PowerBook G4 Titanium Onyx Hard Drive Replacement
Выберете то, что вам нужно
      • Turn the G4 over.
      • Remove the eight T8 Torx screws from the lower case.
      Спросите у FixBot
      Добавить комментарий
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement: шаг 2, изображение 1 из 1
      • Using your thumbs, slide the lower case away from you.
      • The lower case may stick in the front on a tab just above the center of the DVD drive. Be careful as you work the case off, or you may break the thin strip of plastic just above the drive.
      • Lift the lower case off.
      Спросите у FixBot
    2. PowerBook G4 Titanium Onyx Hard Drive Replacement: шаг 3, изображение 1 из 1
      • Your laptop should look approximately like this.
      Спросите у FixBot
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement, Airport Card: шаг 4, изображение 1 из 1
      • Skip this step if your computer does not have an Airport card.
      • Firmly grasp the plastic tab attached to the Airport card and pull up and to the left.
      • Disconnect the antenna cable from the left side of the Airport card.
      Спросите у FixBot
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement, Hard Drive: шаг 5, изображение 1 из 1
      • Disconnect the hard drive ribbon from the logic board using a spudger or the tip of your finger, removing tape as necessary.
      Спросите у FixBot
    2. PowerBook G4 Titanium Onyx Hard Drive Replacement: шаг 6, изображение 1 из 1
      • To free the hard drive, remove the two T8 Torx screws from the right wall of the battery housing.
      Спросите у FixBot
    3. PowerBook G4 Titanium Onyx Hard Drive Replacement: шаг 7, изображение 1 из 1
      • Remove the hard drive by gently grasping the orange ribbon cable and lifting the left edge up and out of the computer.
      • There are four rubber bumpers that fit over the hard drive screws. Ensure that these bumpers come out when you remove the hard drive.
      Спросите у FixBot
    4. PowerBook G4 Titanium Onyx Hard Drive Replacement: шаг 8, изображение 1 из 1
      Спросите у FixBot
    1. PowerBook G4 Titanium Onyx Hard Drive Replacement, Hard Drive: шаг 9, изображение 1 из 1
      • Remove the two black plastic bumpers and two T8 Torx screws from the side of the hard drive.
      Спросите у FixBot
    2. PowerBook G4 Titanium Onyx Hard Drive Replacement: шаг 10, изображение 1 из 1
      • Grasp the orange ribbon cable and disconnect it from the hard drive. If the connector is tight, gently rock it from side to side.
      • Be sure to pull evenly on both sides as uneven force may damage the hard drive pins and render your data inaccessible.
      • If you are installing a new hard drive, we have an OS X install guide to get you up and running.
      Спросите у FixBot
Заключение
9 человек успешно провели ремонт по этому руководству.
Прикрепленные документы
iRobot
Участник с: 09/24/09
1 Репутация
Автор 636 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 11
За последние 30 дней: 51
За всё время: 13,747
