ProntoTec Axius Speaker Replacement
Выберете то, что вам нужно
  1. ProntoTec Axius Speaker Replacement, Speaker: шаг 1, изображение 1 из 1
    • Make sure the device is completely turned off before you begging taking it apart to avoid electrocution risks.
    • Place tablet face-up on a flat table.
    Спросите у FixBot
    Добавить комментарий
  2. ProntoTec Axius Speaker Replacement: шаг 2, изображение 1 из 1
    • Starting near the headphone port, fit the flat end of the spudger in between the screen and back case.
    • Pry the back case from the screen around each point on the device to release the clips securing the case halves to each other.
    Спросите у FixBot
  3. ProntoTec Axius Speaker Replacement: шаг 3, изображение 1 из 1
    • Gently remove the back case of the device and lay it in a flat surface as shown in the photo.
    • Don't pull the back of the device too far apart so it doesn't damage the wires that are connected to the speaker in the back of the device
    Спросите у FixBot
  4. ProntoTec Axius Speaker Replacement: шаг 4, изображение 1 из 3 ProntoTec Axius Speaker Replacement: шаг 4, изображение 2 из 3 ProntoTec Axius Speaker Replacement: шаг 4, изображение 3 из 3
    • Disconnect the red wire connecting the speaker to the motherboard by using a soldering iron to melt the contact point.
    • Once the solder is melted, use pliers to pull the wire away from the motherboard
    Спросите у FixBot
  5. ProntoTec Axius Speaker Replacement: шаг 5, изображение 1 из 2 ProntoTec Axius Speaker Replacement: шаг 5, изображение 2 из 2
    • Repeat Step 4 with the black wire connecting the speaker to the motherboard.
    • Don't leave the soldering iron too long on top of the wire so it doesn't melt any other component in the motherboard or surrounding the area.
    • If soldering is new to you, check out this helpful guide on soldering and desoldering connections.
    Спросите у FixBot
  6. ProntoTec Axius Speaker Replacement: шаг 6, изображение 1 из 2 ProntoTec Axius Speaker Replacement: шаг 6, изображение 2 из 2
    • Using a spudger gently remove the speaker from the back of the device.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger should be used whenever possible.
    Спросите у FixBot
Заключение
Antonio Irons
Участник с: 10/20/16
441 Репутация
Автор 4 руководств
Команда
UMass Dartmouth, Team 5-3, Martin Fall 2016 Участник UMass Dartmouth, Team 5-3, Martin Fall 2016
UMASSD-MARTIN-F16S5G3
3 членов
Автор 10 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 3
За последние 30 дней: 22
За всё время: 410
