Введение
Use this guide to replace a damaged or malfunctioning IR LED in the Roku XD 2050X remote control. To complete this guide, you will need to disassemble your remote and use a soldering iron to replace the LED.
Выберете то, что вам нужно
Insert flat edge of spudger into seam between the top and bottom halves of the remote control.
Gently twist the spudger to separate the top and bottom halves of the remote.
Using either end of the spudger, gently lift and remove the clear keypad backing.
Desolder the two contacts for the IR LED.
Remove the IR LED from the circuit board.
For help with soldering view the ifixit soldering guide.
Еще один человек закончил это руководство.
