ProntoTec Axius Motherboard Replacement
Выберете то, что вам нужно
  1. ProntoTec Axius Motherboard Replacement, Motherboard: шаг 1, изображение 1 из 1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place the tablet face-up on a flat table.
    Спросите у FixBot
    Добавить комментарий
  2. ProntoTec Axius Motherboard Replacement: шаг 2, изображение 1 из 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
    Спросите у FixBot
  3. ProntoTec Axius Motherboard Replacement: шаг 3, изображение 1 из 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Make sure not to sever the wires (red and black) connected to the speaker that is located in the back case.
    Спросите у FixBot
  4. ProntoTec Axius Motherboard Replacement: шаг 4, изображение 1 из 2 ProntoTec Axius Motherboard Replacement: шаг 4, изображение 2 из 2
    • Remove only the yellow tape that touches the motherboard
    • Be careful not to cut or damage the wires (red and black) that connect the battery to the motherboard.
    Спросите у FixBot
  5. ProntoTec Axius Motherboard Replacement: шаг 5, изображение 1 из 3 ProntoTec Axius Motherboard Replacement: шаг 5, изображение 2 из 3 ProntoTec Axius Motherboard Replacement: шаг 5, изображение 3 из 3
    • Use a Phillips screwdriver (PH00) to unscrew the two screws that connects the motherboard to the device
    • Be careful not to cut or damage the wires (red and black) that connect the motherboard to the battery.
    Спросите у FixBot
  6. ProntoTec Axius Motherboard Replacement: шаг 6, изображение 1 из 2 ProntoTec Axius Motherboard Replacement: шаг 6, изображение 2 из 2
    • Using a soldering iron, desolder the contact points of the speaker, battery and screen on the motherboard
    • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
    • Use pliers to pull the wire from the board
    Спросите у FixBot
  7. ProntoTec Axius Motherboard Replacement: шаг 7, изображение 1 из 2 ProntoTec Axius Motherboard Replacement: шаг 7, изображение 2 из 2
    • Using the spudger, disconnect the ribbon cable connecting the camera to the motherboard
    Спросите у FixBot
  8. ProntoTec Axius Motherboard Replacement: шаг 8, изображение 1 из 3 ProntoTec Axius Motherboard Replacement: шаг 8, изображение 2 из 3 ProntoTec Axius Motherboard Replacement: шаг 8, изображение 3 из 3
    • Using the spudger, push the black tabs towards the ribbon cable to unlock the ribbon cables that connect the screen to the motherboard.
    • Gently pull and remove the ribbon cables from the motherboard
    Спросите у FixBot
  9. ProntoTec Axius Motherboard Replacement: шаг 9, изображение 1 из 2 ProntoTec Axius Motherboard Replacement: шаг 9, изображение 2 из 2
    • Using the flat side of the spudger, lift up the mother board to disconnect from the screen.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Estelle Hatem
Участник с: 10/20/16
156 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 5-3, Martin Fall 2016 Участник UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 5
За последние 30 дней: 32
За всё время: 622
