shield and pull up and toward yourself.
      Спросите у FixBot
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Hard Drive: шаг 9, изображение 1 из 1
      • Unscrew, but do not remove, the single Phillips screw from the hard drive bracket.
      Спросите у FixBot
    2. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 10, изображение 1 из 1
      • Grasp the hard drive bracket on the left side and pull up and to the left.
      Спросите у FixBot
    3. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 11, изображение 1 из 1
      Спросите у FixBot
    1. PowerBook G3 Wallstreet Hard Drive Replacement, Hard Drive: шаг 12, изображение 1 из 1
      • Remove the four T8 Torx screws from the hard drive bracket.
      Спросите у FixBot
    2. PowerBook G3 Wallstreet Hard Drive Replacement: шаг 13, изображение 1 из 1
      • Turn the hard drive bracket over.
      • Hold the hard drive bracket at the connector end and grasp the opposite end of the hard drive.
      • Pull the hard drive out of the bracket, making sure to pull evenly on both sides.
      Спросите у FixBot
Заключение
43 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
3 Комментарии к руководству
It is much easier to remove and replace the hard drive by first removing the two T8 Torx screws on the hard drive connector at the end of the hard drive bracket (small green IC board). Less of a chance of bending the HD pins.
randy3833 - Ответить Поделиться
You absolutely do not need to remove the keyboard ribbon cables in order to replace the hard drive. You just need to be careful and the HDD caddy will come out just fine. As someone who has had some bad experiences with ribbon cables, I prefer not to remove them unless absolutely necessary.
Talor Berthelson - Ответить Поделиться
True! I just did the same thing, without even touching the keyboard...
oldnwstf - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 32
За последние 30 дней: 109
За всё время: 24,979
