Retina MacBook 2016 Display Assembly Replacement
Выберете то, что вам нужно
  1. Retina MacBook 2016 Display Assembly Replacement, Unfasten the lower case: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Remove the following eight screws securing the lower case:
    • Two 1.8 mm P5 Pentalobe screws
    • Four 2.9 mm P5 Pentalobe screws
    • Two 6.1 mm P5 Pentalobe screws
    • Note the orientation of the screws as you remove them—they need to be reinstalled at a slight angle.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
    Спросите у FixBot
    Добавить комментарий
  2. Retina MacBook 2016 Display Assembly Replacement: шаг 2, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 2, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 2, изображение 3 из 3
    • Wedge your fingers between the upper case and the lower case, starting from the rear of the MacBook between the hinges.
    • Lift the lower case only slightly to avoid damaging the cables that connect the lower case to the upper case.
    • Keeping a firm grip, lift steadily until the lower case separates slightly from the upper case.
    • You may experience a lot of resistance when lifting the lower case. If necessary, slide an opening pick or other ESD-safe pry tool down the side edges of the lower case to pop the two hidden retaining clips free.
    • During reassembly, to re-engage the clips, press firmly near both side edges of the lower case (near where the pick is inserted in the third image) until you hear the clips snap into place.
    Спросите у FixBot
  3. Retina MacBook 2016 Display Assembly Replacement: шаг 3, изображение 1 из 1
    • While holding the lower case in place, carefully flip the MacBook over so the Apple logo faces up.
    Спросите у FixBot
  4. Retina MacBook 2016 Display Assembly Replacement: шаг 4, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 4, изображение 2 из 2
    • Lift the upper case and display together from the front edge and raise it to about a 45˚ angle.
    • It may be helpful to prop the MacBook open in this position for the next step.
    Спросите у FixBot
  5. Retina MacBook 2016 Display Assembly Replacement: шаг 5, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 5, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 5, изображение 3 из 3
    • Use the flat end of a spudger to press and hold the small gold 'battery disconnect' button.
    • If the power LED is lit up, continue holding the button until the LED goes dark, and then release. This may take up to 10 seconds.
    • If the LED does not light, release the button after 5-10 seconds. Press and hold it again for 5-10 seconds, and release. Finally, press and hold it a third time for 5-10 seconds, and release.
    • This step ensures the MacBook is fully powered down and safe to work on.
    Спросите у FixBot
  6. Retina MacBook 2016 Display Assembly Replacement: шаг 6, изображение 1 из 1
    • Close the MacBook and carefully flip it upside-down.
    Спросите у FixBot
  7. Retina MacBook 2016 Display Assembly Replacement: шаг 7, изображение 1 из 1
    • Lifting from the front edge, open the lower case to an angle of about 45°.
    • Take care not to damage the ribbon cables that still attach the lower case to the MacBook.
    Спросите у FixBot
  8. Retina MacBook 2016 Display Assembly Replacement: шаг 8, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 8, изображение 2 из 2
    • Use tweezers to peel back the tape covering the trackpad cable ZIF connector.
    Спросите у FixBot
  9. Retina MacBook 2016 Display Assembly Replacement: шаг 9, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 9, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 9, изображение 3 из 3
    • Use a spudger to carefully flip up the retaining flap on the trackpad cable ZIF connector.
    Спросите у FixBot
  10. Retina MacBook 2016 Display Assembly Replacement: шаг 10, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 10, изображение 2 из 2
    • Disconnect the trackpad ribbon cable from the trackpad by pulling it gently through its slot in the frame.
    Спросите у FixBot
  11. Retina MacBook 2016 Display Assembly Replacement: шаг 11, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 11, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 11, изображение 3 из 3
    • Carefully close the MacBook and flip it over once again, so that the Apple logo faces up.
    • Lifting from the front edge, raise the upper case/display assembly to about a 90° angle, and prop it up against something sturdy so you don't have to hold it.
    • Add a piece of tape near the track pad to secure the upper case and prevent accidental movement.
    • It's possible to open the MacBook all the way and lay both sides down flat, but this may damage the flex cables and is not recommended.
    Спросите у FixBot
  12. Retina MacBook 2016 Display Assembly Replacement: шаг 12, изображение 1 из 1
    • Remove the single 2.9 mm T5 Torx screw securing the battery connector to the logic board.
    Спросите у FixBot
  13. Retina MacBook 2016 Display Assembly Replacement: шаг 13, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 13, изображение 2 из 2
    Battery Blocker
    $5.95
    • As an added precaution, you may physically disconnect the battery by inserting a battery isolation pick between the logic board and the battery connector.
    Спросите у FixBot
  14. Retina MacBook 2016 Display Assembly Replacement, USB-C and Audio Jack Disconnect: шаг 14, изображение 1 из 1
    • Remove the two screws securing the USB-C port cable bracket:
    • 1.1 mm Phillips #00 screw
    • Some variations of this model may use a Tri-point Y00 screw.
    • 3.5 mm T5 Torx screw
    Спросите у FixBot
  15. Retina MacBook 2016 Display Assembly Replacement: шаг 15, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 15, изображение 2 из 2
    • Use the flat end of a spudger to disconnect the USB-C port cable bracket by prying it straight up from the logic board.
    • To reconnect this cable, first line up the metal bracket over the screw holes, then press down on the middle of the bracket. Make sure it's aligned correctly, or you may damage the connector.
    Спросите у FixBot
  16. Retina MacBook 2016 Display Assembly Replacement: шаг 16, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 16, изображение 2 из 2
    • Use a spudger to flip open the retaining flap on the audio jack board cable ZIF connector.
    Спросите у FixBot
  17. Retina MacBook 2016 Display Assembly Replacement: шаг 17, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 17, изображение 2 из 2
    • Disconnect the audio jack board ribbon cable by pulling it straight back out of the ZIF connector.
    • During reassembly, orient the ribbon cable so the white stripe faces you. Insert the cable until the white line disappears under the socket.
    • At this point it is possible to open the macbook all the way and to lay it flat on a table without causing any damage to the flex cables.
    Спросите у FixBot
  18. Retina MacBook 2016 Display Assembly Replacement, Lower Case Assembly Removal: шаг 18, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement, Lower Case Assembly Removal: шаг 18, изображение 2 из 2
    • Use tweezers to peel back the tape covering the display cable connector.
    Спросите у FixBot
  19. Retina MacBook 2016 Display Assembly Replacement: шаг 19, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 19, изображение 2 из 2
    • It's possible the metal retaining flap on the display cable connector may flip open, remaining stuck to the tape.
    • If so, use the flat end of a spudger to hold down the retaining flap while peeling the tape away with the tweezers.
    Спросите у FixBot
  20. Retina MacBook 2016 Display Assembly Replacement: шаг 20, изображение 1 из 1
    • Use the flat end of a spudger to flip open the retaining flap on the display cable connector.
    • Try to keep it clear of the tape, or it may re-adhere and make cable removal difficult.
    Спросите у FixBot
  21. Retina MacBook 2016 Display Assembly Replacement: шаг 21, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 21, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 21, изображение 3 из 3
    iOpener
    $14.95
    • Carefully slide the flat end of a spudger underneath the display cable to separate the adhesive holding it to the lower case.
    • Take care not to damage the cable. If the adhesive is very strong, heat the case directly beneath the cable with an iOpener to soften the adhesive, and then try again.
    Спросите у FixBot
  22. Retina MacBook 2016 Display Assembly Replacement: шаг 22, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 22, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 22, изображение 3 из 3
    • Hold the retaining flap open.
    • Disconnect the display cable by gently pulling it straight out of its connector.
    • Immediately close the retaining flap. Keep it closed throughout your repair.
    • During reassembly, keep the flap closed while you insert the display cable. Remember to orient the cable so its gold contacts face down, making sure not to crimp or fold it—it'll click into place when it's connected.
    Спросите у FixBot
  23. Retina MacBook 2016 Display Assembly Replacement: шаг 23, изображение 1 из 1
    • Separate the upper case assembly from the lower case assembly.
    Спросите у FixBot
  24. Retina MacBook 2016 Display Assembly Replacement, Audio Jack Board: шаг 24, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement, Audio Jack Board: шаг 24, изображение 2 из 2
    • Use a spudger to flip open the ZIF connector retaining flap for the dual microphone assembly ribbon cable.
    Спросите у FixBot
  25. Retina MacBook 2016 Display Assembly Replacement: шаг 25, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 25, изображение 2 из 2
    • Disconnect the microphone assembly ribbon cable by pulling it straight out of its connector.
    Спросите у FixBot
  26. Retina MacBook 2016 Display Assembly Replacement: шаг 26, изображение 1 из 1
    • Remove the two 3.2 mm T5 Torx screws securing the audio jack board to the case.
    Спросите у FixBot
  27. Retina MacBook 2016 Display Assembly Replacement: шаг 27, изображение 1 из 1
    • Remove the audio jack board.
    Спросите у FixBot
  28. Retina MacBook 2016 Display Assembly Replacement, USB-C Port: шаг 28, изображение 1 из 1
    • Remove two 2.5 mm Phillips #00 screws securing the USB-C port.
    Спросите у FixBot
  29. Retina MacBook 2016 Display Assembly Replacement: шаг 29, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 29, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 29, изображение 3 из 3
    • Use tweezers to lift the USB-C port just over the hinge screws.
    • Slide the port out and up over the display hinge to remove it.
    • There's very little clearance when removing and installing the USB-C port. If there's not enough room, don't force it. Try removing the display hinge screws and moving the hinges for additional clearance, if necessary.
    Спросите у FixBot
  30. Retina MacBook 2016 Display Assembly Replacement, Display Assembly: шаг 30, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement, Display Assembly: шаг 30, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement, Display Assembly: шаг 30, изображение 3 из 3
    • Remove the two 3.3 mm T5 Torx screws securing the display cable assembly.
    • Take care not to lose the small retaining bracket located under the right screw. If it comes loose, note the orientation shown here for reassembly. The small tab on the outer left edge should be hooked under the perforated metal shield.
    Спросите у FixBot
  31. Retina MacBook 2016 Display Assembly Replacement: шаг 31, изображение 1 из 1
    • Fully open the display.
    • Set the MacBook down on its right edge with the display facing away from you, as shown.
    Спросите у FixBot
  32. Retina MacBook 2016 Display Assembly Replacement: шаг 32, изображение 1 из 2 Retina MacBook 2016 Display Assembly Replacement: шаг 32, изображение 2 из 2
    • Remove the four 4.8 mm T8 Torx screws securing the display hinges.
    • There may be a rubber cover on the hinge screws. Remove this before removing the screws and replace it during reassembly.
    Спросите у FixBot
  33. Retina MacBook 2016 Display Assembly Replacement: шаг 33, изображение 1 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 33, изображение 2 из 3 Retina MacBook 2016 Display Assembly Replacement: шаг 33, изображение 3 из 3
    • Holding the display assembly with one hand and the upper case with the other, push them together slightly to move the hinges out of their recesses in the the upper case.
    • There are only a few millimeters of play between the hinges and the case, so you won't need to push far.
    • Push the upper case forward while pulling back gently on the display.
    • Once the two display hinges have cleared the upper case, remove the display and set it aside.
    Спросите у FixBot
Заключение
26 человек успешно провели ремонт по этому руководству.
Adam O'Camb
Участник с: 04/11/15
223 670 Репутация
Автор 416 руководств
11 Комментарии к руководству
Hi, I did the tutorial and everything worked out except for one thing. My Macbook isn’t detecting when I close it and open it. I would like some help, does anyone know how to solve it?
Arthur Rezende de Faria - Ответить Поделиться
will a 2015 screen work on a 2016 machine?
Mac Simple - Ответить Поделиться
did you ever find the answer to this? I have a 2016 machine and looking for a new screen.
Omar Ramirez - Ответить Поделиться
I followed the instructions, seemingly without problems, but the laptop won’t power up now. I have disassembled and reassemble twice, but haven’t found anything obviously missed or out of place. Any ideas on what might be preventing it from charging and restarting?
E.D. van Eerten - Ответить Поделиться
hi E.D. I had the same problem,but i got it to reboot with the help here https://www.macworld.co.uk/how-to/mac/ma... this
Dominik Ziegler - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 27
За последние 30 дней: 120
За всё время: 38,267
