Razer DeathAdder V3 Pro USB-C Port Replacement
Выберете то, что вам нужно
  1. Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: шаг 1, изображение 1 из 3 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: шаг 1, изображение 2 из 3 Razer DeathAdder V3 Pro USB-C Port Replacement, Scroll Wheel: шаг 1, изображение 3 из 3
    • Use a pry tool or fingernail to carefully remove the large foot on the lower end of the mouse.
    • Remove the three 7 mm screws using a Torx T6 screwdriver.
    Спросите у FixBot
    Добавить комментарий
  2. Razer DeathAdder V3 Pro USB-C Port Replacement: шаг 2, изображение 1 из 2 Razer DeathAdder V3 Pro USB-C Port Replacement: шаг 2, изображение 2 из 2
    • BEFORE YOU OPEN THE MOUSE: Be careful at this point. Both shells are connected with a cable in the front of the mouse.
    • Insert a spudger into the seam between the top and bottom shells.
    • Gently work around the edges unclipping the internal latches.
    • Slowly lift the top shell but do not remove it yet; the cables are still attached to the circuit board.
    • Carefully pull the shells apart to unplug the cable in the front.
    Спросите у FixBot
  3. Razer DeathAdder V3 Pro USB-C Port Replacement: шаг 3, изображение 1 из 2 Razer DeathAdder V3 Pro USB-C Port Replacement: шаг 3, изображение 2 из 2
    • Using a small pry tool or your fingers, gently pop the scroll wheel up and out of its housing
    Спросите у FixBot
  4. Razer DeathAdder V3 Pro USB-C Port Replacement, USB-C Port: шаг 4, изображение 1 из 1
    • Use a T6 Torx screwdriver to remove the 5mm screws from the circuit board.
    • Unplug the battery from its connection on the right.
    • Be careful not to break the two clips that hold the PCB at the front of the mouse.
    • Remove the circuit board from the mouse.
    Спросите у FixBot
  5. Razer DeathAdder V3 Pro USB-C Port Replacement: шаг 5, изображение 1 из 1
    • Always solder in a well ventilated area.
    • Apply solder to the four anchor points on the back corners and side of the USB-C port.
    • Once the solder has melted, use tweezers to remove the USB-C port.
    • Use a solder sucker to clean the area.
    Спросите у FixBot
  6. Razer DeathAdder V3 Pro USB-C Port Replacement: шаг 6, изображение 1 из 1
    • Apply flux, then apply solder to one anchor point to help line up the new USB-C port.
    • Once the USB-C port is aligned, apply flux to the other three anchor points and solder them.
    Спросите у FixBot
Заключение
Nicholas
Участник с: 09/24/25
453 Репутация
Автор 4 руководств
Команда
Texas Tech, Team 2-5, Johansen Fall 2025 Участник Texas Tech, Team 2-5, Johansen Fall 2025
TTU-JOHANSEN-F25S2G5
5 членов
Автор 5 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 52
За всё время: 308
